Old 05-07-2008, 02:20 PM   #1
Miko_10
My Ride: 330i 5 Spd
Trunk lights on driver side won't work
I tried to do a search but no luck so here it goes. I have no dash indicators saying that my bulb is out and didnt even realize it until a friend mentioned it to me. I was thinking it was gonna be an easy fix, change the bulb and done but it didn't work out that way. I looked at the bulb carrier and it had a little rust so i scrape off the rust and try put the bulb in, still nothing. I checked the fuse, its good. so now im a little lost. it's either the bulb carrier or the wirring that goes through the car. I figure i'd give e46 a shot..thanx in advance
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 05-08-2008, 03:43 PM   #2
sillieidiot
My Ride: '06 AW 330ci
probably the carrier, did you try pulling the prong at the bottom of the bulb up?
Old 05-08-2008, 09:15 PM   #3
Miko_10
My Ride: 330i 5 Spd
yeah tried that, just ordered the carrier hopefully that's it. thanx
Old 05-09-2008, 04:12 AM   #4
sillieidiot
you could probably have tested the carrier before ordering. just unplug it and plug it into the other side. if all the bulbs light up, it's not the carrier.
Old 05-09-2008, 10:04 AM   #5
Miko_10
My Ride: 330i 5 Spd
yeah tried that too and neither one lit up, if it's not the carrier i'm guessing i'll have to trace the wiring, which I don't want to do. thanx
Old 05-13-2008, 08:35 PM   #6
Miko_10
My Ride: 330i 5 Spd
just installed a new carrier and a new bulb and still nothing.....great!!!!
