Thread Tools Search this Thread Rating: Thread Rating: 516 votes, 4.95 average.
Old 08-10-2012, 10:35 AM   #1201
bikeaddict
My Ride: e46 330ci
So figured I would add to this thread and update with my install experience. I bought ebay headers, link to seller a few posts above. Anyone looking for 325/330 headers, I can confirm that these are correct, and seller is good, with good communication.
Only one of the 02 bungs is useable, and I also had to cut off a few of the other bungs for more clearance. I have a welder at home so I re welded one of the 02 bungs to a better location. One header bolts up to the stock exhaust perfect, the other is about 1/4 inch too short. So I just used a spacer sorta, used an exhaust flange with a gasket on either side and it bolted up. Just got it up and running yesterday and sounds awesome.
The install is not bad at all. Did it at home on the ground, stock manifolds were off in about 1.5 hours, it was the fitting of the new headers that took all the time. Putting them on..marking stuff, taking off, modifying..........
If I was to do it again, I would buy a bit more expensive and perfect fitment headers, and probably will over the winter, but for cheap, with a little bit of time and work, these will do the job.
used a spacer like this
http://www.ebay.ca/itm/2-25-2-Bolt-U...item1e6b42f050
I also at the same time did the euro tune, so no check engine light.....
bikeaddict is offline   Reply With Quote
Old 08-10-2012, 10:48 AM   #1202
Wickedly
My Ride: 2016 BSM ///M2
Which one of all those 4 links you posted you bought it from?
http://www.ebay.ca/itm/STAINLESS-RAC...item27c71ba962
http://www.ebay.ca/itm/STAINLESS-STE...ht_3328wt_1344
http://www.ebay.ca/itm/STAINLESS-STE...ht_4009wt_1344
http://www.ebay.ca/itm/STAINLESS-STE...ht_3801wt_1344
And you care to explain how you do the Euro tune?
Wickedly is offline   Reply With Quote
Old 08-10-2012, 10:55 AM   #1203
bikeaddict
My Ride: e46 330ci
http://www.ebay.ca/itm/STAINLESS-STE...d=373849473593
i purchased these from kospeed.
and there are a ton of threads on doing the euro tune, not gonna clutter the ebay header thread with it.
Old 08-10-2012, 11:07 AM   #1204
Wickedly
Do you know what's the difference between the STAINLESS STEEL SS RACING MANIFOLD/HEADER 01-06 BMW E46/E39/Z4 M54B25/M54B30 and STAINLESS STEEL POLISH RACING MANIFOLD/HEADER 01-06 BMW E46/E39/Z4 M54B25/M54B30
seems like one of them is a SS racing and other is Polish racing.
Old 08-10-2012, 05:24 PM   #1205
Projekt330s
My Ride: 2004 BMW 330i
I picked up Wrecklessfool's old set. Ceramic coated & no adjustments needed to connect them to stock exhaust.( he had them bolted to highline tuning exhaust) I picked up new hardware and gaskets thanks to my buddies @ BMW in Peoria, IL. I found a shop and did the install for 160. I will be doing the 02 sim and relocation of post cat 02 sensors. (galanized box high temp painted red to match my sedan).
Projekt330s is offline   Reply With Quote
Old 08-12-2012, 02:13 PM   #1206
lrz14
My Ride: 2001 BMW 325ci
So I know this thread is a couple yrs old but any one Uknow from who to buy headers from on eBay that will fit a e46 325ci?
lrz14 is offline   Reply With Quote
Old 08-14-2012, 12:43 PM   #1207
bwallace530
My Ride: 325
Omg man read
bwallace530 is offline   Reply With Quote
Old 08-14-2012, 12:47 PM   #1208
Wickedly
Originally Posted by bwallace530 View Post
Omg man read
Old 08-14-2012, 12:57 PM   #1209
lrz14
I looked up the sellers he mentioned and they don't exist, do your homework.
Old 08-14-2012, 02:42 PM   #1210
bwallace530
My Ride: 325
Do my homework ok man! You can read back and you will see I have done my homework
Old 08-14-2012, 02:43 PM   #1211
Wickedly
will 325/330 headers also fit 325ci?
Old 08-14-2012, 02:44 PM   #1212
bwallace530
My Ride: 325
Yes
Old 08-14-2012, 02:50 PM   #1213
Wickedly
I was about a second to buy an ebay header
Either
http://www.ebay.ca/itm/STAINLESS-STE...ht_4047wt_1344
Or
But I just saw this
http://forum.e46fanatics.com/showthread.php?t=926232
And I prefer to wait for a perfect fitment and better quality.
Old 08-14-2012, 03:25 PM   #1214
Guest021715
Account closed.
Nobody purchased them yet, how do you know they're perfect fitment?
My BimmerBrake headers had plenty of issues. Nothing is perfect with aftermarket parts.
At least if something is wrong with those you can yell at Anthony, unlike ebay.
Old 08-14-2012, 03:29 PM   #1215
Wickedly
exactly. Atleast You can always try to negotiate one way or another with Anthony unlike ebay which once you purchase and it doesn't fit very well you kinda screw. They won't take their product back and just to reach them could be a lifetime. And yes you are right maybe not 100% perfect.
Old 08-14-2012, 10:17 PM   #1216
phubar
My Ride: 335is, HD
I just installed a set of ebay headers. NEVER AGAIN... generally the install sucked because of my gorilla hands and the lack of room, but still NEVER AGAIN!
PS: for a few hours there it seemed like it wasnt gonna work, rubbing against each other, firewall, motor mount, etc... the mid pipe flanges on the header did not line-up perfectly (about 1/8" difference) but the magnaflow exhaust is a little bendy so it works for now, no leaks so far (knock on wood). I dont know that a different set of headers would have made a difference, its just so tight in that area and no room to manuever, even after taking the motor mount off.
phubar is offline   Reply With Quote
Old 09-13-2012, 09:00 PM   #1217
King Kashi
My Ride: 06 BMW 330Ci M54 Eur
My mechanic is telling me after the eBay headers, I'll be getting a check engine light ? Is there a way to prevent that ???
King Kashi is offline   Reply With Quote
Old 09-14-2012, 10:18 AM   #1218
Steven747
My Ride: 05 330ci
Is it that difficult to use the search function which will give you 3,000+ answers to your exact question?
Ugh
Old 09-14-2012, 10:55 AM   #1219
Guest021715
Account closed.
Because I'm bored at work, I'll answer instead of yelling at you.
1) EU2 tune - works 100%, never another emissions related CEL
2) O2 sims - usually work, but messy and a hackjob in general
3) Spark plug non foulers - don't work at all.
Old 09-16-2012, 09:25 PM   #1220
Rafaelflopez
My Ride: E46 323i 1999
I like to post for the people i put the header i buy in ebay and fit good but the only problem its the spark defueler i cant not put because the space its to short and my check engene go on i like to now where i cant buy the o2 sims because i look in the web but not have the item to buy please let me where thanks.
Rafaelflopez is offline   Reply With Quote
Rate This Thread
