Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 5.00 average.
Old 10-20-2009, 09:17 AM   #521
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
Today's Daily special (October 20, 2009) is Clay Magic Fine Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $20.80!
  • Fine grade clay bar that is one of the standards in the industry for enthusiasts and professionals
  • Remove embedded surface contamination that does not come off during the washing process
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old 10-21-2009, 02:19 PM   #522
Today's Daily special (October 21, 2009) is Lake Country Black Finishing Pad.
Regular Price for 6.5" is $9.99. Today's price is $7.49!
  • A finishing pad, designed to bring the paint to its maximum depth and gloss with a finishing polish
  • Also can be used to apply a paint cleaner, glaze or sealant
  • Menzerna PO85RD is one of the most popular polishes to use with a black finishing pad
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old 10-22-2009, 11:39 AM   #523
Today's Daily special (October 22, 2009) is Chemical Guys Vertua-Bond 408.
Regular Price for 16 oz is $26.99. Today's price is $20.24!
  • Properly preps your paints surface for applying a sealant or wax to your paint
  • Ensure you achieve the maximum durability out of your protection by using Vertua-Bond 408
  • Apply with a foam applicator pad and remove with a clean microfiber towel
Old 10-23-2009, 09:57 AM   #524
Today's Daily special (October 23, 2009) is Optimum (OPT) Tire Shine.
Regular Price for 17 oz is $11.99. Today's price is $8.99!
Regular Price for 128 oz is $35.99. Today's price is $26.99!
  • Water based tire dressing that applies easily and does not sling onto your paint
  • Can be applied in multiple layers for a glossier look or buffed down to a matte finish
  • We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Old 10-24-2009, 11:42 AM   #525
Today's Daily special (October 24, 2009) is 303 Fabric & Vinyl Cleaner.
Regular Price for 32 oz is $14.99. Today's price is $11.24!
Regular Price for 128 oz is $39.99. Today's price is $29.99!
  • Cleans carpets, upholstery, vinyl, rubber, leather, plastic and much more
  • Safely removes oil, grease, ink, coffee, tea, wine, juice, blood, and tons more
  • Powerful concentrated formula makes for a great value
  • Dilute up to a 30:1 ratio! That's only $0.01 per ounce of cleaning solution (from 128 oz size)
  • Works in carpet extractors
  • Maximum cleaning ability is achieved when used with warm water
  • Best results achieved when agitated with a brush or damp towel
  • Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Old 10-25-2009, 11:14 AM   #526
Today's Daily special (October 25, 2009) is Chemical Guys Window Clean.
Regular Price for 16 oz is $5.99. Today's price is $4.49!
  • A tint safe window cleaner that cuts through grime and leaves windows streak free
  • Best applied with a microfiber towel and followed up with a glass microfiber towel
Old 10-26-2009, 09:04 AM   #527
Today's Daily special (October 26, 2009) is Poorboy & World Spray & Rinse.
Regular Price for 32 oz is $15.99. Today's price is $11.99!
  • Powerful, acidic wheel cleaner designed to work best on alloy, clear coated wheels
  • Dilute down to a 6:1 ratio for regular maintenance, use a stronger concentration as needed
  • Works best when an E-Z Detail Brush is used in conjunction with PBW Spray & Rinse
  • For easy dilution and usability, we recommend a 22 oz spray bottle
  • Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
Old 10-27-2009, 09:29 AM   #528
Today's Daily special (October 27, 2009) is Poorboy's World Leather Stuff.
Regular Price for 16 oz is $17.99. Today's price is $13.49!
  • An amazing one step solution for leather. Cleans, lightly conditions, and UV protects!
  • Restores and leaves behind a pleasant leather scent
  • Easy to apply and remove, while leaving behind a like new matte finish
  • Also works well on vinyl and rubber surfaces throughout the vehicle and home
  • Best applied with a terry cloth applicator and wiped to desired finish with a microfiber towel
Old 10-28-2009, 11:18 AM   #529
Today's Daily special (October 28, 2009) is Optimum (OPT) Opti-Bond Tire Gel.
Regular Price for 128 oz is $35.99. Today's price is $27.81!
  • Gel based tires dressing that applies easily and does not sling onto your paint
Old 10-29-2009, 08:07 AM   #530
Today's Daily special (October 29, 2009) is Klasse All In One (AIO).
Regular Price for 500 ml is $27.99. Today's price is $21.28!
Regular Price for 1000 ml is $39.99. Today's price is $30.40!
  • A must have for anyone looking for an all in one (AIO) product that cleans and protects
  • A strong chemical cleaner that can remove oxidation, water spots, and other surface imperfections
  • Leaves behind an acrylic layer of protection that lasts months
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Can be applied with a foam applicator pad and removed with a quality microfiber towel
  • When using a buffer, best applied with a white polishing pad or black finishing pad
Old 10-29-2009, 12:04 PM   #531
Old 10-30-2009, 09:20 AM   #532
Today's Daily special (October 30, 2009) is Menzerna Finishing Touch Glaze (FTG).
Regular Price for 16 oz is $18.99. Today's price is $14.42!
Regular Price for 32 oz is $23.99. Today's price is $17.27!
  • A glaze that utilizes kaolin clay and oil fillers to help improve the depth and gloss of your paint
  • Can mask minor surface imperfections in the paint
  • Most commonly applied with a black finishing pad when used on a buffer
Old 10-31-2009, 08:48 AM   #533
Today's Daily special (October 31, 2009) is Clear Kote Red Moose Machine Glaze.
Regular Price for 16 oz is $17.99. Today's price is $13.13!
  • Enhance the gloss and depth of any color paint, while hiding minor imperfections
  • We recommend applying a carnauba wax on top of Red Moose Glaze
  • To avoid bonding issues, we do not recommend applying a sealant on top of Red Moose Glaze
  • We recommend using a foam applicator pad along with some elbow grease for application
  • Remove Red Moose Glaze with a quality microfiber towel
Old 11-01-2009, 09:52 AM   #534
Today's Daily special (November 1, 2009) is Chemical Guys Grime Reaper.
Regular Price for 16 oz is $7.99. Today's price is $5.91!
Regular Price for 128 oz is $24.99. Today's price is $17.74!
  • One of our most powerful degreasers available, designed to easily cut through contamination
  • Powerful concentrated solution can be diluted down 8:1 with water and still maintain effectiveness
  • Perfect to degrease wheel wells, engine bays, door jambs, tires and much more
Old 11-02-2009, 04:46 PM   #535
Today's Daily special (November 2, 2009) is Lake Country 4 Inch Orange Light Cutting Pad.
Regular Price for 4" is $4.99. Today's price is $3.59!
  • A light cutting pad designed to remove moderate swirls and scratches with an abrasive polish
  • Menzerna Super Intensive Polish (SIP) is one of the most popular products to use with an orange pad
Old 11-03-2009, 12:37 PM   #536
Today's Daily special (November 3, 2009) is Poorboy's World Quick Detailer Plus (QD+).
Regular Price for 16 oz is $12.99. Today's price is $9.22!
  • A great quick detailer to be used on top of any sealant or wax for added depth and gloss
  • A perfect maintenance product to use after a wash to help prolong your coat(s) of protection
  • Easy to apply and remove without streaking when applied correctly
  • Best applied with a plush microfiber towel to minimize any micro-marring in the paint
  • For convenient storage and easy, even application, we recommend using a 4oz pump spray bottle
Old 11-04-2009, 11:45 AM   #537
Today's Daily special (November 4, 2009) is Poorboy's World Super Swirl Remover 1 (SSR 1).
Regular Price for 16 oz is $15.99. Today's price is $11.67!
  • Designed to remove light surface imperfections and improve the depth and gloss of the paint
  • Removes light swirls, oxidation, water spots, light surface scratches and other minor imperfections
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG
  • When using a buffer, best applied with a white polishing pad or black fine finishing pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Old 11-05-2009, 12:25 AM   #538
Today's Daily special (November 5, 2009) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.48!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Old 11-05-2009, 11:13 AM   #539
Old 11-06-2009, 02:11 PM   #540
Today's Daily special (November 6, 2009) is Poorboy's World Bug Squash.
Regular Price for 16 oz is $10.99. Today's price is $7.80!
Regular Price for 32 oz is $15.99. Today's price is $11.83!
  • Paint safe, pre-wash degreaser designed to break up stubborn contamination prior to washing
  • Helps loosen bug splatter, tar, sap, bird droppings, and other forms of contamination
  • Concentrated solution which should be diluted down to a 3:1 ratio with distilled water
  • Remember to protect the areas you use Bug Squash on with a sealant or wax
  • For easy dilution and usability, we recommend a 22 oz spray bottle or a convenient 4 oz pump bottle
Rate This Thread
