Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 5.00 average.
Old 09-07-2010, 09:13 AM   #781
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
Today's Daily special (September 7, 2010) is Stoner Tarminator.
Regular Price for 10 oz is $5.99. Today's price is $4.46!
  • Safely and effectively remove tar, grease and sap from painted surfaces
  • Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
  • Remember to protect the areas you use Tarminator on with a sealant or wax
Old 09-08-2010, 11:12 AM   #782
Today's Daily special (September 8, 2010) is P21S Windshield Wash Booster.
Regular Price for 250 ml is $8.99. Today's price is $6.56!
  • Increase the cleaning power of your current windshield washer fluid
  • Helps improve visibility, which helps you drive safer in poor weather conditions
  • Simply pour some P21S Windshield Washer Booster into your existing washer fluid!
Old 09-10-2010, 11:16 AM   #783
Today's Daily special (September 10, 2010) is Chemical Guys Go Green! Waterless Wash.
Regular Price for 16 oz is $12.99. Today's price is $9.68!
  • Our most versatile spray on product that cleans, polishes, enhances gloss and protects your paint
  • Use as a waterless wash to remove a light coating of contamination without marring your finish
  • Perfect option to keep in your glove box to clean up bird droppings and other contamination
  • To minimize adding swirls and imperfections, use a plush microfiber towel to wipe and buff
  • To maximize your product, we recommend using a 4oz pump spray bottle to dispense ONE
Old 09-12-2010, 12:08 AM   #784
Today's Daily special (September 12, 2010) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.43!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old 09-13-2010, 02:16 PM   #785
Today's Daily special (September 13, 2010) is Poorboy's World Super Swirl Remover 1 (SSR 1).
Regular Price for 16 oz is $15.99. Today's price is $11.35!
  • Designed to remove very light surface imperfections or hazing and improve the depth and gloss of the paint
  • Can be applied in either the shade or in the sun, making the polishes great for mobile detailers
  • Works best when applied with a quality buffer, such as a Porter Cable 7424 or Flex XC3401VRG, typically using a white or black pad
  • For accurate product dispensing, we recommend using a 4oz dispenser bottle or 8oz yorker bottle
Old 09-14-2010, 05:59 PM   #786
Today's Daily special (September 14, 2010) is Gilmour Foamaster II Foam Gun.
Regular Price for 1/4 Gallon Tank is $59.99. Today's price is $43.79!
  • An outstanding wash tool that can help minimize adding imperfection and adds in some fun
  • Pre-soak your car with a layer of sudsy shampoo before ever touching your car with your wash mitt
  • Helps get shampoo in those hard to reach areas, such as in the wheel wells and engine bay
  • Change the dilution ratio with the spin of a dial
Old 09-15-2010, 02:47 PM   #787
Today's Daily special (September 15, 2010) is Klasse All In One (AIO).
Regular Price for 500 ml is $27.99. Today's price is $21.28!
Regular Price for 1000 ml is $39.99. Today's price is $30.40!
  • A must have for anyone looking for an all in one (AIO) product that cleans and protects
  • A strong chemical cleaner that can remove oxidation, water spots, and other surface imperfections
  • Leaves behind an acrylic layer of protection that lasts months
  • Easy to apply and remove when applied properly, which is as thin as possible
  • Can be applied with a foam applicator pad and removed with a quality microfiber towel
  • When using a buffer, best applied with a white polishing pad or black finishing pad
Old 09-16-2010, 01:47 PM   #788
Today's Daily special (September 16, 2010) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.31!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Old 09-17-2010, 04:50 PM   #789
Today's Daily special (September 17, 2010) is Chemical Guys Jetseal 109.
Regular Price for 16 oz is $39.99. Today's price is $28.39!
  • One of our best selling sealants due to how well rounded of a product Jet Seal 109 is
  • Offers wax like depth and gloss, strong protection, ease of use, slick surface, and good durability
  • Works great on any colored vehicle, light, dark, metallic or non-metallic
  • For maximum durability, allow the sealant to cure for 24 hours prior to applying another coat
  • Best applied with a foam applicator pad and removed with a microfiber towel
  • When using a buffer, best applied with a blue fine finishing pad
Old 09-18-2010, 12:23 PM   #790
Today's Daily special (September 18, 2010) is DI Accessories Polishing Pal.
Regular Price is $12.99. Today's price is $9.82!
  • Even distribution of any product and better results from hand applications
  • Get the same variety in cutting and finishing pads as you would with a buffer using 4" pads!
Old 09-20-2010, 07:01 PM   #791
Today's Daily special (September 20, 2010) is Meguiar's Final Inspection M34.
Regular Price for 16oz is $7.99. Today's price is $5.67!
Regular Price for 128oz is $26.99. Today's price is $19.16!
  • Great cleaning quick detailer to remove a light dusting, finger prints and light contamination safely
  • Use after polishing to wipe down dust residue or after a sealant or wax to ensure there is no excess product left behind
  • We recommend using M34 with an Ultra Plush Microfiber Towel
Old 09-21-2010, 08:25 PM   #792
Today's Daily special (September 21, 2010) is Meguiar's All Purpose Cleaner D101.
Regular Price for 128 oz is $13.99. Today's price is $10.07!
  • Perfect for carpet, upholstery, vinyl and leather surfaces
  • Concentrated formula works effectively at a 10:1 dilution ratio
  • Agitate stubborn stains with a medium bristled brush for maximum results
  • Exceptional value for detailers and enthusiasts
  • Dilute and dispense using a 22 oz trigger spray bottle
Old 09-23-2010, 02:02 PM   #793
Today's Daily special (September 23, 2010) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.43!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Old 09-24-2010, 12:02 PM   #794
Today's Daily special (September 24, 2010) is Chemical Guys M-Seal.
Regular Price for 16 oz is $19.99. Today's price is $14.89!
  • One of the best bang for the buck, pure sealants for under $20
  • M-Seal not only protects your paint, but leaves behind a great shine and sharp reflections
Old 09-24-2010, 04:14 PM   #795
Roxlo
My Ride: e46 325i
How does this work vs. Optimum opti-seal, anyone?
Roxlo is offline   Reply With Quote
Old 09-26-2010, 09:42 AM   #796
Similar products in what they do, but not how they do it. The Chemical Guys M-Seal is a pure sealant, meaning it simply protects the paint for several months and enhances the shine. The M-Seal is applied like all traditional sealants. The Opti-Seal is the same as it just protects the paint. However opti-seal is ultra concentrated and it's application is different. .5 ounces (or less) is all you need for a full coat of protection on your car. Spray it on the paint or your applicator and buff it on with light pressure and you are all done. It dries totally clear so no removal is necessary. Both products have a nice shine and durable protection so you can't go wrong either way.
Let me know if you have any other questions.
Old 09-26-2010, 09:42 AM   #797
Today's Daily special (September 26, 2010) is Chemical Guys 50/50 Limited Series Concourse Paste Wax.
Regular Price for 8 oz is $59.99. Today's price is $46.25!
  • Bang for the buck, one of the best carnauba waxes we offer
  • Offers outstanding depth and gloss as well as sharp reflections on any colored vehicle, light, dark, metallic or non-metallic
Old 09-27-2010, 06:36 PM   #798
Today's Daily special (September 27, 2010) is Menzerna Power Lock Polymer Sealant.
Regular Price for 16 oz is $29.99. Today's price is $21.59!
Regular Price for 32 oz is $49.99. Today's price is $35.99!
  • First true sealant produced by Menzerna
  • Long durable protection with a great shine!
  • Long lasting protection from durable polymer formula
  • Deep and glossy shine while easy to apply
Old 09-28-2010, 05:02 PM   #799
Today's Daily special (September 28, 2010) is Menzerna PO85RD Polish.
Regular Price for 32 oz is $34.99. Today's price is $25.54!
  • When you want the absolute maximum depth and gloss, finish your polishing with PO85RD
  • Works best after correcting paint imperfections with more aggressive polishes
  • Easy to work with, with long work times and easy removal when properly broken down
  • Most commonly applied with a black or blue finishing pad when used on a buffer
Old 09-28-2010, 08:33 PM   #800
ObsessedM3
My Ride: 13 M3C
You had mentioned a product that is a spray wax for these difficult rims on the E92 M3, but I couldn't find it on your website?
ObsessedM3 is offline   Reply With Quote
Rate This Thread
