Old 05-17-2008, 12:06 AM   #1
deafboy
My Ride: 2000 323Ci
Post OEM M3 Hood on Non-M Coupe *DIY*
Alright, well I have received several PMs from various members over the past several months asking how to install an OEM M3 hood on a Non-M Coupe. So I figured I would go about doing a brief DIY.
e popa also has a DIY and I ended up doing mine with the help of him and his DIY (as well as help from several other members). Anyways, I just figured I would throw this together really quick.
Step 1: Removal of Stock Hood components.
(If you have a Bentley Service Manual for the e46 3 series open to page 410-3...I am simply taking my information from there, almost verbatim and adding in my tid bits)
Pop and Raise the hood.
- Disconnect washer fluid hose from washer nozzles. (If you have never done this before it may be difficult to remove. I found by warming the hose up with a hair dryer and gradually pulling/wiggling makes things much easier).
-Where applicable, disconnect electrical harness connector from heated nozzles (see picture below for example).
Before you attempt to remove the hood from the car, be sure to remove the wiring and hose that run through the hood. You will want to remove the rubber grommets first. They should be slitted so just simply pull them out.
While the hood is still on the car (you can do it when the hood is off also, but I found it easier to do while the hood was still attached) remove the hood release latch and springs. Simply remove the torx bolts using a torx bit. Set Aside.
*For this next step you will definitely want a second hand. The stock hood is by no means light (in comparison).
Although the Bentley Manual suggests you remove the gas-charged hinge from the hood supports, I didnt. Instead my helper and I (one on each side of the hood) removed the bolts that connect the hood to the hinge. Removing the one nearest the windshield first. Once that bolt was removed we simply loosened the upper bolt so it could slide off. Be careful with this step, as mentioned the hood isnt light. BEFORE you loosen/remove these bolts, with a sharpie or a pencil, mark around the bolt. This will help for future reference.
Step 2: Install of OEM M3 Hood components
The basic install of the OEM M3 hood is simply the reverse of what you just did. But I will give you some tips on going about doing it.
You will notice right away that the M3 hood is significantly lighter than your stock one. You will still want help attaching it. I started off by starting the upper bolt (the one that goes to the hinge) to the M3 hood. I started it simply so it could slide into the hinge so we didnt have to hold the hood in place while someone else got the bolts going. Once the hood is slide on, put the bottom bolt (the one nearest the windshield) in place and get it going. Snug all four bolts down. This isnt final, you will be adjusting it later on, so do not fully tighten them, just get them snug.
Althought you arent tightening them completely, try and line up the bolts with your reference marks, although they wont be dead on, they should be fairly close to where they will end up being.
Once the hood is on, take your time and run the hose and wiring back through the hood. This is very tedious and can be annoying as hell Just take your time and be patient. I end up using an extended grabber but it isnt a common tool so I dont expect many of you to have them.
Put your washer grill and washers in place, simply snap in. Then reconnect the hose and wiring. I ended up looming my wiring and zip tying it to the hood, but its completely optional.
Time to see how it initially fits. GENTLY lower the hood, DO NOT CLOSE IT COMPLETELY. It is very possible that your hood and fenders could rub, so gently lower it and see how things look. From here you can get a general idea how much you need to adjust the fenders and hood.
Step 3: Adjusting for Better Fitment.
Although every car isnt the exact same. The common case is that you will have to "pull" out the rear portion of the fender and "push" in on the front portion of the fender. To do so you will need to take out the upper torx bolts that hold the fenders in place, you have to take them out because you will need to widen the holes a bit so you have enough room to push and pull.
Widening the holes isnt as dauntening as it sounds. I ended up using my dremel and some sanding bits to widen the hole. I am very anal about how things look so I made the holes as close to OEM looking as possible. I also took a paint pen and touched up the exposed metal. I cant really tell you how much you will have to do because like I said, each car is a little different. Some require the holes to be a little larger than others.
Once the holes are widened to your needs, you will need to bring the fenders up in certain areas. Most people do this by using washers where the bolts go. Although I did use metal washers in certain areas I found the best option was the use of hard rubber grommets. The use of grommets allowed for more play (ie I could really tighten the bolts down to compress the rubber or back off a little bit to bring it back up. But that method only words for a mm or two. It will take a lot of tweaking at playing with to get just right. Just buy a selection of washers and play around with it. This is the most time consuming thing you will be doing. Just getting things aligned the way you want.
In some cases, you might need to shave some metal off the hood itself. In my case the sidewall of the hood was hitting the bottom of the fender, so it was unable to get down low enough to be completely flush. To find what spots needed to be trimmed a bit I placed some play-dough on the fender (very thin) and then close the hood to see where it's touching. Trim as necessary or desired. Again, I used my dremel to do this. Also, touch up the exposed metal with a paint pen (not necessary, but again, I am anal about this crap).
Another thing that you will need to adjust it the rubber bumpstop on the front near the headlight (see pic)
you will have to turn this so that it is ALL the way down. I actually even head to trim mine a little bit so the front of the hood could come down a bit more. I simply trimmed it down using an exacto knife.
For the most part it just takes a LOT of playing around and testing things out.
I know all of this sounds like a lot of work, but it is actually really easy. As long as you are patient it'll come out just fine. If you have any questions or want some pictures of something please feel free to ask.
You can also check out these (among several others) for references to my process.
E Popa's DIY Thread
Blade929's Thread
My Alignment/Fitment Thread
Final Product (during bimmerfest, disregard the decals )
PLEASE POST ANY QUESTIONS OR CONCERNS YOU HAVE HEAR. YOUR QUESTIONS COULD HELP OTHERS. IF YOU SEND ME A PM ABOUT AN OEM M3 HOOD INSTALL, I WILL PROBABLY BE POSTING IT HERE (with names blocked out).
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 05-17-2008, 02:20 AM   #2
Arrows
My Ride: 2000 323i.
Send a message via AIM to Arrows Send a message via MSN to Arrows
wrong section?
Arrows is offline   Reply With Quote
Old 05-17-2008, 06:49 AM   #3
-=Spike=-
My Ride: BMW 330Ci Coupé
The edges of the hood near the front lights, don't fits with the fender. Where did you buy the hood?
Regards
Ralf
BMW e46 330Ci Coupé from Germany :)
-=Spike=- is offline   Reply With Quote
Old 05-17-2008, 11:06 AM   #4
deafboy
My Ride: 2000 323Ci
Originally Posted by Arrows View Post
wrong section?
Regards
Ralf
yeah.... like I said. It takes a lot of adjusting. I'm still not done yet.
Old 05-17-2008, 11:22 AM   #5
///Rogu3
My Ride: has M-Style
Nice DIY...it turned out sweet for you.
I fought the fitment issues for a while and finally gave in to M3 fenders upgrade.
Wifey's car is faster....booooooooo
///Rogu3 is offline   Reply With Quote
Old 05-20-2008, 09:31 PM   #6
sillieidiot
My Ride: '06 AW 330ci
you need to push the hood back a little
Old 06-03-2008, 04:34 PM   #7
phrozen06
phrozen06's Avatar
My Ride: E46, E92 M3, R32 VW
Send a message via Yahoo to phrozen06
great thread.
phrozen06 is offline   Reply With Quote
Old 06-03-2008, 04:40 PM   #8
phrozen06
phrozen06's Avatar
Regards
Ralf
Same here, I have more adjusting to do also. It takes time and patience.
Old 07-01-2008, 12:05 AM   #9
deafboy
My Ride: 2000 323Ci
yeah, I know..like a couple mm. But it doesnt bug me enough yet to want to do it
Originally Posted by phrozen06 View Post
great thread.
thanks
YOU'RE DOING THIS?!
I cant wait to see your car with it
Old 07-01-2008, 01:43 AM   #10
freshprince2421
My Ride: 325ci
Also be careful not to strip the bolts when adjusting your fenders. I ended up stripping one bolt on each side. For whatever reason they had been torqued to the extreme.
freshprince2421 is offline   Reply With Quote
Old 07-01-2008, 02:52 AM   #11
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
Awesome DIY. Now I just wish M3s came in sienna red
-Gary
DiscoStu is offline   Reply With Quote
Old 07-02-2008, 10:19 AM   #12
deafboy
My Ride: 2000 323Ci
yeah, I didnt really have a problem with that...but I can definitely see that happening. Especially if someone used a hex wrench instead of the torx wrench.
lol...no joke.
Must be a ***** for you trying to find stuff in the classified section
Old 10-02-2008, 01:38 PM   #13
Mc 007
My Ride: 325ci Performance
my compliments Deafboy!
Mc 007 is offline   Reply With Quote
Old 10-03-2008, 08:00 AM   #14
TioTitin'sBlau3
My Ride: 03 TopazBlau3
Send a message via Yahoo to TioTitin'sBlau3
Can this be done to a Face lifted Sedan??
Tio Blu, in hiding.
///M South on Facebook
TioTitin'sBlau3 is offline   Reply With Quote
Old 10-04-2008, 09:52 AM   #15
Mc 007
no,coupe' hood isn't the same like sedan
Old 10-04-2008, 01:35 PM   #16
sontanvu
My Ride: 2006 325Ci
can this be done to a facelifted coupe?
sontanvu is offline   Reply With Quote
Old 10-05-2008, 02:15 PM   #17
Mc 007
no,for the facelift coupe' you need the Vorsteiner
Old 10-24-2008, 03:19 PM   #18
k7780446
My Ride: 323i
so my passenger side sits way to high idk what to do about that any ideas?
5492_121783803182_586518182_2342960_2124492_n
k7780446 is offline   Reply With Quote
Old 10-24-2008, 07:05 PM   #19
deafboy
My Ride: 2000 323Ci
do you have washers on the passenger fender to raise the fender up?
Old 10-25-2008, 04:38 PM   #20
m-tints
My Ride: 2004 E46 Coupe
Send a message via Yahoo to m-tints
is it the same for the facelift model?
m-tints is offline   Reply With Quote
