Old 05-13-2002, 08:33 AM   #1
330-fitz
My Ride: 330I
Stereo Help - Amplifier Wiring diagram
I am adding an amp and sub to my 2001 330i w/ HK. I keep reading conflicting info on the wiring diagram that I need to tap into. What wire do I use for the remote turn on and what do I need to tap into for the speaker level inputs? Do line level converters make a difference even if my amp has speaker level inputs?
Thanks in advance.
330-fitz is offline   Reply With Quote
Old 05-13-2002, 09:14 AM   #2
Clem
Alpha Male
Clem's Avatar
My Ride: Twin Turbo'd Beast
From the FAQ
Clem is offline   Reply With Quote
Old 05-13-2002, 12:05 PM   #3
330-fitz
My Ride: 330I
Thanks. I had the remote power correct and it didn't power on. I'm a mechanical engineer so I'm not sure if I could do the mods you described. What do I need to do to get the remote to power it on, minus putting a switch in the cabin of the car?
Old 05-13-2002, 12:08 PM   #4
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
You're probably using the wrong remote wire...
You CANNOT use the white wire from the HK-subwoofer amp...it's only 9.6v. You MUST use the with wire from the HK-main amp located behind the trunk carpet on the driver side. Many make the mistake of using the sub amp remote to turn on an aftermarket amp...just not enough voltage.
vinnymac is offline   Reply With Quote
Old 05-13-2002, 12:35 PM   #5
330-fitz
My Ride: 330I
I was using the white wire for pin # 10 going into the amp. Where is the white wire that you are referring to routed? I took apart the drivers side of the tunk. I would go look now but we are having a downpour.
Thanks.
