Old 05-18-2008, 08:44 PM   #1
davideby
My Ride: 325i 2002
Question Error codes 0313 &1083/1085 HELP!
HI: My 325i started missing and running rough today. The low fuel light was on so I thought filling the tank would help, It did not. It actually stalled at stops. Code 0313 indicates a misfire detected with low fuel and 1083/1085 indicate fuel control mixture lean, bank 1 & 2. I have no idea how to solve or check these problems. Could it be a fuel filter problem? All suggestions will be greatly appreciated.
Davidebby
davideby is offline   Reply With Quote
Old 05-18-2008, 09:00 PM   #2
EvilGenius
Banned User
My Ride: '02 BMW 330Ci
Not knowing the maintenance history or miles on the car, I would first suggest the fuel filter, then a few tankfulls of good injector cleaner. If that doesn't fix it, then look into fuel pump.
EvilGenius is offline   Reply With Quote
Old 05-18-2008, 09:06 PM   #3
djnekkon
My Ride: MB3ci & z33 HR
fuel pump, but try that first^^^^^ it is very cheap.
Old 05-18-2008, 09:12 PM   #4
EvilGenius
Banned User
AND (very important) post an update here on what component fixes it!
Old 05-18-2008, 10:29 PM   #5
davideby
My Ride: 325i 2002
THANKS GUYS. I'll get a fuel filter on order tomorrow and let you know.
davideby
Old 05-21-2008, 12:52 AM   #6
2003330i
My Ride: SC'330izhp,09 335i,
any updates. i have the same codes and about to go out and buy a fuel filter and a fuel pump. can we use an m3 fuel pump?
2003330i is offline   Reply With Quote
Old 05-28-2008, 08:31 PM   #7
davideby
My Ride: 325i 2002
Unhappy Engine Quit & More Code Problems.
Fuel filter did not fix the problem. Later it got worse. Had to leave it at a repair shop for 6 days before they could get to it. The trouble turned out to be a Cracked elbow snorkle tube, whatever the Hell that is! Anyhow that did not stop new error codes from popping up. Mechanic said it runs good, try it with the error codes. I did today and it ran but still cuts off and sputters when you first start it. Codes are now-143,228,227,120,203,202,238,240,239,249,171,174, and the original P1083 &1085. I am going back to the mechanic tomorrow and have a long talk. I think I will end up driving to the nearest BMW dealer (100 miles) BILL WAS $353.05. Davideby
Old 05-28-2008, 08:52 PM   #8
EvilGenius
Banned User
Are those Px codes or BMW native codes? Sure is a lot. That makes sense about the elbow. It's the part of the tube that hooks to the air intake line and then goes to the throttle body and idle control valve. It's known to break, introducing a post-maf air leak, and making the engine run lean and crappy. With all of those codes it sounds like the mech didn't plug something back in Let me know if they are P0, P1 or BMW native, and I'll see if I can help you interpret what your car is trying to tell you.
