Old 05-08-2008, 04:44 PM   #1
wack0
My Ride: M3, ZHP
Foglights and noise from fuse box
I noticed that whenever my fogs are on (OEM, came with car) I hear a little "zzzt zzzt" noise coming from the fuse box area. The lights dont flicker or anything so i'm not sure what's going on.
The only thing that has changed is that i've changed out my turn signal bulbs with sylvania silverstars. could they be screwing something up when the fogs are on?
wack0 is offline   Reply With Quote
Old 05-09-2008, 04:17 AM   #2
sillieidiot
My Ride: '06 AW 330ci
it's probably the fog light relay that you're hearing.
Old 05-10-2008, 10:13 AM   #3
wack0
My Ride: M3, ZHP
is that something i should replace?
Old 05-11-2008, 03:43 PM   #4
sillieidiot
you might need to. but you should check it out to make sure. have a friend turn on/off your fogs while you stick your head in the fusebox area to try to pinpoint the noise. or you can just go ahead and replace the relay. it's a relatively inexpensive product to replace.
