Old 05-12-2008, 06:50 PM   #1
skipole
My Ride: '02 330ci
Stupid Angel Eyes Question
Always having been a Honda guy, I'm new to the whole concept of angel eyes. It seems like every BMW enthusiast knows everything there is to know about angel eyes, but I really know nothing. I don't even really get the concept.
Question is: when are angel eyes on? Do they replace your DRL's? Are they always on, regardless of whether Xenon's are on or not? Do you have to turn them on manually? I just don't get it, and I simply cannot find an answer to this through all my searches.
I'm thinking about picking up a set, but ideally I'd prefer that they replace my DRL's (I'm in Canada so the DRL option is turned on since DRL's are mandatory here).
skipole is offline   Reply With Quote
Old 05-12-2008, 06:56 PM   #2
Aerick
My Ride: 2003 M3
You can wire them to be on whenever you want (on switch), only when the car is on (most commonly wired this way), or when your corner lights are on. Basically, you can have it any way you like. Just depends on how you wire it.
They do not replace DRLs. DRLs are completely separate and you will have to get your local dealer to turn them off. I don't think they will though, since you're in Canada.
Aerick is offline   Reply With Quote
Old 05-12-2008, 06:58 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
With our kits, we include a full wiring harness with built in remote kit so they will fade on when you unlock the car with your factory remote, stay on whenever the car is on (even if the headlights are on or off so they function as a DRL too) and fade off when you lock the car.
In addition, if you wish to have full control over them, we offer a Kill Switch DIY so you can install a switch to turn them on and off at will.
Here are the two kits currently available for your car:
Predator Chromium for Most BMW (CCFL Based)
Predator Orion for Most BMW (LED Based)
Both kits are nearly identical with the difference being that the Chromiums use a CCFL ring with ballasts and the Orions use an LED based ring with no ballasts. We are also releasing an Orion V2 along side the current version of Orion which features more high output LEDs.
Old 05-12-2008, 07:50 PM   #4
jetskier88
My Ride: 330i ZHP S/C TS2+
Send a message via AIM to jetskier88
definitely recommend doing it.... IMHO it looks really good... i'm assuming your CI is pre facelift so that means you dont need to bake ur headlights... installation will be really easy, you just have to remove some clips
ESS TS2+ - OEM M3 LSD rear end swap - Meth Injection - Recaros PP - Defi Guages - Dinan TB - Headers&M3 Custom Quad Exhaust - UUC LTW Flywhl - UUC SegKev Clutch - Rogue SSK - KW V2 Coils - H&R Sways - TMS Subfrme&Sway Reinfrcmnt - VMR V710 & M PS2's - Brembo X Rotors and more....
jetskier88 is offline   Reply With Quote
Old 05-12-2008, 07:53 PM   #5
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
Everything you need to know about Angel Eyes can be found in this thread: http://forum.e46fanatics.com/showthread.php?t=564135
Then simply wait for aurora to start shipping:
tom @ eas is offline   Reply With Quote
Old 05-12-2008, 08:03 PM   #6
skipole
My Ride: '02 330ci
Thanks Nick. I'm currently considering the Orion - what's different about the V2? Also, if I understand correctly, I need to have my DRL's turned off or else the Angel Eyes will be on with the DRL's also? Wow, that would be disgustingly ugly. Anyone know if there's a way to do this somewhere other than the dealer? I have a feeling my local Bimmer dealership will either try to charge me several hundred dollars for this, or tell me to go f*ck myself.
Yep, pre-facelift ('02). I'm not actually that huge on the look of them on a stock car (mine is still stock atm) but they're cheap and easy to install
Old 05-12-2008, 08:08 PM   #7
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Here is more info about the V2:
http://forum.e46fanatics.com/showthread.php?t=573846
You do have to get the DRLs disabled by the dealer which I believe cannot be done in Canada. The only other way would be to take out the bulb and install resistors to trick the computer into thinking the bulb was still present.
Old 05-12-2008, 08:10 PM   #8
skipole
My Ride: '02 330ci
That's a great threat Tom, I've actually seen it before. It didn't actually answer my original question though (re: DRL).
Old 05-12-2008, 08:12 PM   #9
skipole
My Ride: '02 330ci
That sounds like a reasonable solution. That bulb doesn't double as the high beam, does it?
Old 05-12-2008, 08:12 PM   #10
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Any independent mechanic should be able to turn them off with a GT1 or Autologic as long as the AEs are functioning as DRLs.
Old 05-12-2008, 08:14 PM   #11
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Nope, your car has bixenons which uses the low beam for both the high and low beam. The inner beam is only used for DRLs or if you flash your high beams.
Old 05-12-2008, 08:15 PM   #12
russ330
Mod Squad
russ330's Avatar
My Ride: Motorsport III
Send a message via AIM to russ330
I just skimmed through so someone may have addressed your DRL question. The DRLs are independent of the halos, one doesn't have anything to do with the other. If you have the DRLs turned on, many people (and I would too) have them turned off when adding angel eyes.
LEDs seem to be the new thing with halos, it's a simpler install and a more robust system.
/Moved.
russ330 is offline   Reply With Quote
Old 05-12-2008, 08:16 PM   #13
jetskier88
there aren't independent shops which can disable this feature?
Old 05-12-2008, 08:18 PM   #14
skipole
My Ride: '02 330ci
Right on. I definitely think this would be the easiest solution, then. What size resistor would I need? The V2's look good, Nick - any idea when they'll be released?
Old 05-12-2008, 08:55 PM   #15
drchuck72
My Ride: 2003 M3
not a stupid question
The only stupid question is the one you don't ask.
I've spoken with a mechanic here in the GTA and I think he knows how to wire the angel eyes in such a way that they would replace the DRLs. In fact, I'm pretty sure a lot of guys do it that way.
If you live in the GTA, talk to Rocco at RMP Motors. If you check the e46toronto.ca forum, he has a forum there as one of the sponsors.
DR CHUCK (plate number ON)
2003 Titanium Silver M3 Cabriolet
AC Schnitzer rear lip spoiler, Carbon Fibre Rear Valence and front strut bar.
Supersprint Exhaust
drchuck72 is offline   Reply With Quote
Old 05-12-2008, 09:03 PM   #16
PhillyKatBMW
My Ride: BMW
Holy crap...there are LED based systems that are brighter than the CCFL? I've always stayed away from angel eyes cuz of the CCFL's "finicky" nature...
So which ones are brighter EAS's e2 or the JL's OrionV2?
-Chevalier Mal Fet-
PhillyKatBMW is offline   Reply With Quote
Old 05-12-2008, 09:05 PM   #17
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
Until we see an actual picture of our competition - ours.
Old 05-12-2008, 09:09 PM   #18
skipole
My Ride: '02 330ci
Thanks dude, I'm actually in Victoria but I'll have to call around about that. Failing that, I'll go for the ghetto resistor mod
Old 05-16-2008, 07:48 PM   #19
tom @ eas
tom @ eas's Avatar
My Ride: e92 S/C M3
For those that requested - daytime pictures:
Videos have been shot, the Orions (left) are finally coming off this weekend.
Old 05-16-2008, 07:53 PM   #20
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
Here's the real answer:
http://forum.e46fanatics.com/showthr...on#post7923178
