Old 05-20-2008, 10:13 PM   #1
e30m3izzle
Banned
My Ride: 1999 323i pal!
What is the heaviest oil I can run in my BMW? m54
I need to know what is the heaviest oil I can run in my bmw. My car is using a ton of oil. I am replacing the ccv valve and hopefully that fixes the problem. If it does not I need to know a back up plan before I even think about replacing the valve stem seals. I have my eye on this oil
This oil is 5w-40. I currently use it in my motorcycle. Im sure you guys have hear of it before. They also make a 15w-40 version which I think will be way too thick,
I am willing to try this oil on my car. Please let me know of any side affects that may occur as a result.
95k miles 01 330ci
I am losing as much as a quart every 500 miles. maybe less. No visible smoke out of the exhaust.
e30m3izzle is offline   Reply With Quote
Old 05-20-2008, 10:23 PM   #2
EvilGenius
Banned User
My Ride: '02 BMW 330Ci
95k miles 01 330ci
Do a search on it, but if you put in anything outside of the recommended, you are going to either ruin your engine components or ruin your performance. Use ONLY BMW LL-01 (longlife) oils.
EvilGenius is offline   Reply With Quote
Old 05-20-2008, 10:37 PM   #3
e30m3izzle
Banned
Well royal purple has come out with 5w-40 for our cars. I dont beleive it is long life approved. Which does not concern me because I would never wait for 15k miles to change my oil anyway.
here is the royal purple. it is the same viscosity as the rotella
http://www.bimmerfest.com/forums/sho...d.php?t=197033 Royal purple
http://www.shell.com/home/Framework?...ellasynth.html Rotella
I searched but could not find anything. I found a stray post of someone using it in their 325 with no problems. I am just trying to figure out why it would be bad to run this oil
Old 05-20-2008, 11:41 PM   #4
Wes328i
My Ride: 2003 325i
Send a message via AIM to Wes328i
Wait, does the owner's manual say 5w-30 or 5w-40 weight? I thought I read that just the other day.
2003 325i
previous: 1999 328i
Wes328i is offline   Reply With Quote
Old 05-20-2008, 11:53 PM   #5
RideZX6R
My Ride: 2003.5 M3 coupe
Send a message via AIM to RideZX6R
RideZX6R is offline   Reply With Quote
Old 05-20-2008, 11:57 PM   #6
Arsevader
My Ride: '90 325i, '02 325it
Originally Posted by RideZX6R View Post
wasn't really that funny.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Arsevader is offline   Reply With Quote
Old 05-21-2008, 01:27 AM   #7
Chris C
My Ride: 2001 325Ci
I use the same oil in my 2001 325ci and I haven't had any problems at all. When I read the manual for my car it mentions 5w30 and 5w40 synthetic oil (BMW LL01.) I wanted to go with a heavier weight. Anyway, the only 5w40 oil that I can regularly find is Shell Rotella T Synthetic. I pick it up at Walmart. It isn't BMW LL01. If you want BMW LL01 oils that are heavier than 5w30, then perform a search for a listing. Off the top of my head there's Mobil 1 0w40, Valvoline 5w40 synthetic, and Castrol 10w60 (the expensive stuff used by E46 M3s.) Good luck.
Chris C is offline   Reply With Quote
Old 05-21-2008, 01:35 AM   #8
jmueller
My Ride: 2001 330ci
maybe you should look into the cause of the oil burning problem. My car was burning lots of oil around 90000 miles, turned out to be the Valve Cover Gasket leaking oil into the engine bay. I could see white smoke when i stopped moving (like at a stop light) and could smell a problem with the car. Replaced the VCG and spark plugs, havent used a drop of oil to this day...
jmueller is offline   Reply With Quote
Old 05-21-2008, 01:43 AM   #9
Tele
My Ride: E46 330XIT MTech II
I'm using Castrol 10w60 (the only way to go) on my Supercharged 330XI.
That oil is actually cheaper than the 5w40 "long life oil" from Castrol.
Tele is offline   Reply With Quote
Old 05-21-2008, 01:50 AM   #10
paraklas
My Ride: ESS TS2 320ci
95k miles 01 330ci
As pointed, look for the cause of oil burn. If you burn as much as you say then a thicker oil will probably not do anything and it will put more stress on the engine specially on the VANOS which works with oil. I was burning as much oil as you and I went up to 15W50 Mobil 1 nascar edition. The only thing that happened was to make the car more sluggish (like I had 2 extra passengers inside all the time).
Old 05-21-2008, 06:27 AM   #11
grafiksguy
My Ride: 2010 328xi
^+1 find the problem. With that kind of oil consumption, thicker oil likely won't help much. At a quart/500mi. are you sure it's not leaking out somewhere?
grafiksguy is offline   Reply With Quote
Old 03-28-2010, 04:49 AM   #12
mujjuman
My Ride: not an E46
I know this is a REALLY old thread, but I'd like to add that I'm having this problem too....
my engine (from a 330ci) burns a quart every 500-600 miles. I've been using only BMW oil 5w30 but now I started topping off with Castrol 5w40
did you ever fix the problem?
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 03-28-2010, 10:27 AM   #13
Hartman
My Ride: 2000 323i
I love oil threads.
"If you don't use an oil that's LL01 approved, your engine will catastrophically self-destruct!!!"
Hartman is offline   Reply With Quote
Old 03-28-2010, 10:36 AM   #14
dfjaws
My Ride: E90 M3 / E86 M Coupe
I just use OEM. It's cheap and guaranteed to work properly in my car.
dfjaws is offline   Reply With Quote
Old 03-28-2010, 11:12 AM   #15
viceversa
My Ride: 2004 325i
Read
http://forum.e46fanatics.com/showthr...400&highlight=
Originally Posted by i_ween View Post
OP: I am sure your English Writing teacher told you this every year, regardless of who s/he was: writing is important. Others will either respect you or ignore you or piss on you if you type like a moron. This isn't an instant message site; it's a forum. We aren't texting each other right now. We are typing messages. Type regular English and people are more likely to respond.
viceversa is offline   Reply With Quote
Old 03-28-2010, 09:41 PM   #16
Minnoe07
My Ride: 2004 BMW 330Ci
My car burns oil with the BMW 5w-30 but not with the Castrol 5w-40. Long life oil doesn't matter if you change it frequently. I don't get why some people freak out about that.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 03-28-2010, 10:37 PM   #17
mujjuman
My Ride: not an E46
exactly. as long as you change it quickly you have nothing to worry about
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 03-29-2010, 03:13 PM   #18
Arsevader
Not true. It's not just the 'long-life' that is important. The LL-01 oils meet the proper shear/viscocity specs whereas other non LL oils do not.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Old 03-29-2010, 03:16 PM   #19
viceversa
My Ride: 2004 325i
This is definitely the wrong weight oil. I do not suggest you follow this.
Old 03-29-2010, 03:20 PM   #20
mujjuman
My Ride: not an E46
Touché
mujjuman
2003 325xi 5MT
sig by Solidjake
