Old 05-20-2008, 04:39 AM   #1
MilanoGTR
My Ride: 01 JeTBLK M3
E46 coupe B pillar removal?
How to remove both B pillars on E46 coupes? do i have to un-bolt both seat belt anchors? Are the pillars held on by clips or screws? thanks...looking to remove the entire headliner for vinly.
MilanoGTR is offline   Reply With Quote
Old 05-20-2008, 04:53 PM   #2
MilanoGTR
no one ever remove the B pillar ???
Old 06-06-2008, 01:23 PM   #3
grogers
My Ride: 2001 330Ci
looking for the same thing...bump
grogers is offline   Reply With Quote
Old 06-06-2008, 01:26 PM   #4
phrozen06
NA V8
phrozen06's Avatar
My Ride: E46, E92, R32
Send a message via Yahoo to phrozen06
I'm sure it's possible but If you do this. You could experience some twisting of your frame. Although it wouldn't be noticable. Also the B pillar contains the rubber window seal.
M3 DCT/Swift Spec R Springs/Macht Schnell Spacers/Megan Exhaust
Coming Soon: Test Pipes, BMC Intake Filter and BPM Stg 2 Tune
& BPM Euro DCT Software
phrozen06 is online now   Reply With Quote
Old 07-04-2008, 01:18 AM   #5
Squeak
My Ride: M3 -> 135
Send a message via AIM to Squeak
any ideas?
Squeak is offline   Reply With Quote
Old 07-05-2008, 02:02 PM   #6
mikem7709
My Ride: Z4M Roadster
Are you talking about the inner plastic cover or removing the whole B pillar ?
mikem7709 is offline   Reply With Quote
Old 07-05-2008, 02:08 PM   #7
BreakMyWallet
My Ride: B6 A4
if youre talkin about the cover just unhook the seatbelt.. pull the rear panel back and ull see the b pillar is held in by 2 push in clips on the bottom and metal anchors on the top. pull out the bottom clips then pull down to unhook it from the top
BreakMyWallet is online now   Reply With Quote
Old 07-05-2008, 02:13 PM   #8
SurreyF1
My Ride: BMW
there are two push screws at the bottom of the b pillar underneath the backseat side panels, therefore those need to come off, or at least be popped out a little bit
take the bottom of the back seat out
take the corner leather pieces off (where the seat belts rest on as well as the plastic pieces on top)
there are two screws underneath the armrest on each side, unscrew those
undo the anchors at the bottom
pull
SurreyF1 is offline   Reply With Quote
Old 07-05-2008, 03:30 PM   #9
mikem7709
I was going to suggest an angle grinder.
