Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 5.00 average.
Old 11-28-2009, 01:08 PM   #561
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
Today's Daily special (November 28, 2009) is Dodo Juice Double Wax Kit.
Regular Price for 2 x 200 ml is $159.99. Today's price is $133.19!
  • A combination of a Dodo Juice hard and soft wax for the best of both worlds
  • Apply a coat of the hard wax for a base and longer durability for your protection
  • Top the hard coat with a layer or more of the soft wax for additional depth and gloss
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • For maximum results, allow for 12 - 24 hours between coats
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Old 11-28-2009, 01:59 PM   #562
ObsessedM3
My Ride: 13 M3C
Always order from you guys--great website and very fast!!!
Got a problem that I need help with. My E92 M3 18's are horrible for collecting brake dust. The ONLY reason I wash the car every weekend is because of the brake dust. Short of replacing the brake pads are there any devices that could be put on an end of a drill to get in between, but also reach all the way in?
ObsessedM3 is offline   Reply With Quote
Old 11-29-2009, 01:24 PM   #563
Thank you for the support I really appreciate it! I understand how tough the brake dust can be. There is some drill bit brushes that I've seen but we don't carry it. My only concern with them is that your high speed drill is buffing in the contaminants. This will create a lot of ultra fine scratches and over time the wheels may look hazy. I would suggest cleaning the wheels first with a product like the Chemical Guys Diablo Gel Rim and Wheel Cleaner Concentrated Suspension. It's safe on all wheels and highly effective at full strength or diluted down roughly 3:1. After that apply a coat of protection with the Poorboy's World Wheel Sealant or other quality sealant. They help prevent the high temperature brake dust from bonding to the wheels. If desired you can use the DI Accessories E-Z Detail Brush to help get in those tough to reach areas. Let me know if you have other questions.
Greg @ DI
Old 11-29-2009, 01:25 PM   #564
Today's Daily special (November 29, 2009) is Dodo Juice Supernatural Wax.
Regular Price for 250 ml is $199.99. Today's price is $145.99!
Regular Price for 30 ml is $29.99. Today's price is $24.97!
Regular Price for v2 200 ml is $129.99. Today's price is $92.29!
  • One of our finest carnauba waxes we've ever tested, competes with more expensive high end waxes
  • Amazing gloss and depth that makes any color look liquid wet and shimmering
  • One of the easiest waxes to apply and remove, even when applied too thick
  • Can be applied with a foam applicator pad or literally with your bare hands
  • We recommend using a plush microfiber towel to remove Dodo Juice Supernatural
Old 11-30-2009, 08:06 PM   #565
ObsessedM3
My Ride: 13 M3C
Greg @ DI
How long do you think I can get in between polishes? Do you think this sealant should be used once a month?
The only reason I ask, is because I probably will pull each tire off and clean them like they are suppose to and then apply the sealant you recommended, but just don't want to do that every month.
Old 12-01-2009, 07:20 PM   #566
Today's Daily special (December 1, 2009) is DI Microfiber Super Gripper.
Regular Price for 16" x 16" is $5.99. Today's price is $4.46!
  • The ideal towel for removing light dusting on smooth surfaces
  • Attract and cling to dust with our grippiest towel we've tested to date
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
Old 12-01-2009, 07:24 PM   #567
If you clean the wheels at least once a month you probably don't have to polish them often at all, maybe just the occasional spot treatment. The durability of sealants on wheels varies tremendously depending on so many conditions, but a month is around the right ball park figure. You don't have to have the wheels off though to do a pretty good application. You may also want to look at the Optimum (OPT) Opti-Seal. It's a strong sealant you spray on and it dries clear. I have also used this on the wheels because it's so much faster. Just mist it on very lightly and spread it evenly with a clean cloth/app.
Greg @ DI
Old 12-02-2009, 04:28 PM   #568
Today's Daily special (December 2, 2009) is Lake Country Ulti-Mit.
Regular Price is $15.99. Today's price is $11.91!
  • A paint safe foam wash mitt that has two different surfaces to tackle various areas of your vehicle
  • Holds large amounts of suds and water which helps minimize marring the paints finish
  • Use the red cubed side to wash your paint, as it is the softer of the two sides
  • Use the black side to clean stubborn contamination off of lower panels, tires, wheel wells and more
  • Highly recommended to be used with a Grit Guard insert to easily release contamination
  • Will outlast natural fiber mitts due to the durable foam design
Old 12-03-2009, 04:50 PM   #569
Today's Daily special (December 3, 2009) is Lexol Leather Conditioner.
Regular Price for 16.9 oz is $9.99. Today's price is $7.82!
  • Condition your leather to maintain a soft and supple, like new feel with a matte finish
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Best applied just after cleaning your leather with Lexol pH Leather Cleaner
  • Best applied with a terry cloth applicator and wiped to desired finish with a microfiber towel
Old 12-04-2009, 08:43 PM   #570
ObsessedM3
My Ride: 13 M3C
Greg,
I didn't like this foam pad as much as I like your wool mits. The problem I had with the foam is the little squares would come apart only have 4 times. When you are finished with the wash mit or the foam mit do you rinse them out completely with water or do you just ring them out as much as possible and allow to air dry?
Old 12-05-2009, 03:19 PM   #571
Greg,
Thank you for the feedback I try to keep track of any possible problems with products. I've pretty good luck with this mitt and I even still have my original prototype that is in really good shape. I do rinse it out after each use to help get the excess shampoo and grit out of the mitt. I wring it out thoroughly and let it air dry. I don't get all the water out but certainly the majority of it. It helps extend the life of any mitt. If you use it on certain areas (wheel wells, really low bumpers, etc.) there could be a sharp surface that is causing those tears. If you use it on smooth flat surface it shouldn't rip under these normal conditions. If you have any other specific questions or concerns please feel free to shoot me a PM or e-mail about it.
Greg @ DI
Old 12-05-2009, 03:19 PM   #572
Today's Daily special (December 5, 2009) is DI Microfiber reTHICKulous Towel.
Regular Price for 16" x 16" is $7.99. Today's price is $6.05!
  • Thickest, softest, most plush towel we carry.
  • Over 3x thicker than regular microfiber towels.
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent.
Old 12-06-2009, 10:06 AM   #573
Today's Daily special (December 6, 2009) is Dodo Juice Hard Candy Hard Wax.
Regular Price for 250 ml is $64.99. Today's price is $50.49!
Regular Price for 30 ml is $13.99. Today's price is $10.55!
  • A Dodo Juice hard carnauba wax designed to work on any colored vehicle, light or dark
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
Old 12-07-2009, 08:19 PM   #574
Today's Daily special (December 7, 2009) is Meguiar's Quik Interior Detailer.
Regular Price for 16 oz is $6.99. Today's price is $5.21!
  • Clean and protect plastics, vinyl, leather, rubber, metal, gauges, audio equipment and more
  • The one interior quick detailer you'll need to keep your car looking and smelling fresh
  • Best applied with a quality microfiber towel
  • Pick up a 4 oz pump spray bottle to easily store this in your glove compartment for emergency clean ups
Old 12-10-2009, 06:08 PM   #575
Today's Daily special (December 10, 2009) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.31!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Old 12-11-2009, 04:16 PM   #576
Today's Daily special (December 11, 2009) is Wheel Wax Wheel Wax.
Regular Price for 8 oz is $14.99. Today's price is $12.28!
  • Protects your wheels from stubborn contamination and brake dust build up
  • Easily maintain your protected wheels with automotive shampoo and water
  • Apply Wheel Wax to a clean wheel with a foam applicator pad in thin coats
  • Clean, restore and protect your wheels in one easy step
Old 12-12-2009, 11:22 AM   #577
Today's Daily special (December 12, 2009) is Dodo Juice Diamond White Hard Wax.
Regular Price for 250 ml is $69.99. Today's price is $54.72!
  • A Dodo Juice hard carnauba wax designed to work exceptionally well on lighter colored vehicles
Old 12-13-2009, 11:18 AM   #578
Today's Daily special (December 13, 2009) is DI Accessories Sheepskin Wash Mitt w/no thumb.
Regular Price is $8.99. Today's price is $6.65!
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Old 12-14-2009, 08:15 PM   #579
Today's Daily special (December 14, 2009) is Poorboy's World Natty's Red Paste Wax.
Regular Price for 8 oz is $21.99. Today's price is $16.05!
  • One of the top performing carnauba waxes for under $25 and looks outstanding on any color
  • Leaves behind a ton of depth and gloss, especially when multiple coats have been applied
  • An 8 oz jar will last dozens of applications when applied correctly
  • Best applied with a foam applicator pad and removed with a microfiber towel
Old 12-15-2009, 09:37 AM   #580
Today's Daily special (December 15, 2009) is Meguiar's Ultra-Cut Compound M105.
Regular Price for 32 oz is $26.99. Today's price is $20.70!
Regular Price for 128 oz is $74.99. Today's price is $59.70!
  • Very effective at cutting through deeper imperfections
  • Finishes down nicely, but we still recommend a finishing polish after 105
  • Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Rate This Thread
