Old 05-18-2008, 10:35 AM   #1
j0n228
My Ride: 2001 bmw 330i
my car smells like something is burning
when i use my car after its stop running if you go near the kidney grills u can smell like something burning i kno i need new belts but can that be the reason why it smells like that or can it be something eles ?
j0n228 is offline   Reply With Quote
Old 05-18-2008, 12:21 PM   #2
UNFORGIVEN
My Ride: Bagged Stang, 330CI
Jon, is your coolant light on by chance? I had the same burning smell. In my case, it was the thermostat needing to be replaced. Good luck man.
UNFORGIVEN is offline   Reply With Quote
Old 05-18-2008, 01:27 PM   #3
Polish_328Ci
My Ride: M3
Not sure if you have angel eyes but mine caught fire 2 days ago where the connectors are since the connectors are **** and they arc causing it to catch fire. I cut off the connectors and soldered the wires back together.
Polish_328Ci is offline   Reply With Quote
Old 05-18-2008, 11:52 PM   #4
j0n228
it goes on and off but it only goes on when i really get on it but when i dont speed the light stays off i just fixed the leak but i think its still leaking im not sure but i dont want my car to mess up
Old 05-19-2008, 12:51 AM   #5
neil22
My Ride: 330ci ZHP, E28 535is
...had a burning smell a few weeks back. my car's still under warranty, needed a new valve cover gasket. problem solved no more burning smell. may or may not be the same problem. it was intermitent for me but after "spirited" drives i could definitely smell it with the windows down at a stop.
neil22 is offline   Reply With Quote
Old 05-19-2008, 06:29 AM   #6
j0n228
neil when u had this problem when u drove fast did ur antifreeze go down fast and the sign went up and then went away
Old 09-22-2009, 08:41 PM   #7
SRAM3
My Ride: 02 IMOLA M3
I just had my thermostat changed and i still notice the burning smell. Did yours go away immediatly after you changed or did it take a few days to clear up?
SRAM3 is offline   Reply With Quote
Old 09-22-2009, 08:44 PM   #8
JSanders
My Ride: Breaks too often
Once my coolant light came on, it never went off. 3 years later and its still on.
JSanders is offline   Reply With Quote
Old 09-22-2009, 08:48 PM   #9
JK1150
My Ride: 2004 325CI
my engine always smells pretty bad after driving...
JK1150 is offline   Reply With Quote
Old 09-22-2009, 08:51 PM   #10
dinan Bimmer
My Ride: Turbo 350Z
Send a message via AIM to dinan Bimmer
I had the same problem. After getting on the gas it smelled burnt. One of my pulleys started to seize and was burning from the friction of the belt against the pulley. About a month later (while on the gas) the belt broke. GL
1997 VW Jetta TDi 16v ABAt
1997 BMW M3 S366
E90 335i 6mt DD
2000 323i Sold
2004.5 350Z APS ST 475whp 505wtq Sold
dinan Bimmer is offline   Reply With Quote
Old 09-22-2009, 08:51 PM   #11
Mclovin1458
My Ride: 2005 325ci, zsp/zpp
If its electrical burning smell then might be an alternator gone bad. I'v had this happen on my 01 maxima.
Mclovin1458 is offline   Reply With Quote
Old 09-22-2009, 09:04 PM   #12
Acarder
My Ride: 69' M3
Valve cover gasket, coolant leak somewhere (expansion tank/thermostat/upper radiator hose), something leaking and landing on the exhaust manifold.. could be quite a few things really. I wouldn't be too worried, just get up to date on all the maintenance.
Is it a sweet smell? Or does it smell like burnt oil?
Acarder is offline   Reply With Quote
Old 09-22-2009, 09:10 PM   #13
s3th
s3th's Avatar
My Ride: 05 330Ci ZHP
burnt oil or burning the clutch?
You can just call me seth.
500px
s3th is offline   Reply With Quote
Old 09-22-2009, 09:14 PM   #14
WFRFitness
My Ride: 2000 328CI E46
^^ exactly don't you know your car maintenance smells if you could send me the smell I could tell you... oil, clutch, antifreeze.... http://www.popularmechanics.com/how_...e/2423551.html that's the best I can do for you
WFRFitness is offline   Reply With Quote
Old 09-22-2009, 09:25 PM   #15
kosnosferatu
My Ride: 2000 323ci
do you smell anything while in the car? I did in my car when my valve cover gaskets were leaking.
kosnosferatu is offline   Reply With Quote
Old 09-22-2009, 09:43 PM   #16
GDA
My Ride: M5, 325i and 330i
Power steering fluid stinks pretty bad too when it hits a hot block or exhaust
GDA is offline   Reply With Quote
