Angel eye issue I'm out of ideas - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-12-2008, 09:52 PM   #1
jeremysmith1967
a.k.a. Norton
My Ride: 00 328ci & 67 stang
Send a message via AIM to jeremysmith1967
Well I have been having ballast issues on my passenger side so I decided to eliminate that ballast and just run the power from the outside ring on my drivers side to the inside ring on the passenger side so at least it looked even.
The issue I'm having is kind of odd but I'll do my best to explain it. When I wire up the ring and have the wires dangling over the fan both rings work fine. But when I route the wires in the channel on top of the radiator the ring on the passenger side works intermittently. If i move the wires from the channel it usually lights up but not all the time. I thought there may have been an insulation problem so I lined the wires with loom but that did absolutely nothing.
All the joints are soldered and covered in heat shrink so I highly doubt that the issue is related to the connections. The problem seems to be related to the wire being placed down in the channel on the radiator but I don't understand why that would be.
Any help is appreciated because I am quite confused.
jeremysmith1967 is offline   Reply With Quote
Old 05-13-2008, 04:14 AM   #2
sillieidiot
My Ride: '06 AW 330ci
so you extended the white wires from the ballast to the rings?
maybe try using a bigger gauge wire to minimize interference. say 16-18 awg.
Old 05-13-2008, 08:06 AM   #3
jeremysmith1967
a.k.a. Norton
Yeah I extended the wires and I used 16 awg.
Old 05-13-2008, 01:42 PM   #4
sillieidiot
well that's most likely the problem. the white wires aren't supposed to be extended.
Old 05-13-2008, 10:04 PM   #5
jeremysmith1967
a.k.a. Norton
Well damn I guess thats what I get for trying to cut corners, lol.
Old 05-13-2008, 10:17 PM   #6
sillieidiot
lol, what's wrong with the ballast going out on the passenger side? it shouldn't be a problem. might want to check the wires on that side of the harness. to see if it's chaffed or something.
Old 05-14-2008, 10:47 PM   #7
jeremysmith1967
a.k.a. Norton
Yeah I checked the wires and couldn't find anything so I just took that ballast out and this is what I came up with. I guess I'll have to break down and buy another ballast. I heard that there is a place that sells upgraded ballasts that are cased in metal. Do you by chance who that is?
Old 05-14-2008, 11:56 PM   #8
sillieidiot
yeah it's called vibelights.com. you need to get the aluminum ones. you'll have to solder the connections, as the connectors don't fit. should be like 16 something for 2.
Old 05-15-2008, 12:56 AM   #9
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
I have a few different variations also, all potted/weatherproof.
Let me know if you need a set.
tom @ eas is offline   Reply With Quote
Old 05-15-2008, 01:26 AM   #10
Genuine
Banned
My Ride: 00 323i 4Dr
ROFL!!!! I just did the exact same thing on my install yesterday. only the driver 2 worked. I got mad, so i extended the lowbeam angel eye to the passenger side high beam, and to my disappointment, it still didn't work. I too ran the wires across the radiator.
Genuine is offline   Reply With Quote
Old 05-15-2008, 03:03 AM   #11
sillieidiot
lol
