Old 05-06-2008, 12:54 PM   #1
myksbmw
My Ride: BMW 2003 325i
Xenon Light wont come on
I am experiencing a driver side xenon light out. This is extremely frustrating because I just replaced the ignitor and now a month later it is not working? Could it be the Ballast? Or is the blub burned out? Any way to tell what the problem is? Thanks for your input.
myksbmw is offline   Reply With Quote
Old 05-06-2008, 01:03 PM   #2
weisiong123
My Ride: 323ci
Switch ballast to see if the problem carries to the other side?
weisiong123 is offline   Reply With Quote
Old 05-06-2008, 01:11 PM   #3
myksbmw
Great Idea! Thanks
Old 05-06-2008, 01:13 PM   #4
weisiong123
My Ride: 323ci
That way you can see if its the ballast or at least which side is faulty. Try that 1st, if it doesn't work let us know.
Old 05-07-2008, 10:08 PM   #5
Jabboure36
My Ride: 03 540i/6
Send a message via AIM to Jabboure36
or switch the bulb to the other side too just in case it may not be the ballast...i just fixed my ballast today after a year of it being gone!
Jabboure36 is offline   Reply With Quote
Old 05-08-2008, 12:17 AM   #6
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Yep, better to start with the bulb.
Old 05-10-2008, 08:31 PM   #7
myksbmw
Ok, I switched bulbs, it is not the bulb. However it is the ballast. I have hear that some people have switched to an aftermarket HID system. Anyone know how this is done? thanks
Old 05-11-2008, 10:55 AM   #8
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
It's best to just get an OEM replacement, not all aftermarket HID kits will be a direct swap on an OEM setup.
