Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 5.00 average.
Old 08-14-2009, 10:16 AM   #461
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
Today's Daily special (August 14, 2009) is Chemical Guys Citrus Wash & Gloss.
Regular Price for 16 oz is $7.99. Today's price is $5.99!
Regular Price for 128 oz is $22.99. Today's price is $17.25!
  • One of our best selling shampoos, lots of foam, great lubricity, strong cleaning power
  • Can be used in high concentration to strip off previous coats of protection from a sealant or wax
  • Can be used very diluted to maintain your coats of protection during regular maintenance washes
  • Works great in a foam gun, such as the Gilmour Foamaster II
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Old 08-15-2009, 10:38 AM   #462
Today's Daily special (August 15, 2009) is Gilmour Flexogen 8 ply Hose.
Regular Price for 50 feet is $34.99. Today's price is $26.34!
Old 08-16-2009, 09:53 AM   #463
Today's Daily special (August 16, 2009) is Dodo Juice Diamond White Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • The Dodo Juice Diamond White hard carnauba wax is designed to work exceptionally well on lighter colored vehicles
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Old 08-17-2009, 02:42 PM   #464
Today's Daily special (August 17, 2009) is Lake Country Black Finishing Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
  • A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
  • Also can be used to apply a paint cleaner, glaze or sealant
  • Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old 08-18-2009, 10:16 AM   #465
Today's Daily special (August 18, 2009) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.49!
  • Foam based formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry microfiber towel
  • For optimal results, give a final wipe down with the low nap, glass microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old 08-19-2009, 06:24 PM   #466
Today's Daily special (August 19, 2009) is Lake Country Ulti-Mit.
Regular Price is $15.99. Today's price is $11.99!
  • A paint safe foam wash mitt that has two different surfaces to tackle various areas of your vehicle
  • Holds large amounts of suds and water which helps minimize marring the paints finish
  • Use the red cubed side to wash your paint, as it is the softer of the two sides
  • Use the black side to clean stubborn contamination off of lower panels, tires, wheel wells and more
  • Highly recommended to be used with a Grit Guard insert to easily release contamination
  • Will outlast natural fiber mitts due to the durable foam design
Old 08-20-2009, 07:48 AM   #467
Today's Daily special (August 20, 2009) is Optimum (OPT) Tire Shine.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
  • Water based tire dressing that applies easily and does not sling onto your paint
  • Can be applied in multiple layers for a glossier look or buffed down to a matte finish
  • We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Old 08-21-2009, 02:57 PM   #468
Today's Daily special (August 21, 2009) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
  • Remove embedded surface contamination that does not come off during the washing process
  • Medium grade bars will remove contamination quickly, however it may result in micro-marring
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old 08-22-2009, 09:42 AM   #469
Today's Daily special (August 22, 2009) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.49!
  • Perfect maintenance shampoo that enhances gloss and depth
  • Lots of lubricity and slickness to help minimize adding imperfections
  • Concentrated formula means only a little product is needed per wash
  • Best used with a grout sponge or sheepskin wash mitt
Old 08-24-2009, 05:40 PM   #470
Today's Daily special (August 24, 2009) is Chemical Guys M-Seal Pure Sealant.
Regular Price for 16 oz is $19.99. Today's price is $14.99!
  • One of the best bang for the buck, pure sealants for under $20
  • Easy to apply and remove when applied properly, which is as thin as possible
  • M-Seal not only protects your paint, but leaves behind a great shine and sharp reflections
  • Best applied with a foam applicator pad and removed with a microfiber towel
  • When using a buffer, best applied with a blue fine finishing pad
Old 08-25-2009, 08:34 AM   #471
Today's Daily special (August 25, 2009) is Poorboy's World Super Swirl Remover 2.5 (SSR 2.5).
Regular Price for 16 oz is $15.99. Today's price is $11.99!
  • Designed to remove a majority of imperfections in the clear coat
  • Removes moderate to deep swirls, oxidation, water spots, scratches and other imperfections
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Poorboy's SSR 2.5 should be followed up with a finishing polish for maximum results
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG
  • When using a buffer, best applied with an orange light cutting pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Old 08-26-2009, 03:34 PM   #472
Today's Daily special (August 26, 2009) is Poorboy's World Spray & Wipe (S&W).
Regular Price for 16 oz is $8.99. Today's price is $6.74!
Regular Price for 32 oz is $14.99. Today's price is $11.24!
Regular Price for 128 oz is $32.99. Today's price is $26.10!
  • Extremely versatile product that is a favorite amongst professional detailers
  • Quick and easy waterless wash product for lightly contaminated vehicles
  • Excellent clay bar lubricant, even diluted at a 1:1 ratio with distilled water
  • Perfect product to keep in your glove compartment to clean up emergency bird bombs, sap, tar, etc.
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
  • For maximum efficiency and convenient storage use in a 4oz pump spray bottle
Old 08-27-2009, 01:43 PM   #473
Today's Daily special (August 27, 2009) is P21S Concours Carnauba Wax.
Regular Price for 6.2 oz is $31.99. Today's price is $26.05!
  • Very easy to apply and remove carnauba wax that looks great on any color vehicle
  • Includes an applicator pad that conveniently stores inside the top of the wax
  • Unlike other waxes, P21S Concours Carnauba wax will not stain your trim
  • Excess product should be removed with a quality microfiber towel
  • P21S recommends prepping the surface with Paintwork Cleanser for best results
Old 08-29-2009, 10:05 AM   #474
Today's Daily special (August 29, 2009) is Menzerna Final Polish II (FPII).
Regular Price for 16 oz is $18.99. Today's price is $14.42!
Regular Price for 32 oz is $29.99. Today's price is $22.49!
  • A great finishing polish, designed to remove hazing, holograms and light surface imperfections
  • Restores depth and gloss to the paints finish and is easy to work with
  • Easy to remove when worked into the paint properly
  • Recommended application is using a buffer with a white polishing pad
Old 08-30-2009, 11:06 AM   #475
Today's Daily special (August 30, 2009) is Clear Kote Red Moose Machine Glaze.
Regular Price for 16 oz is $17.99. Today's price is $13.49!
  • Enhance the gloss and depth of any color paint, while hiding minor imperfections
  • We recommend applying a carnauba wax on top of Red Moose Glaze
  • To avoid bonding issues, we do not recommend applying a sealant on top of Red Moose Glaze
  • We recommend using a foam applicator pad along with some elbow grease for application
  • Remove Red Moose Glaze with a quality microfiber towel
Old 08-31-2009, 01:03 PM   #476
Today's Daily special (August 31, 2009) is 303 Aerospace Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.74!
Regular Price for 32 oz is $22.99. Today's price is $17.24!
Regular Price for 128 oz is $54.99. Today's price is $41.24!
  • Strong UV protection on vinyl, rubber, leather and plastic
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, and leather seats
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Old 09-01-2009, 10:07 AM   #477
Today's Daily special (September 1, 2009) is Poorboy***039;s World Trim Restorer.
  • Restores faded, neglected trim that has been over exposed to the elements
  • Works best on rubber, vinyl and plastic trim
  • Apply thicker for some gloss or buff dry to desired matte finish
  • For maximum results, prep the surface you plan on restoring with a degreaser like Total Auto Wash
Old 09-02-2009, 03:52 PM   #478
Today's Daily special (September 2, 2009) is DI Accessories Sheepskin Wash Mitt.
Regular Price is $9.99. Today's price is $7.49!
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Old 09-03-2009, 03:15 PM   #479
Today's Daily special (September 3, 2009) is Chemical Guys Fabric Clean.
Regular Price for 16 oz is $6.99. Today's price is $5.24!
  • Powerful concentrated fabric cleaner and deodorizer that works wonders on carpet and upholstery
  • Dilute down to an 8:1 ratio with distilled water, or use full strength for stubborn stains
  • We recommend using a brush to agitate stubborn stains in fabric and carpets
  • For easy dilution and usability, we recommend a 22 oz spray bottle
Old 09-04-2009, 12:44 PM   #480
Today's Daily special (September 4, 2009) is Plexus Plastic Polish, Cleaner & Protectant.
Regular Price for 13 oz is $17.99. Today's price is $14.49!
  • Clean, polish and protect all of your plastic surfaces, leaving behind anti-static properties
  • Ideal for clear plastics, such as gauges, headlights, tail lights, clear bras and plastic windows
  • For best application, apply to a plush microfiber towel, then gently wipe the plastic
Rate This Thread
