Old 05-02-2008, 08:32 PM   #1
joehall71
joehall71's Avatar
My Ride: e46 M3 vert, X5 3.0,
Yet another angel eye M**fckr thread
Bought My Carr angel eyes from EAS
They came on time and were reasonably priced accept one of the lights were broken internally. There goes my weekend of gettin stuff done! Now I have to wait till Monday to order a replacement. AGH!
So being a licensed electrician and a car fanatic i need to make some suggestions to make the installation of this product go smoother.
1. The one small sheet of instructions that came in the box; don't bother putting it in there. It tells you nothing and dosen't give any links to a page on the net with the real instructions. I found a thread where Tom from EAS gave the link to the instructions for one of our members.
2. EAS. Put the instructions link on the product page. I looked and they are not there.
3. Note on installation. The e46 M3 headlight assemblies are hardwired from the light assembly to the ballast/igniter if BMW performed any work on your headlights. Apparently the "quick disconnects are factory only.
4. Notes on the included wiring and harness. The connectors supplied on the end of the wiring harness that are supposed to connect to the angel eye ballast leads (black and white to the brown and red on the wiring harness) do not work. Unless MYCARR forgot to put the crimp on connectors for the ballast leads you have to cut the factory connectors off and make your own connection (crimp barrel, solder etc.)
5. Additional notes on the internet instructions. It would be a good idea to put a wiring diagram in it.
Installation degree of difficulty 5 but it should be a 2
Installation degree of frustration 8 on a scale of 1-10
joehall71 is offline   Reply With Quote
Old 05-09-2008, 03:30 AM   #2
sillieidiot
My Ride: '06 AW 330ci
for number 1, i'm fairly confident they didn't put it in there. comes like that from the factory. for 4. the wiring harness isn't mycarr. i believe it's from another supplier as they do not sell with relays. other than that, i agree on the remaining points.
Old 05-09-2008, 04:28 PM   #3
joehall71
joehall71's Avatar
bought another set and have the same wiring issue. Mycarr is going to have to do a massive recall to fix the units that were already sold or issue a TSB.
