Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 4.78 average. Display Modes
Old 05-12-2008, 08:11 AM   #1
endaward
My Ride: BMW 320d
Unhappy Rear Parking Sensor Not Working, How do I replace it?
Hi,
I have a problem with the parking sensor over the exhaust pipe by putting the car in reverse and then putting my finger over each of the sensors in the bumper where it's easy to spot the dodgy one.
I believe you can easily purchase a replacement sensor on EBAY or other similar sites, but I'm not sure how you actually get access to the broken sensor that is located in the bumpers trim?
Can somebody please explain whats the easiest way to replace a parking sensor without the need to dismantle the bumper.
endaward is offline   Reply With Quote
Old 05-12-2008, 11:09 AM   #2
endaward
My Ride: BMW 320d
Originally Posted by endaward View Post
Hi,
Hi,
I'd like to make a small modification to the problem description above. It should have read as follows:
Hi,
I have a problem with the parking sensor over the exhaust pipe.
I found the problematic sensor by doing the following procedure:
First turn on the ignition, then shift into reverse gear (engine off)
Then put you finger on rear sensors you should be able to feel a pulse and hear a ticking from the sensors if you dont then you need to replace that sensor.
Old 08-17-2008, 03:14 PM   #3
budweiser505
My Ride: e46 330ci 01
Send a message via MSN to budweiser505
bump for last sentence ^^
budweiser505 is offline   Reply With Quote
Old 08-20-2008, 05:54 AM   #4
budweiser505
bump
Old 10-25-2008, 11:26 AM   #5
owenmoney
My Ride: 320D
Parking Sensors
I also have a problem with one parking sensor on a 2004 320d. Does anyone know how to remove the old sensor and replace with a new one?
owenmoney is offline   Reply With Quote
Old 02-09-2009, 03:19 PM   #6
ronjeremy
My Ride: 330D
Cheers Lads, just confirmed one sensor u/s on my car. You're right, you can hear them tick, found the u/s one was silent. Cheers!
Park sensor.pdf
Hopefully I've attached that PDF correctly, shows how to remove the sensors.
ronjeremy is offline   Reply With Quote
Old 02-11-2009, 12:31 PM   #7
b21playa
My Ride: 306
Ive got the same problem.
Anyone got tis info for the msport bumpers?
b21playa is offline   Reply With Quote
Old 02-11-2009, 03:56 PM   #8
ronjeremy
My Ride: 330D
Is this what you're after old chap?
M3 Park sensor.pdf
Old 01-30-2010, 05:38 PM   #9
DJ DigitalMoose
My Ride: BMW 320
I've had the same problem, car beeps when in reverse, but when I go to check the pulse on the sensors, they're all working???
Anyone any ideas??
DJ DigitalMoose is offline   Reply With Quote
Old 02-02-2010, 07:50 AM   #10
DJ DigitalMoose
My Ride: BMW 320
Anyone any ideas??
Bump!
Anyone?
Old 04-01-2010, 04:45 AM   #11
Alex Santos
My Ride: 320d e46
thakx guys
this is a very helpfull site keep it up
may you all have a wonderful easter
Alex Santos is offline   Reply With Quote
Old 04-07-2010, 10:31 AM   #12
boyfromnowhere
My Ride: beemer
After trawling through a lot of threads,could not find a definitive answer to the sensor problem ie;clicking=working,not clicking=not working,I found that one of my sensors was clicking slightly quieter than the other 3. I obtained a replacement from a breaker and bingo,job done,I reckon that if you get a good sensor and use process of elimination you should come up trumps.
boyfromnowhere is offline   Reply With Quote
Old 07-02-2010, 07:51 AM   #13
blackeightballer
My Ride: bmw 330 ci
Parking sensor over exhaust not working. Can anyone tell me how i get faulty sensor out and put new one in please. E46 330 coupe. update; the trim holding all 4 sensors unclips underneath for easy access
blackeightballer is offline   Reply With Quote
Old 07-02-2010, 08:41 AM   #14
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Take the pumper off and unplug the sensor.
GoingNuts is offline   Reply With Quote
Old 08-23-2011, 11:11 AM   #15
happyt
My Ride: 330ci
Parking sensor
I am not sure what is wrong with my sensors, they all click but it still doesn't work. I think it may be surface damage on the middle two.
Either way... BMW list price is 97, ebay second hand is 20 or (and better) original Bosch Sensor is 30 from Central Auto Supplies here in UK.
www.central-auto.co.uk
happyt is offline   Reply With Quote
