///M3 Forum
Old 04-28-2008, 10:39 PM   #1
E46NYBMW
My Ride: E46
HELP! what do these dash lights mean ??
Been having a werid rubbing noise in the back, suspect it to be diff fluid needing to be changed. But waiting to find some stock wheels before i bring it into the stealership. Is this causing the indicator lights to come on ? These lights come on, then once I turn off the car and turn it back on it goes off.
E46NYBMW is offline   Reply With Quote
Old 04-28-2008, 11:15 PM   #2
colinschick
My Ride: 325ci
i think it could be a few diff things.
abs wheel sensor?
brake fluid low?
dsc module?
rotation rate sensor?
i had the same prob and have been doing tons of research on this problem. mine turn out to be a nail in my tire that caused a flat and that set off the lights since the wheels turned at diff rates. i hope this helps. pay the ~$90 to have a shop clear all codes and they can pinpoint it.
colinschick is offline   Reply With Quote
Old 04-29-2008, 12:59 AM   #3
3rd_collective
ti-m-e
3rd_collective's Avatar
My Ride: Alpine White ///M
Send a message via AIM to 3rd_collective
if you got a owners manual....
3rd_collective is offline   Reply With Quote
Old 04-29-2008, 01:01 AM   #4
jetblack///M
My Ride: 03 Jet Black SMG M3
Well the one in the middle is traction control and the one all the way to the right is ur tire pressure I dont know what the other one is
jetblack///M is offline   Reply With Quote
Old 04-29-2008, 01:03 AM   #5
JL328i
My Ride: BSM 03 325i 5MT ZSP
The 328i that once was... :(
JL328i is offline   Reply With Quote
Old 04-29-2008, 01:18 AM   #6
mpowered95
My Ride: 02 M3
Originally Posted by JL328i View Post
true
mpowered95 is offline   Reply With Quote
Old 04-29-2008, 01:20 AM   #7
JL328i
haha. i tried to post a pic from my owners manual but i dont know how... if anyone wants to tell me ive got it ready!
Old 04-29-2008, 10:18 PM   #8
E46NYBMW
My Ride: E46
checked the tire pressure and seems to be ok.
Old 04-29-2008, 10:25 PM   #9
KOTYKB
My Ride: 2003.5 M3 & CBR600RR
Send a message via AIM to KOTYKB
then hit the tire pressure button to turn the one light off and hit the traction button to turn the second button off
KOTYKB is offline   Reply With Quote
Old 04-29-2008, 11:01 PM   #10
Dirty B1
My Ride: 2002 BMW ///M3
The yellow light that says "brake" means your brake pads or rotors are worn or malfunctioning. Could also be a bad brake sensor. The exclamation point is your tire pressure sensor TPS. I had an 02 325ci that had the ABS light on like that. Ended up being a steering angle sensor, whatever the hell that does it's $500 azz raping at the stealership
Dirty B1 is offline   Reply With Quote
Old 04-29-2008, 11:52 PM   #11
Shanetoast
My Ride: 2003 M3
Its your tire pressure sensor. My tires that i have on the car right now dont have sensors in them so that light stays on. But the tires that were on the car before had sensors so the light stayed off. So again dont worry its just the tire sensor. I took it to the dealership just to make sure thts what it was.
Shanetoast is offline   Reply With Quote
Old 04-30-2008, 12:43 AM   #12
dabears
My Ride: 2003 BMW M3
when my tire pressure sensor goes off it's red... so I'm pretty sure (Especially because the ABS light is on (at least I think it is?) that this is not tire pressure related, but reset it anyways by holding down the button on your centre console.
dabears is offline   Reply With Quote
Old 04-30-2008, 04:03 PM   #13
profM3
My Ride: 2005 M3 ZCP
If you don't have a flat, it's probably a tire rotation sensor gone bad. The tire pressure monitor, DSC, and ABS systems all use the rotation sensors to make decisions on what to do. Since all your lights are on, it makes sense that it's the sensor. I had same symptoms on your Mini. The dealer can probably read the code and it will tell them which sesnor on which wheel. Then be prepared for the bill...
profM3 is offline   Reply With Quote
Old 04-30-2008, 11:46 PM   #14
E46NYBMW
My Ride: E46
Tried reseting it by holding down the tire pressure button, but no help. I think it is the rotation sensor gone bad.. how can this happen ? Is it covered under CPO warrenty? Would they give me a problem if I go in with my aftermarket wheels? Im looking to buy a stock set of wheels before I go in.
