#21 | |
There I was, Sicily, 1918..
#22 |
total coincidence that i found this forum.. i had that light show up on my dash today for the first time also shut the car off and turned it back on and it disapeared.. i find it odd it turned on being that at 73k miles i got a new tranny under my extended warranty and now have 75k. Hope i dont see that damn light again!!
ps steptronic fanatic!! lol
2002 325ci Roadster!! |
#23 |
my voltage regulator fault also trigger the transmission error light and the car went into limp mode
#24 |
Has your car overheated previouslly, I would start by checking fluid, level and condition ??
#25 | |
Regional Sponsor
My Ride: 2000 E46 with 254K
http://forum.e46fanatics.com/showthr...ighlight=radio
Seth Thorson Service Manager/BMW Tech JB Eurotech Service "Your Reasonable Dealer Alternative" General Questions can be sent to appointment@jbeurotech.com 1. Do not argue with an idiot. He will drag you down to his level and beat you with experience. 2. Light travels faster than sound. This is why some people appear bright until you hear them speak. Last edited by jbeurotech; 04-16-2009 at 08:03 AM. |
#26 | |
Regional Sponsor
![]() SI B 24 04 06 September 2006 Automatic Transmission Technical Service This Service Information bulletin supersedes S.I. B24 04 06 dated September 2006. [NEW] designates changes to this revision SUBJECT ZF 5HP19 - Diagnosis of EGS FC 059 & 065 MODEL [NEW] E46: 325i, 330i with M54, M56 and ZF 5HP19 up to 04/2004 E39: 525i, 530i with M54 and ZF 5HP19 E85: Z4 with M54 and ZF 5HP19 up to 04/2004 SITUATION Transmission warning light is illuminated and transmission enters fail-safe mode. Fault codes FC 059 (3B) "Stall speed plausibility", and/or FC 065 (41) "Gear monitoring 4, limp-home program" are stored in the EGS control module. Also, the following ambient conditions are stored in EGS for the gear monitoring faults 065, or 059: l - "Throttle valve angle 0%", - "Battery voltage 0 V ". IMPORTANT NOTE: If any other fault codes are stored in the EGS control unit in conjunction with FC 059 and/or 065, then contact BMW Technical Hotline/Drivetrain (via PuMA) for further assistance. CAUSE Possible causes: electromagnetic interference or voltage fluctuation in vehicle's electrical system affecting the transmission turbine speed signal. Non-approved aftermarket electrical equipment, or loose/corroded connections in the electrical system are the main reasons for the electromagnetical interference. PROCEDURE 1. NEW Inspect vehicle for presence of various, non-approved aftermarket electrical equipment. If such an equipment is installed, contact a customer and with his/her permission disconnect it (remove it) from the vehicle. 2. NEW In case a customer does not wish to remove aftermarket equipment which may be causing an electromagnetic interference, provide him/her with an option of installing a special EGS control module (step 5 of this procedure). This repair and diagnostic time would NOT be covered by BMW warranties (customer pays for parts and labor). 3. In case aftermarket equipment is not found, then inspect connections and repair if needed at: - Battery terminals, - Battery ground connection, - Ground/B+ splices/connection in engine and body harness, - Ground connection at the ignition secondary windings, etc. 4. Using DIS/GT1 check the DME fault memory to determine if there is any fault in the primary or secondary ignition. Correct if needed. 5. In case, no problem can be found in the vehicle's electrical or ignition systems, then install the improved EGS control module (PN 24 60 7 548 312) fitted with interference suppression capacitor. The improved control module can be recognized by the index number "002", or higher, printed on the white, Bosch label below the second bar code. Currently, all EGS control modules available for BMW PDCs are equipped with the interference suppression system. 6. Program and code the basic EGS control module.
Seth Thorson Service Manager/BMW Tech JB Eurotech Service "Your Reasonable Dealer Alternative" General Questions can be sent to appointment@jbeurotech.com 1. Do not argue with an idiot. He will drag you down to his level and beat you with experience. 2. Light travels faster than sound. This is why some people appear bright until you hear them speak. |
#27 | |
Regional Sponsor
Really techs are very highly trained and do have some knowledge of what hey are talking about and are not out there to rip you off. Heck they could have just said they tranny was done instead they are trying to look for the cheapest fix which happens to be to try the factory radio
#28 |
Regional Sponsor
Any updates
#29 |
my comes on and off all the time, but my car isnt running any differently and shifts fine from first to second to third to fourth and to fifth. whats going on?
#30 |
Banned
i have the same situation going on with my car, can it be the HID system that i have connected on the vehicle. it is a 99 323i. i have the low beams as well as the fogs with out the warning canceller. i never got the error to show up on my cluster, so i let it be. but then the other day i drove the car and all of a sudden the (!) sign shows up on every gear of the car. i followed the manauls procedure to eliminate the sign, but nothing, it still remains on the cluster.
#31 |
Just had this happen to me today too. :wtf
apparently its a "Transmission failsafe"
-Brandon
![]() 239whp/227wtq @2700lbs |
#32 |
Happen to me too buddy. Paid $5k for reco transmission unit. Drove it around for a few weeks and it came back on and now BMW is blaming it on my aftermarket mod. Wish they had checked that first, i told em that and they say its a different fault code heh.
Anyways they said to fix it again will be 3.5k for a transmission control unit. **** me...dunno what to do. |
#33 |
I just changed the starter and now I am getting that light... I assume i probably rattled some sensor or whatever... how do you clear it?
#34 | |
ima touching member
Location: tree fort in big oak on corner somewhere in ny
My Ride: 04 330i jet black
#35 | |
How old is your battery? maybe. . . low voltage problem.
#36 |
Many can cause that issue. In my case, bad MAF caused it many times.
But that light is like 'Service Engine Soon.' You'll never know what's really wrong until you scan the tranny DTC. If you connect OBD2 scanner, you can scan transmission ECU. It'll give you better idea what's going on. At least my scanner can access to tranny ECU..
#37 |
///Motorcepts ///Maintained
Had similar problem about a month ago... took it to Leo @ Motorcepts and found out the auto gear selector module connector was not making good contact... he cleaned the contacts, plugged it back up and I was good to go.
TRANSFORMATION LINK http://www.youtube.com/watch?v=VmDFUtpcWhQ TRANSFORMATION LINK II http://www.youtube.com/watch?v=OxP2aDrXJk8 TRANSFORMATION LINK III http://www.youtube.com/watch?v=TcQm1dekGNE&feature=plcp Exhaust Note http://www.youtube.com/watch?v=fKfRe_c1l1w |
#38 |
Here is what happen to me yesterday. My transmission light came on in red, the car started to behave as if the wants to stall when i'm coming to a stop, then the transmission changes out with a kick. I parked the car for the rest of the day, this morning i start the car and the light is off, haven't driven it yet to see if the symtoms still exist. I did a voltage test and the battery is fine, i have'nt install any after market stuff. Only i replaced about a month ago was my MAF sensor which is dealer baught. I'm going to have a scan done to see what codes are showing.
#39 |
I drove the car a short while ago, car drives perfect and no more codes. I think i can safely rule out a defective tranny. I'm going to get a scan later, and i will not drive the car until this is done. I'm think that the tranny sensor might be the culprit. Thanks for the useful info on this site. The key to owning a BMW and paying a arm and a leg for repairs, is to have the ability to troubleshoot effectively.
#40 | |
Do you happen to see the repair? where is the auto gear selector module connector located? More research for me. My wife's 328i had the transmission light on randomly. It'll go off once the car is shut down.
