Thread Tools Search this Thread Rating: Thread Rating: 318 votes, 5.00 average. Display Modes
Old 08-04-2011, 01:53 PM   #221
\\V
My Ride: 2002 AW 330ci
Originally Posted by Wickedly View Post
Pics of the installation dont show anymore..someone update to new pics...this thread was made on 2008. Thanks
Check post #15 on the first page.
Here's a direct link --> http://forum.e46fanatics.com/showpos...1&postcount=15
\\V is offline   Reply With Quote
Old 08-04-2011, 03:02 PM   #222
bignickmetro
My Ride: 2002 330ci TiAg
just wanted to chime in, I did headers on my 330 last weekend (as well as rotors, pads, SS lines, was a lot of work in one weekend).
The DIY is pretty much bang on. About half of my studs backed out, it wasn't bad though, you can reach all but 2 or 3 of the nuts from the top with just a 3in extension. You WILL have to remove the motor mount and jack the engine up to get the front manifold out, we tried to avoid this and after 2 hours of banging/prying the hell out of everything we decided we had to do it.
The rear manifold comes out first, you can wiggle it it out before you jack the engine up. The rear header has to go in first. Loosen exhaust hangers and scoot the exhaust back a little.
I completely removed the SAP, with a block off plate from ECS. So glad its gone I hated that noise. I also removed my rear O2 sensors completely, since they are pointless.
You don't have to remove the engine covers unless you plan on unplugging the rear O2 sensors.
This was really really hard, but not complex or anything. Just exhausting (lol).
bignickmetro is offline   Reply With Quote
Old 08-04-2011, 04:49 PM   #223
bwallace530
My Ride: 325
How much was the sap block off plate and I didn't no you could just remove the rear o2s. How do remove them?
Sent from my PC36100 using Bimmer App
bwallace530 is offline   Reply With Quote
Old 08-04-2011, 05:21 PM   #224
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
the block off plate was 6 bucks from ECS for me. PN 11 12 1 438 086.
and the 02 sensors can be disconnected underneath the engine cover directly in the middle of the engine. There are two detachable harnesses just sitting there.
drumbum624 is online now   Reply With Quote
Old 08-04-2011, 09:05 PM   #225
bwallace530
My Ride: 325
Thanks cheaper then the oem part
Old 09-05-2011, 05:48 PM   #226
miketblack
My Ride: 2003 BMW 525i
hello guys. first post here.
i have a 2003 525i E39 with the 2.5L m54 engine. ive searched all over google and the rest of the interweb and this is by far the best and most informative write up for DIY headers. infact if i search e39 headers diy, this page comes up everytime.
heres my million dollar questions;
1. will my procedure for the 525i be the same as the 3 series cars? im guessing so, just that my 525 is a tad bigger of a car
2. will the answer to number 1 result in having more room to move around and work?
3. is there anything that is 5 series specific that i should know of?
thanks and have a great day.
mike
miketblack is offline   Reply With Quote
Old 09-06-2011, 12:17 PM   #227
luc
My Ride: '04 325i
installed bimmerbrakes headers yesterday. perfect fit! o2 sensors have plenty of room and flanges matched up with the back of the exhaust with no problem. If you're doing headers, spend the extra and go with guarenteed fitment (bimmerbrakes, stett, etc.), don't gamble with ebay.
i did the install without removing the motor mount too! i was pretty nervous about removing it so i wanted to avoid that if i could. the hardest part was taking out the stock ones.. after that everything went really fast. headers went in 100 times easier than stock ones came out. i installed the precat o2 sensors in the postcat holes. i hope that turns out to be ok. it just worked better that way. Total install time was about 10 hours
my thoughts/notes on install.
-let ceramic coating sit for a week or so before trying to install. if you install soon after painting them it will all scratch off. Let it cook per instructions on the can as well.
-subframe brace torque - 43 ft lb
-header nut torque - 25 ft lb (if you can get a torque wrench in there, if not just guess)
-get one of these.. worth its weight in gold: http://www.amazon.com/Stanley-89-962.../dp/B000HEKV1W
-drop the entire rear exhaust before completely removing stock manifolds
-unbolt both stock manifolds but remove the rear first, it comes out easier and will let you wiggle the front one out.
-install front header first, then rear. dont completely bolt either down until both are in to give yourself wiggle room.
-do not do this by yourself. it will be completely impossible (if youve done this by yourself, respect. theres no way i could have). i had 2 knowledgeable guys helping me.
-ill add more if i think of any
pictures and video soon
Sent from my DROID2 GLOBAL using Bimmer App
2004 325i sedan
3 pedals, ZSP, ZPP | bimmerbrakes headers | shark injector | AFE filter / swiss cheese | 17" TRMotorsports C2 | H&R suspension | CF sunroof delete | custom short shifter | clear lights | CDV delete | DIY aux audio in | lots of random $5 mods
gamertag: babyDriver29
luc is offline   Reply With Quote
Old 09-06-2011, 01:14 PM   #228
vi
My Ride: '01 320i
What do you guys suggest for seized up spark plugs??
vi is offline   Reply With Quote
Old 09-06-2011, 05:06 PM   #229
bwallace530
My Ride: 325
Why are you messing with the spark plugs when installing headers?
Old 09-09-2011, 08:00 AM   #230
PRDesignsTony
My Ride: 02 330ci
going to try to do this install in a few months. Im hearing a lot of fitment issues kinda scaring me cause i really dnt want to take it to a muffler shop and dnt want my sensors off. I know a few headers on ebay are like $80 but i hear trader-nas is a very trustworthy seller and his fit good. He sell them for bout $200, has anyone purchased from him and run into fitment issues? Also i know some of you dropped your exhaust, does it really help fitting it on?
PRDesignsTony is offline   Reply With Quote
Old 09-17-2011, 10:55 PM   #231
redlin'r
My Ride: (E46) 330Ci
Ok I need some help! I spent ~3hrs removing all the bolts from the header to block connection, no problem, then I went to remove the mid pipe and header nuts and they are rusted solid! What should I do?
My only options are to cut the stock header pipes or cut the bolts. I am thinking of cutting the pipes and then taking the mid pipe and grinding the bolts off....
Anyone else have this problem?
redlin'r is offline   Reply With Quote
Old 09-17-2011, 11:27 PM   #232
bwallace530
My Ride: 325
PB blaster and let it sit. Or cut them off and do what you need to do to get them off. Mine where kinda rusted but not bad I used PB blaster and they came off not easy but they came off. You also need to have some type of breaker bar maybe a think pipe that can fit over the wrench and just pull pull and pull till it comes off thats what I did.
Old 09-17-2011, 11:38 PM   #233
redlin'r
I sprayed them and am letting them sit over night. If the breaker bar doesn't work I will cut.
Sent from my ADR6300 using Bimmer
Old 09-17-2011, 11:41 PM   #234
bwallace530
My Ride: 325
Good let us know if it works you can add another story to help out others that try
Old 09-18-2011, 09:04 PM   #235
redlin'r
Ok progress was made today. Here is what I have done so far:
1.) removed air cleaner
2.) Removed washer fluid res.
3.) Removed rear exhaust section
- Side note, I let the 4 bolts sit over night with pb blast and I managed to get all but one which stripped. Unfortunetly I had to use my angle grinder and grind it off.
4.) Removed all bolts to the front most manifold.
5.) At this point I needed to remove the engine mount to all me to get the front most manifold out. This was a HUGE help because this allowed me to remove the manifold no problem, but also to jack up the motor and "easily" get access to all the bolts for the second manifold.
Right now everything is out and I just need to get another gasket( I thought I ordered 2, FAIL). This DIY was spot on! I just hope everything lines up when I put it back together. I bought Bimmerbrakes headers which are 100% fitment...we shall see.
Does anyone have a part number for the studs? I would like to replace all the ones that came out with new studs.....
Old 09-18-2011, 11:18 PM   #236
bwallace530
My Ride: 325
Replace all the studs. There's no point in just replacing a few you should replace all of them. I think somewhere in this thread there is part numbers for the studs. Do a search in this thread I am pretty sure its in this huge thread LOL. If not just go to the dealer and ask them.
Good luck
Old 09-19-2011, 08:11 PM   #237
redlin'r
Tonight I finalized my order for parts and did a test fit to make sure everything will squeeze in. Here are my list of parts for anyone who needs references:
1.) Block studs- ES#18454 ~$0.72/ea
2.) GASKET W/HEAT SHIELD ES#26135: ~$29/ea
Here are pics of the mock up... (bimmerbrakes headers)
1.) the bottom o2 sensors cross but have room! Thank GOD!
2.) headers line up PERFECT to the mid pipe.
3.) A little surprise, I painted the rear exhaust with header paint and there is no muffler, so this will be a no muffler or 2nd resonator set-up. I can't wait to fire it up.....
Its just a waiting game until I get my parts so I thought a mock-up wouldn't hurt. I decided to get new tie-rods since the car was in the air to complete the front overhaul.
Now I just need to figure out how to connect the o2 simulator.
ID:	417619   Click image for larger version
ID:	417620   Click image for larger version
ID:	417621   Click image for larger version
Old 09-19-2011, 08:47 PM   #238
redlin'r
Question....
How did everyone install the o2 sim? I don't want to re-locate my post cat bungs and didn't get instructions with my sim from bimmer brakes.
Another question, do you need to have 02 harness extensions for pre-cat bungs?
Old 09-19-2011, 09:06 PM   #239
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Question....
No, extension is needed. Just unclip the harness on the back of the motor (clip onto the Valve Cover).
BimmerBrakes is offline   Reply With Quote
Old 09-21-2011, 10:48 PM   #240
redlin'r
Got them installed! Great fitment and fairly easy to tackle. I still have to do the o2 sim.
I have no muffler or second resonator and boy is it loud. Seems to be running rich as it pops a lot on declaration.
I went for a test drive and I had the car turn off and throw a ses after going to redline then neutral...normal? I am thinking this will go away after o2 sim.
