Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 4.71 average. Display Modes
Old 05-13-2008, 09:52 PM   #1
bigdog2003_99
My Ride: 2009 Audi B8
5 to 6 speed swap, parts list with pics.. no 56k
so i am almost ready to swap my 5sp tranny to a 6sp so i can use my 3.46 kaaz lsd without sacrificing my gas mileage, heres a general parts list if your car is already a 5 sp and what you need to convert it... you will need:
1. transmission = 1500
2. clutch and flywheel (plus alignment tool) 435 all oem
3. transmission mount, with adapter = 65
4. shifter and shifter carrier = 35 for oem shifter carrier, 450 for evo 3 with dssr
5. guibo = 78 oem bmw (same as the guibo off the 323ci auto/why different bolt pattern than 323ci 5sp idk)
6. driveshaft = 300 + 150 for the parts to repair it (you can buy a different flange/bearing to convert the 4 bolt auto to a 6 bolt manual)
7. i went with the cdv, because i hate the way my car feels when i shift... = 30
heres everything minus the clutch, which i left in my garage... my flywheel is a little rusty-hopefully it will still work fine-if not ill just replace it with a lightweight lol
heres the new tranny mount, and the adapter is still attached to the transmission
heres where the new shifter carrier bolts up to, it is different than the 5 sp because it has 2 mounting points instead of one
heres my cdv, on the left, the oem one is on the right, you can see the ballbearing that makes it suck to shift
my new uuc carrier bushings, anyone know if i can shave these down to fit? they are alot wider than the oem ones
the rear of my driveshaft, the rear bushing was crushed, and had to be replaced, all that holds it in is a snap ring, and thers also a clip that seals the rubber bushing
new vrs old, note the broken bushing-can i use axle/driveshaft lube for this? figured i should ask for a 2nd oppinion here
finished install before it goes in
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
http://videos.streetfire.net/video/J...yan_186423.htm
bigdog2003_99 is offline   Reply With Quote
Old 05-13-2008, 09:58 PM   #2
southpaw
My Ride: E36 M3 and E36 318ti
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 05-13-2008, 10:07 PM   #3
Mishka1
My Ride: :(
In
Mishka1 is offline   Reply With Quote
Old 05-13-2008, 10:10 PM   #4
bigdog2003_99
hopefully if all goes right it will be in this weekend, with the holiday and all i should start saturday night-still have a 5sp shift knob....
btw thanks to the gas prices and me driving 80+ miles a day, i am thinking of selling my 3.46 lsd after it gets rebuilt, and buy the 3.15 one in the "for sale" forum, if anybodys intersted pm me
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
Old 05-13-2008, 10:16 PM   #5
Snik
Snik's Avatar
My Ride: IR M3 Vert.
You inspire me dude.
Fuk yeah.
Do you ride a sportbike?
Old 05-13-2008, 10:29 PM   #6
WhiteOut323i
My Ride: 2000 323i
lookin good bro
WhiteOut323i is offline   Reply With Quote
Old 05-13-2008, 10:51 PM   #7
bigdog2003_99
Fuk yeah.
i'd say go for it lol, i just checked car-part but theres not anything good on it right now though
Originally Posted by WhiteOut323i View Post
lookin good bro
thanks man!! definately have to let you check it out next time i go to Mi.
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
Old 05-18-2008, 03:29 PM   #8
bmw_chuzo
My Ride: HPF M3
Send a message via MSN to bmw_chuzo
wow man project is looking HOT!
bmw_chuzo is offline   Reply With Quote
Old 05-18-2008, 03:33 PM   #9
Vinnie Vega
My Ride: 0032870Vette70Velle
aw dude please document this swap well. What is the 6 speed out of? the 5 series?
Vinnie Vega is offline   Reply With Quote
Old 05-18-2008, 03:49 PM   #10
WhiteOut323i
My Ride: 2000 323i
for sure!!!
Old 05-18-2008, 04:13 PM   #11
Alex323Ci
My Ride: M3 & 323Ci (sold)
i've been thinking of doing this for a while now. everytime i start to search for parts i just say i'll wait and buy a new car. so i'm looking forward to how this goes for you and finding out all the parts and changes needed.
i'm not sure about some of the part swaps so please document any modifications you find you need along the way.
also, pretty sure your 323ci doesn't have a CDV. so i'm unsure about that whole thing you posted. you bought a CDV because you hate the way your car shifts?? then you show new cdv and stock one. i'm totally lost what you're talking about. why buy a new one and have an old one replaced?
i'd keep the 3.46 with the 6th gear. going from 3.07 to 3.15 is only a 2.5% change for you.
Old 05-18-2008, 06:10 PM   #12
AdamBath
My Ride: E30
+1 on keeping the 3.46, no way i'd go 3.15 with a 6 speed, its got such a long 6th gear, you'd still be in a very comfortable rpm range in 6th at 80.
and again, whys this one been moved to forced induction forum??
AdamBath is offline   Reply With Quote
Old 05-18-2008, 06:25 PM   #13
BlueTeeth
My Ride: e36
so you spent $2000 to change your transmission so you can save a few dollars here and there at the pump? sounds economical.
why don't you be more honest and say, "i just really wanted a 6 speed"
-BlueTeeth-
BlueTeeth is offline   Reply With Quote
Old 05-18-2008, 07:43 PM   #14
Len013091
My Ride: S52 E30, 330i
Send a message via AIM to Len013091
The 6 speed will not only allow him to get better mileage, it will also substantially reduce engine noise while cruising at higher speeds.
Len013091 is offline   Reply With Quote
Old 05-18-2008, 08:50 PM   #15
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
Subscribing
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 05-18-2008, 08:55 PM   #16
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
I'd definitely take that flywheel to get resurfaced before I put it in...
Lookin good though, good luck!
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 05-18-2008, 10:31 PM   #17
bigdog2003_99
yes i did just want a 6sp, the simple fact of better gas mileage definately helps along with reduced engine noise, 2 for 2 there
whenever i get the lsd back from the shop, ill end up keeping it and installing that soon-like everyone is saying 3.46 is the way to go, i should still be up in the 27-30mpg range so im happy there
i didnt end up doing the swap this weekend because the autozone that i was at had no royal purple or redline fluid for the tranny... i'm going to order some redline from turner tomorrow and some other goodies lol
btw i thought you couldnt resurface the dual-mass flywheel
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
Old 05-18-2008, 10:36 PM   #18
AdamBath
My Ride: E30
do you not have a napa near you? i believe they stock royal purple.
Old 05-18-2008, 10:37 PM   #19
bigdog2003_99
cool ill check that tomorrow, they were closed by the time i got off of work on saturday
2010 C300 4matic
2008 yamaha r6
see garage^
R.I.P. John Bryan
Last edited by bigdog2003_99; 05-18-2008 at 10:53 PM. Reason: spelling error as usual
Old 05-18-2008, 11:08 PM   #20
bmw_chuzo
My Ride: HPF M3
test your lsd man.. I have the 3.46 and is not so bad.. and i have the 5sp....
the 3.64 in the other hand is not soo "economical"
