Old 05-11-2008, 12:49 AM   #1
Genuine
Banned
My Ride: 00 323i 4Dr
Question Relay Wiring ? ---- I've searched and searched....
and pretty much just want a couple more options and/or opinions if there are any.
Pics help best as well as detailed instructions. Thanks in advanced.
I've done so much research only because I want to wire my fogs, Angel Eyes, and do the corner delete mod all at once. Getting car back from repainting the hood and spraying my new bumper tomorrow.
My plan is to have the
Angel Eye's - fade in / fade out with lock/unlocking. (footwell light tap-in?)
Angel Eye's - stay ON while headlights are OFF
Front Turn Signals - are OFF when LCM is in parking or headlight on position
Front TUrn Signals - still flash on/off when signal lever is in use
Any way this can be done? If so, can someone show me the relay wiring diagram to accomplish this? I'd rather not use diodes...I have plenty of 5 spdt relays.
Genuine is offline   Reply With Quote
Old 07-07-2008, 10:33 PM   #2
black323i1981
My Ride: 2000 BMW 323i Sedan
Send a message via MSN to black323i1981
i would like to know this too at least you have the same idea as me
2000 BMW 323I
Cold air intake
Optima red top
18" chromes
P46 with 6000k HID and 30 led angels (pictures coming soon)
6000k HID Fogs
Magnaflow exhaust 2nd resonator delete
Poly bushings all around
Cold air intake
Sport seats
Sport suspension
JVC KD-NX5000 DVD GPS single din
7" screen replaced sunglass holder and ashtray
12" Rockford P3
Eclipse 7122 mono class D amp
black323i1981 is offline   Reply With Quote
Old 07-07-2008, 10:40 PM   #3
sillieidiot
My Ride: '06 AW 330ci
for the angel eyes, footwell tap and ecu tap will do the trick (basically any normal relay harness). for the corner del, just do the corner del and you're done. no need for a relay, nor will it help much.
Old 07-08-2008, 12:54 PM   #4
mosill
My Ride: E46 M3
Send a message via AIM to mosill
Like sillieidiot said.
You can also use this thread http://forum.e46fanatics.com/showthread.php?t=430839
post #13 for the relay wiring for the angel eyes
mosill is offline   Reply With Quote
