Going to the Dealer - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-27-2008, 07:55 PM   #1
teleopti
My Ride: BMW 330i
Unhappy Going to the Dealer
So I had the alignment triple checked and tires rotated. Everything is within specs BUT I still have to hold the steering wheel to the right a little bit with an occasional vibration around 40-50mph. When turning, the wheel seems tighter to the left than it does to the right. I contacted my advisor and he says its the control arms and bushings that need to be replaced. I think he quoted me at 800?
What do you guys think? Is this the solution to the problem or is there something else that may be causing it like for example a much much MUCH cheaper solution?
Thanks again guys for all the help!
teleopti is offline   Reply With Quote
Old 04-27-2008, 08:03 PM   #2
kcalhoun27
My Ride: under conctruction
Ruben @ desert motor works + DIY = much cheaper solution.
if you have to change this stuff he can hook you up with the parts at a great rate, and then get your hands a bit dirty for the love of your car!
also, Ruben is a pleasure to deal with and he can answer any of your questions. I bought the parts also, so this is first hand info
good luck
-kevin
Originally Posted by theribdoctor View Post
chili is awesome, I bleed aqua and orange.
kcalhoun27 is offline   Reply With Quote
Old 04-27-2008, 10:01 PM   #3
mechanic_101
My Ride: 2005 325I
you would save about 50% if DIY.
mechanic_101 is offline   Reply With Quote
Old 04-27-2008, 10:03 PM   #4
Anub!s
My Ride: e46 330ci, e92 M
Send a message via AIM to Anub!s Send a message via MSN to Anub!s Send a message via Yahoo to Anub!s
good luck
+20539896
You can even save by using an indy shop.
Anub!s is offline   Reply With Quote
Old 04-27-2008, 10:46 PM   #5
teleopti
My Ride: BMW 330i
so do u guys think that that is what my problem is?
idk any good indy shops around here. i would do the work but im afraid ill be in a biger prob if i screw it up just by trying to save a hundred buck
Old 04-27-2008, 10:48 PM   #6
Anub!s
I'm sure there's a bunch of fanatics in your area. Talk to the guys in the regional forum and try to find an indy shop. Who knows, maybe one of them might even offer to help out themselves.
