Old 11-16-2016, 01:38 PM   #1
mikeetastic
My Ride: lots of 3
E46 Starter Replacement Quick removal
inspired by this thread http://forum.e46fanatics.com/showpos...28&postcount=1 so i finally decided to tackle this last night..
only took me 1.5 or maybe 2 hours or less and i will show what i did to make this job as quick as possible..
this is a combination of top and bottom but no need to take the intake manifold and i only jack the front wheels..
pieces to remove:
1: Top - cabin filter cover and the one on the ECU/DME
2: Bottom - Plastic splash shield and the aluminum cover
thats it, i remove the starter and reinstall everything underneath.
tools needed
1: 10mm or 3/8 ratcheting wrench. i used this set http://www.sears.com/craftsman-20-pi...p-00946820000P
*** if you are worried about stripping the bolt you can buy E10 from link below.
https://www.amazon.com/GearWrench-92.../dp/B000HBF5LQ
2: 3/8 ratchet to use as leverage and this fit exactly on the 3/8 or 10mm http://www.sears.com/craftsman-3-8-i...p-00944815000P
*** this is for the inner starter bolt which i break and remove on top
3: E12 3/8 socket, wobble pieces and 3/8 extension
*** this is for the outer starter bolt which i remove underneath.
pics:
inner starter bolt removal (10mm or 3/8 wrench + 3/8 ratchet to use a leverage)
outer starter bolt removal. this is the easiest part. done and bolt is out in less than 5min
Hope this helps everyone..
mikeetastic is offline   Reply With Quote
Old 11-16-2016, 03:20 PM   #2
das_autobahn
My Ride: 2004 330ci coupe
glad it worked boss! just be careful using standard wrenches on torx heads, they could strip and then yer screwed. but glad it worked
das_autobahn is offline   Reply With Quote
