Old 05-11-2008, 12:22 PM   #1
VillanovaGrad
My Ride: M3 M5 X3
How to reset the Inspection reminder after I did DIY ?
So a friend and I did the inspection II ourselves on my car (2001) and i want to reset the inspection reminder (500 miles left)...
I tried the regular method but it didnt work this is what i did...
key in position 0, press left button on the cluster and hold it, key in position 1, release button, when reset comes on, release, then reset flashes and goes away.
But the inspection ticker is still there...
X_X
VillanovaGrad is offline   Reply With Quote
Old 05-11-2008, 12:28 PM   #2
freerider
My Ride: 03 320i, 98 328i ind
you have to hold the button down until reset shows... about 10seconds
freerider is offline   Reply With Quote
Old 05-11-2008, 12:38 PM   #3
VillanovaGrad
My Ride: M3 M5 X3
yeah then it flashes and goes away
but it still doesnt reset the counter...
Old 05-11-2008, 04:12 PM   #4
JSanders
My Ride: Breaks too often
What does this do then? Just make the ticker go away temporarily?
JSanders is offline   Reply With Quote
Old 05-12-2008, 02:39 PM   #5
VillanovaGrad
My Ride: M3 M5 X3
bump
Old 05-12-2008, 02:42 PM   #6
SeanC
My Ride: 330i
this should also work for the "inspection":
RESETTING OIL SERVICE INDICATOR:
If your OBC needs to be reset after completing your oil change, there are two ways. NOTE: If you miss a step, just turn the key back off and try again:
A. Model Year 1999 to Mid-2000: You should have the older round 20-pin DLC connector under your hood behind the battery terminal, you need to use a small length of wire to connect (short) pins 7 and 19 for 3-5 seconds with the ignition key in position 1 (Accessory).
B. After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 05-12-2008, 04:04 PM   #7
VillanovaGrad
My Ride: M3 M5 X3
mmm ok... ill try this...
Old 05-12-2008, 04:53 PM   #8
sdbimmer
My Ride: 2004 325Ci
http://www.kneb.net/bmw/E46/Service%20light%20reset.pdf
sdbimmer is offline   Reply With Quote
Old 05-12-2008, 07:22 PM   #9
VillanovaGrad
My Ride: M3 M5 X3
the method i tried above works...
Old 05-25-2008, 05:21 PM   #10
sanyomats
My Ride: 00 328CI
cngzsn - worked like a charm on my 00(9/99 made) 328!!!
Thanks!!
sanyomats is offline   Reply With Quote
Old 05-25-2008, 06:57 PM   #11
JB707
My Ride: 2001 DINAN 330 CI
also...as stated in my bentley man..u have to drive for at least 50 miles...which isnt really true becuase that would mean the dealer is takin ur car for a drive everytime it gets an oil change or what not...so yea..just tellin ya what my manual says
DINAN:COLD AIR INTAKE, THROTTLE BODY, STAGE 3 CHIP, FREE FLOW EXHAUST
BB PERF HEADERS // RESONATOR DELETE // EE LED TAILS // M3 LIP SPOILER // DICE IPOD INTEGRATION // DIY FRONT REFLECTORS // UMNITZA ORION V2 ANGEL EYES // KONI YELLOW SPORT // H&R RACE SPRINGS // ROGUE RSM's // POWERFLEX FCAB // CLEAR FRONT SIGNALS // CLEAR SIDEMARKERS // LED FRONT SIGNAL BULBS // LED SIDEMARKERS
JB707 is offline   Reply With Quote
Old 05-25-2008, 10:30 PM   #12
SeanC
My Ride: 330i
Thanks!!
np
Old 10-02-2008, 07:27 PM   #13
Define ///M3
My Ride: E92
i have a 2000 323ci and i think mine might have been made mid 1999 or something cause it isnt working for me, when i hold it in it comes up " test" not reset....anyone help me out?
Define M3
tiag 2000 323ci - sold
BSM 2004 325ci - sold
AW 2013 328i - sold
MWM 2012 e92 328i - current
Looking 4 e46 M3
Define ///M3 is offline   Reply With Quote
Old 10-03-2008, 01:36 AM   #14
Chris-TK
My Ride: Mk VI GTI
You need to keep holding
--The car should be off
--hold down the left instrument button (the trip odometer reset)
--while holding the key, turn the ignition to position 1 (radio)
--you will see a test menu
--keep holding the button
--after maybe 10 seconds, the word "reset" will appear
--let go of the button and press again
--The indicator is reset!"
K.
Chris-TK is offline   Reply With Quote
Old 10-03-2008, 01:42 AM   #15
Breyton-BMW
Breyton-BMW's Avatar
My Ride: Ti
Send a message via AIM to Breyton-BMW Send a message via Yahoo to Breyton-BMW
Your car is a 2000 model. If you have the 20 pin connector, you have to go with option A of Czgsn's post above. Option B will not work.
Breyton-BMW is offline   Reply With Quote
Old 10-03-2008, 08:46 AM   #16
plmskier
My Ride: 2002 325XI
I had that problem too, I followed directions but nothing changed. I brought it to the dealor, showed them what I was doing...the service manager told me the same thing, it didn't work, then a tech came out and did the same steps but when it says reset and your holding the button down, he pushed the button 2 times and then it reset. I was like are you kidding me...! So long story short, follow same directinos then push the button in a few times and it will reset...def a pain.
plmskier is offline   Reply With Quote
Old 10-03-2008, 09:22 AM   #17
beingdevious
Apple Jews
beingdevious's Avatar
Location: Drunk onthe Beach.. Official 4ngiefest.com Techie Go to: 4ngiefest.com/donate Needs: to leave the computer Status: ///Pantless
My Ride: 2001 325i Sedan
Send a message via AIM to beingdevious
OMG thank you
ive been trying to get that damn inspection warning off for 8800 miles now
drove me nuts.
[IMG]http://************/ogaeq6[/IMG]
Question for you:
Are boobs and hands polarly charged, thus causing the inevitable joining of the two? If so are some breasts simply charged backwards?
On a scale from 0 to 24...wait, 3 to 24, where 6 is the lowest and 12 is the highest, how freaking high re you right now?
She's got you high, and you don't even know yet.
beingdevious is offline   Reply With Quote
Old 10-03-2008, 11:09 AM   #18
nathancarter
My Ride: 02 330i
It took me a few tries to get it right at my last Inspection (90k). I think I bungled something, because it also changed my trip odometer from 230ish miles to 660 miles. I was mildly annoyed because I couldn't calculate my fuel economy for that tank.
nathancarter is offline   Reply With Quote
Old 10-03-2008, 12:52 PM   #19
tony325ci_51
My Ride: BMW 335i 2007 Coupe
I believe the "service indicator light reset tool" sold for 323/328's just does what is mentioned in method A.
Later 325/330s which don't have a round 20-pin connector certainly just reset by pushing buttons on the dash as in method B.
tony325ci_51 is offline   Reply With Quote
Old 10-27-2008, 04:14 PM   #20
Megalocnus
My Ride: 05 330i ZHP/MT
inspection / oil change
I have a '99 323i with 20-pin DLP under the hood. After changing the oil I wanted to reset the oil service indicator, shortcutting pins 7 and 19 while the key was in position two. Apparently I connected the pins for too long (perhaps for five seconds, but not longer than that). Now I get "inspection 15500 miles" displayed on the cluster instead of "oil change" when I turn the key to position one.
Does anybody know how to clear the inspection indication and activate the oil service again? Thanks.
Edit: OK, apparently that was a stupid question. The service intervals are preset according to the mileage/spent fuel and one can't choose which one comes next.
Megalocnus is offline   Reply With Quote
