///M3 Forum
Old 05-17-2008, 01:12 PM   #1
robertwroth
My Ride: e46 M3, e36 M3
O2 Sensor replacement - which is Bank 2?
I am getting a P0430 Code on the car and think I need to replace an O2 sensor... can anyone tell me which one is the sensor for Bank 2 (i.e the one closest to the transmission or the one further forward?) Also, in the engine bay - any tips on locating the right connector for plugging this in? The shop manual is a little light on info around this area
robertwroth is offline   Reply With Quote
Old 06-03-2008, 11:29 AM   #2
sdbimmer
My Ride: 2004 325Ci
sdbimmer is offline   Reply With Quote
Old 06-03-2008, 04:58 PM   #3
robertwroth
Thanks!
Thanks - that helped a lot
Old 06-03-2008, 05:00 PM   #4
sdbimmer
My Ride: 2004 325Ci
no problem.
Old 01-02-2009, 04:19 AM   #5
ricky_zapt
My Ride: bmw 318i
hi, i've got same problem. the o2 sensor faulty came up on my scan result. and my car has problem with idle. up and down. do you have the same problem before replaced the sensors? thx
ricky_zapt is offline   Reply With Quote
Old 01-02-2009, 05:05 AM   #6
sdbimmer
My Ride: 2004 325Ci
it did help...
yeah, my car was idling up and down a little bit. It wasn't too bad though. Also it felt like it was misfiring too. After replacing the bad O2 Sensor, all of that problem went away.
Hope that helps....
