Old 11-19-2016, 05:46 PM   #1
05SMG
My Ride: 2005 330ci ZSP
05' 330ci Rear diff fluid change.
Changed my rear differential fluid today in preparation for 3,000 miles of driving over the next 6 weeks. Some notes for those of you who haven't done this: It's very easy to do took maybe :45 mintutes tops. After safely jacking the car up and making sure it's level.
1)Always remove the fill bolt (14mm) first. I pre soaked mine with PB.
2) I used a 1/2 drive 14mm bolt on a 1/2 inch breaker bar. (A 3/8 drive would be perfect but I couldn't locate a 3/8 drive 14mm drive bolt.
3) I didn't get a photo of the 79,000 fluid but it was fairly dark. I assumed it was the origainal because it smelled like crap. (Pentosin maybe)
4) Refilled the fluid which took slightly over 1 bottle. I did some research and it boiled down to either Redline or Liqui Moly. I have Redline 75W-90 in my SSG/SMG gearbox so I decided to try something different. I used liqui Moly Full Synthetic 75W-90 GL5
For non-Limited slip "open differentials. $16.00 from ECS tuning.
5) I purchased a fluid transfer pump from Autozone for less than $15.00 but didn't use it because the Liqui-Moly bottles have a convenient little extendable tube built into the bottle. I'll save the pump for a gearbox flush.
6) I went by the dealer to pick up crush washers for the drain and fill bolts but realized the bolts were the built in gasket type which I cleaned off and reused.
7) After filling the fill hole until fresh fluid spilled out you clean it off, attach the fill bolt and tighten. I believe the bolts are supposed to be torqued to 42ft lbs (not 100% sure) but I've been wrenching for a while now and I simply bottom out the bolt then snug it up tight after that.
8) Test drove the car on a short highway run at 60mph and to be honest, I couldn't tell a difference in sound or gear changes even with the windows up and AC off.
And that's it.
It'll be a nice piece of mind knowing I've got fresh Gold colored fluid back there.
Some pics.
Cheers
ID:	645475   Click image for larger version
ID:	645476   Click image for larger version
Technically 05SSG
05SMG is offline   Reply With Quote
Old 11-19-2016, 10:25 PM   #2
juslookin
My Ride: 05 330ci ZHP
Should have done tranny fluid as well. I try to change both at the same time since its the same job and its right there
juslookin is offline   Reply With Quote
Old 11-20-2016, 09:39 AM   #3
05SMG
Yup. Did that with the new clutch this summer. On my gearbox there is plate that I have to remove so it's a little more involved than the rear diff.
Technically 05SSG
