Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 05-05-2008, 08:00 PM   #1
acpstunts
My Ride: E46 330ci / E53 X5
Best way too remove pollen?
Is there anything out there to safely remove pollen from your car without scratching the car at all?
acpstunts is offline   Reply With Quote
Old 05-05-2008, 08:11 PM   #2
M0nk3y
Banned
My Ride: 2002 325xi
I would just hose it down with water. Wiping it off with a dry towel might scratch it......
Speaking of that. I washed my car yesterday to only find out after school that my car was covered with pollen.........
M0nk3y is offline   Reply With Quote
Old 05-05-2008, 08:35 PM   #3
jmay87
jmay87's Avatar
My Ride: e36,e46,e90
a bucket wash is the best way, but you can do small sections with quick detailer and a clean microfiber towel, whatever you do, its going to be covered again in a couple of days if not a couple of hours
--1995 E36 M3--2001 E46 325i--2008 E90 335i--
jmay87 is offline   Reply With Quote
Old 05-05-2008, 08:54 PM   #4
acpstunts
Yea :-/ Ive seen duster looking things at some auto stores. Are those a good idea or no?
Old 05-05-2008, 09:07 PM   #5
M0nk3y
Banned
My Ride: 2002 325xi
I don't like them, because it just traps the dirt and dust. Only to rub it back on the paint
Old 05-05-2008, 10:27 PM   #6
///McKinzie
My Ride: 1999 BMW Z3 2.3
Safest way is to just wash your car like someone above said. But I'm sure you were looking for a quick way...so, depending on how much pollen is on there, the Quick Detailer spray and a clean microfiber towel would be my suggestion.
1999 BMW Z3
w/ BMW M3 Chrome 17" Wheels
Currently has 306,000 miles
Detailed Image Auto Detailing Supplies
Maintained by Detailed Image
///McKinzie is offline   Reply With Quote
Old 05-05-2008, 10:35 PM   #7
derek80
My Ride: is optically clear
i'll wash it...
derek80 is offline   Reply With Quote
Old 05-05-2008, 11:07 PM   #8
Dunbar
My Ride: '04 330i ZHP 6MT
Wash it and then apply FK1 #425 quick detailer. It cuts down on 80-90% of dust/pollen attraction. Probably my favorite detailing product for my black E46.
http://www.fk1usa.com/products-consumer.htm
Dunbar is offline   Reply With Quote
Old 05-06-2008, 02:42 AM   #9
JJR4884
My Ride: BMW
if the car isn't dirty, i would say just rinse it and wipe it down with a big soft towel (definitely not terry cloth)
after that you should be good to go with a nice spray wax.......
thats what i would do......... or i would just put a tiny little bit a soap in a bucket and do a really quick wash........
i must say tho, the "california duster" does work wonders..... i don't have one but i have used it before, and it doesn't smutch pollen like a microfiber towel would.......... using a microfiber towel you can definitely feel the tiny surface scratches because pollen is so goddamn sticky
when i use the california duster on my black roof it will show if it really works or not
JJR4884 is offline   Reply With Quote
Old 05-06-2008, 02:58 AM   #10
04yfz
My Ride: A car
No matter how soft of a towel you use simply wiping will do more harm than good. Also just rinsing your car off will lead to water spots and potential water etching. The fastest safe and proper method would be to do an ONR wash. A car like an e46 can be washed in about 40-50 minutes with it, if not quicker. It's quick, easy, safe and relatively inexpensive. I actually use it as my primary wash method on my jet black car when the sun is out. Keeps me from having to fight water spots.
04yfz is offline   Reply With Quote
Old 05-06-2008, 03:03 AM   #11
04yfz
My Ride: A car
I also wouldn't recommend those dusters, anytime you are touch the pain you can potentially mar it, this increases greatly with such products as there is no lubrication when the pollen/dirt is rubbed against the paint.
[/CENTER]
Old 05-06-2008, 09:40 AM   #12
chris_bmw330ci
My Ride: 330ci
i'm seriously considering getting one of these:
http://crspotless.com/
i would use the filtered water this unit provides as my final rinse during a regular wash, filtered water means i can just let the car air dry w/o the worry of water spots - saves time and avoids scratching. but it can also be used to rinse off the pollen and other loose dirt - just rinse the car at night, stick it in the garage and have a non-pollen car in the morning.
there is a group buy over on the detailing bliss forum.
chris_bmw330ci is offline   Reply With Quote
Old 05-06-2008, 10:04 AM   #13
Custom3
My Ride: HellRot 330CI
if your car is cleaned and waxed then you can wipe off the pollen with a detail cloth....i have a cloth that shines and removes pollen as well...forgot whats its called...it has a picture of a camel and a 5 series on the front of it....works great...if your car is dirty and you have pollen and you want to wipe it off then i would recommend washing it....the dirt on the car can scratch the paint when trying to wipe the pollen off...but pollen being wiped off on a cleaned waxed car with a cloth would not scratch your car.
Old 05-06-2008, 10:07 AM   #14
Custom3
never seen that....but damn its kind of pricey...looks awesome though.
I know in home depot you can buy a filter for your entire house...you connect it from the main water pipe coming into the house...this way all the water in the house is filtered...toilet..sink...showers...etc etc...its awesome and cost alot less then that...but im not sure if will guarantee a spotless car wash
Old 05-06-2008, 10:10 AM   #15
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
just try to keep it indoors as much as possible and, when it gets to the point you have to clean it, do a full wash.... no sense scratching your car permanently to get rid of pollen temporarily
Timeless Motor Group
Old 05-06-2008, 04:37 PM   #16
jmay87
jmay87's Avatar
I wouldn't recommend just wiping your car with a dry cloth even if it is waxed, it can still leave scratches, if you are going to wipe it get a bottle of Quick Detailer
Old 05-06-2008, 04:52 PM   #17
///McKinzie
I have one of these, maybe not the same brand, but it looks identical just gray instead. I still dry my car with my microfiber towel, but any water that runs off from cracks will most likely not leave any spots.
1999 BMW Z3
Old 05-06-2008, 07:54 PM   #18
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
The CRSpotless system is an outstanding way to wash your vehicle safely when pollen builds up. It's filtered water that won't leave watermarks on the surface. Therefore you can rinse the vehicle off and walk away and you're all set. They are also great for washing windows. It's certainly not cheap but anyone who uses one will swear by the results. There is a wall mounted unit and one that comes with a set of wheels. If anyone has any questions about these units please let me know.
Greg @ Detailed Image
Old 05-13-2008, 08:57 PM   #19
Martin C.
My Ride: e90x; 91 318is
Living in the Evergreen State I know the complications of pollen. I hate swirling marks so I usually wash my car instead of using a 'dry' towel, no matter how much or how little pollen accumulates on the car. Spend the time and do it right.
Martin C. is offline   Reply With Quote
Old 05-15-2008, 07:47 PM   #20
Chris-TK
My Ride: Mk VI GTI
I use a California Duster in between car washes, it works really well. Helps me cut back on the frequency of all out car washes.
K.
Chris-TK is offline   Reply With Quote
