Thread Tools Search this Thread Rating: Thread Rating: 514 votes, 4.95 average.
Old 07-26-2011, 01:22 PM   #1021
luc
My Ride: '04 325i
Ok after some more research.. I found out my car wont get emissions tested. So im all good I think. Im overthinking it I think.. just need to stick them on there
Sent from my DROID2 GLOBAL using Bimmer App
2004 325i sedan
3 pedals, ZSP, ZPP | bimmerbrakes headers | shark injector | AFE filter / swiss cheese | 17" TRMotorsports C2 | H&R suspension | CF sunroof delete | custom short shifter | clear lights | CDV delete | DIY aux audio in | lots of random $5 mods
gamertag: babyDriver29
luc is offline   Reply With Quote
Old 07-26-2011, 03:57 PM   #1022
Mr_325
My Ride: 2007 X5 3.0Si
2 questions:
anyone buy from this ebay group yet? seems to have the best price for me in Canada.
http://cgi.ebay.ca/BMW-3-Series-E46-...item2c5e16b92f
anyone know what labour cost may be on the install for those of us who do not have lifts or welders (if needed)?
Mr_325 is offline   Reply With Quote
Old 07-29-2011, 10:49 PM   #1023
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Originally Posted by Mr_325 View Post
2 questions:
To bad those are 323/328 headers.
Depends on what need to be done will affect the price of the install. (500-1000). I have seen some fanatics has spent to get headers installed.
BimmerBrakes is offline   Reply With Quote
Old 07-29-2011, 11:22 PM   #1024
bwallace530
My Ride: 325
Its not worth it to have a shop do it. You can uninstall and install with basic hand tools there are no special tools needed just alot of time.
bwallace530 is offline   Reply With Quote
Old 07-30-2011, 12:53 AM   #1025
Mr_325
no welding involved?
Old 07-30-2011, 12:59 AM   #1026
GhostFlame
My Ride: E46 Sedan
Why would there be welding involved..
GhostFlame is offline   Reply With Quote
Old 07-30-2011, 02:06 AM   #1027
Andy2108
My Ride: SpecE46 & E46 M3
No welding is involved when swapping OEM headers for aftermarket.
De gustibus non est disputandum.
Old 07-30-2011, 02:05 PM   #1028
kpeng
Banned User
My Ride: E46 330 and E30 325
Welding? No.
kpeng is offline   Reply With Quote
Old 07-30-2011, 02:30 PM   #1029
bwallace530
My Ride: 325
Well I had to get mine welded but that was because I got the wrong ones and had know clue untill I pulled my old ones out. I had to modifie my flanges and extended them 4 inches. But you should not need to unless you get the wrong ones. Which I hope you do not.
Old 07-30-2011, 05:34 PM   #1030
Guest021715
Account closed.
Old 08-09-2011, 06:09 PM   #1031
scav'sBMW
My Ride: 99 323i
question
Me and my Dad are considering doing this to my car, hes the mechanically inclined one and had some questions, hoping you gurus can help us out
1. Will the precat sensors reach the ebay headers without an extension of some sort?
2. I plan on using the AA tune to get rid of the CEL so what would I do with the postcat sensors?
3. Do the studs to the head have to be replaced or do you need a different size for the ebay headers from stock?
Thanks fellas
scav'sBMW is offline   Reply With Quote
Old 08-09-2011, 06:15 PM   #1032
kpeng
Banned User
Thanks fellas
1. Yes, it will reach (sorry, I misread it the first time)
2. Re-install them onto the headers, there's 2 bungs on each one.
3. No need to replace.
Old 08-09-2011, 06:16 PM   #1033
Andy2108
yes
probably just don't install them in the car. This might be a question best answered by AA.
OEM studs, nut hardware, and gaskets work great. I bought all new hardware and gaskets just to be sure, but you can reuse the hardware but go ahead and buy new gaskets from the dealer. They're expensive but they work well...
Thanks fellas
Old 08-09-2011, 06:18 PM   #1034
Andy2108
Originally Posted by kpeng View Post
1. No
2. If the AA tune is set up to delete the post cat sensors then there is no reason to have them in the car.
I couldn't even fit my post cat sensors if I tried. Same story with my friend's 330i. We both used O2 simulators and relocated them.
Old 08-09-2011, 06:29 PM   #1035
kpeng
Banned User
Originally Posted by Andy2108 View Post
1.
I misread his 1st question the first time.
Old 08-09-2011, 06:32 PM   #1036
Andy2108
gotcha
Old 08-10-2011, 12:01 AM   #1037
Guest021715
Account closed.
yes
Thanks fellas
Would you happen to have part numbers for the OEM studs, nuts and gaskets?
Also, a bit off topic, but what is the consensus about the gaskets that come with BimmerBrakes headers, comparable to OEM quality, or should those be replaced as well?
Old 08-10-2011, 12:16 AM   #1038
Andy2108
2 x exhaust manifold to header gasket + heatshield (11621732969) - $41.92 each
2 x header to exhaust gasket (18301436334) - $12.63 each
16 x header nuts (11721437202) - $.78 each
16 header studs (11127506203) - $.38 each
2 x bolts and nuts for connection between header and exhaust - (11621427586 - bolts: 18301737774 - nuts) $.99 each - (Can substitute Grade 8, M10-40 bolts)
1 tube of red locktite - $3
Credit goes to MVRK
Old 08-10-2011, 12:28 AM   #1039
Guest021715
Account closed.
Credit goes to MVRK
exactly what I needed.
Are the BimmerBrakes gaskets good enough, or do I still need to purchase the OEM ones?
Old 08-10-2011, 12:42 AM   #1040
bwallace530
My Ride: 325
You want mine I never used them. I was too lazy and forgot to open the trunk and stick the ebay ones on.
I am selling them
Rate This Thread
