Old 08-04-2008, 01:43 PM   #21
Kenny@JleviSW
Past Site Sponsor
My Ride: JB E90 335
Send a message via AIM to Kenny@JleviSW
Originally Posted by UncleDon View Post
Thanks for the quick reply ... Are Red angel eyes street legal?
Not sure about the other states but in CA, red and blue are illegal (only law enforcement vehicles can run them).
Kenny@JleviSW is offline   Reply With Quote
Old 08-04-2008, 01:48 PM   #22
UncleDon
My Ride: '05 325iT '86 911
So if tail lights are red, does the law state that you can only have red lights on the back of the car?
UncleDon is offline   Reply With Quote
Old 08-04-2008, 02:22 PM   #23
Wreckless
My Ride: E60 528xi
in for the update on the dimming.
Wreckless is offline   Reply With Quote
Old 08-04-2008, 02:40 PM   #24
chay2263
My Ride: 330i Sport Package
NEGATIVE!!!! I wish they were tho cuz I would get some blue ones
chay2263 is offline   Reply With Quote
Old 08-04-2008, 02:46 PM   #25
Kenny@JleviSW
Past Site Sponsor
My Ride: JB E90 335
In CA you can run red or amber in the back and white or amber on the sides and the front. Red and blue are not allowed in the front.
Old 08-04-2008, 07:31 PM   #26
sillieidiot
My Ride: '06 AW 330ci
Originally Posted by Genuine View Post
my only guess off the top of my head would be to tap into the interior dimmer wire, there should be one running from your head unit. splice it from the same wire you ran to your footwell light.
would this work? 5 prong relay,lead to constant +, lead to chassis and AE ground, + lead to AE, lead to ECU box for on w/ ign, lead to footwell lights (now spliced to radio dimmer wire)
it's not going to work. the only way to do that if you just bypass the relay altogether and wire it direct. as the trigger wires for the relay does not need a constant 12v to "trigger" the relay.
Old 08-04-2008, 07:34 PM   #27
sillieidiot
as for dimming the angels. you can just add more resistors to it to dim them down. but you'd probably have to know what you're doing i guess.
Old 08-09-2008, 09:01 AM   #28
jamesthebikeguy
My Ride: Is a ugly POS
Send a message via AIM to jamesthebikeguy
subscribed
jamesthebikeguy is offline   Reply With Quote
Old 08-09-2008, 09:03 AM   #29
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
This sounds like a stupid question, but can you actually dim LED's? I thought that wasn't possible, or if so you would damage them...
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 09-05-2008, 06:48 PM   #30
Bimmer37
My Ride: 2003 BMW 330i
Any update on this install? Did it work? Any pictures?
Was this ever installed?
Bimmer37 is offline   Reply With Quote
Old 09-05-2008, 11:13 PM   #31
sillieidiot
yes you can. just put more resistors on the circuit and it will essentially dim the LEDs. that's what a rheostat is pretty much. it's like a variable resistor (well actually is).
Old 09-05-2008, 11:15 PM   #32
sillieidiot
maybe i'll get one later and wire it up for you guys to see. i will do it outside of the car though, too lazy to run it inside the car when i don't even want them.
Old 09-08-2008, 09:25 AM   #33
chop999i999
My Ride: e46 M3
Any updates on this?
Carbon Black/Black. Mods: 19" iforged swifts, Borla Catback, JVT Headers, Depo smoke corners, Orion V2 angel eyes, Viper 2way alarm, Full Alpine speakers, sub in custom box and double din Alpine DVD with mybimmer.net bezel, H&R RSS Coilovers, Vorsteiner Double sided carbon fiber hood. More to come...
chop999i999 is offline   Reply With Quote
Old 09-08-2008, 04:26 PM   #34
sillieidiot
i haven't done it yet. been lazy as hell lol
Old 09-11-2008, 03:00 PM   #35
HighVoltage
My Ride: 2007 335i
One thing to be careful of, is to make sure the rheostat (potentiometer) is rated for the power (W). Although with LEDs it wont be much...
Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive...like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
HighVoltage is offline   Reply With Quote
Old 09-11-2008, 09:00 PM   #36
sillieidiot
yea, it's like 1w for all 4 rings i think. iono i didn't measure the draw yet or anything
Old 09-25-2008, 10:33 PM   #37
turbrorx7
My Ride: E36M3, R1 RX7
Send a message via AIM to turbrorx7
updates?
97 Cosmos M3
93 R1 RX7
Pettit built Engine with Large Streetport
T04R
465hp/390tq
0-60 in 3.6 seconds
turbrorx7 is offline   Reply With Quote
Old 01-19-2009, 10:50 AM   #38
Fair Witness
My Ride: 2004 BMW M3
Has anyone done this that can provide a How-To? Also, if you insert a rheostat into the mix, will that prevent the fade on/off from working when you lock your car?
Fair Witness is offline   Reply With Quote
Old 01-19-2009, 05:35 PM   #39
swoobies
My Ride: '03 M3
ive always found the dimness of the oem ones to look crappy but to each their own i guess
swoobies is offline   Reply With Quote
Old 01-30-2009, 12:32 AM   #40
easyIsle
My Ride: 02 330i
I'm getting an AE kit soon .. I wouldnt mind DIY'ing this:
Using a standard 12volt automotive relay, some connectors, wire, and a rheostat thats rated properly. (I dont want to guess the rating/resistance range. Would have to measure the circuit first and play with some resistors)
But it would be wired as such:
- When the relay is not powered, it provides power straight through to the AE as it does now (so fade on/off will still work)
- 12V Trigger input to the relay would be headlight low beam power
- When your headlights turn on, the relay switches- wired so it powers your AE's not with 12v, but 12v sent through a rheostat installed in the cabin, first.
When you turn on your lights, the brightness you adjust with the rhetrostat dial applies. When your lights are off, it will be powered straight through for full brightness.
This can obviously be varied to suit your desires but its not difficult for anyone to do.
Much easier than transistor switched circuits, anyway
-Owner of the biggest electronic kit I could find on the interweb
easyIsle is offline   Reply With Quote
