rear spring change - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 05-05-2008, 08:15 AM   #1
dougsre
My Ride: 2002 330xi
rear spring change
Hi everyone, I am a new member. I drive a 2002 330xi I have a broken left rear spring, the dealer wants over $600 to change both rears. I have been pricing each at $124. Is it a difficult procedure to attempt myself? What are the steps in performing this procedure? Has anyone used raxles.com in replacing the front axle. My left front cv boot is tore and it was recommended to replace the axle and cv joints in the process instead of just the boots, any recommendations? I appreciate any help.
Thanks, Doug
dougsre is offline   Reply With Quote
Old 05-05-2008, 08:28 AM   #2
M-Spec Tuner
My Ride: 325i
Doug,
The rear springs are said to be easy to change, but from my experience it was a pain. Really all you have to do is jack up the rear, rest it on jack stands, and take off the bolt that secures the strut to the control arm. From there it is advised to have someone help you push down on the axle so you will have enough room to wiggle the spring out.
If you normally work on cars then you can attempt it at your own risk. If not then leave it to a professional. I can't help you with the axles cause I have never had to work on them before.
Good luck.
'03 325i...Just getting started!
M-Spec Tuner is offline   Reply With Quote
Old 05-05-2008, 08:43 AM   #3
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Sorry you had a bad experience.
It's about as hard as making a PB&J sandwich. Instead, spend the $250 on a set of performance springs, rent a spring compressor for the fronts, and have a full new set of springs. There are a thousand threads on chaning the springs on the forum. Do a search in the DIY section. You're sure to find everything you'll need.
Old 05-05-2008, 11:45 AM   #4
328iBMW
My Ride: C320
Both of my rear springs broke.
1.) Loosen the rear lugnuts
2.) Jack the car up in the rear by jacking on the subframe in teh middle near the diff.
3.) put jack stands on the rear stock jack pads.
4.) Remove jack and rear wheels.
5.) Release the parking brake. This will allow your axil to lower down.
6.) Remove the bolts on the bottom of the shocks.
7.) Your springs will fall out. If not, have a friend stand on the axil.
8.) Have a friend stand on the axil so that you can put new springs in.
9.) Put your car back together.
You can buy stock rear springs used for cheap from people on the forum that have them laying around. Go to the for sale section.
What makes you come alive?.........Go do it.
328iBMW is offline   Reply With Quote
Old 05-05-2008, 11:49 AM   #5
aggieE46
Keep it clean
aggieE46's Avatar
See... PB&J.
Old 05-05-2008, 01:49 PM   #6
Sam 330ci
My Ride: 03 530i 07 Sierra
Send a message via AIM to Sam 330ci
even if you have htem to it is a rip off
i got my 4 springs installed for $200 total.
dont pay that kinda money.
Sam 330ci is offline   Reply With Quote
Display Modes
