Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 5.00 average.
Old 04-23-2013, 07:04 AM   #1481
Greg@DetailedImage.com
Clean Shine Protect Expert
My Ride: is clean & protected
Today's Daily special (April 23, 2013) is Meguiar's DA Microfiber Correction Compound.
Regular Price for 16 oz is $18.99. Today's price is $14.15!
Regular Price for 32 oz is $34.99. Today's price is $25.54!
Regular Price for 128 oz is $84.99. Today's price is $63.32!
  • Superior cutting power that finishes down smooth and glossy in one step!
  • Use with Meguiar's Microfiber Cutting Disc Buffing Pad and a Porter Cable 7424 XP for best results
  • Revolutionary new technology that will forever change detailing!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old 04-24-2013, 07:19 AM   #1482
Today's Daily special (April 24, 2013) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.79!
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
Old 04-25-2013, 07:18 AM   #1483
Today's Daily special (April 25, 2013) is CarPro Iron X Iron Remover ( IronX w/cherry scent ).
Regular Price for 500 ml is $19.99. Today's price is $15.20!
Regular Price for 1000 ml is $32.99. Today's price is $25.08!
Regular Price for 4 L is $99.99. Today's price is $85.00!
  • This is the MUST have product for ALL detailers!
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Cherry scented with improved formula!
Old 04-26-2013, 07:03 AM   #1484
Today's Daily special (April 26, 2013) is DI Brushes Leather and Vinyl Scrub Brush.
Regular Price is $3.99. Today's price is $2.91!
  • Outstanding leather care brush to deep clean leather!
  • Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
  • Soft and gentle leather brush that works great
Old 04-29-2013, 06:05 AM   #1485
Today's Daily special (April 29, 2013) is DI Accessories Universal Replacement Flip Top Caps.
Regular Price is $0.75. Today's price is $0.56!
  • Universal top that fits the majority of 16oz, 32oz, 500ml and 1000ml bottles
  • Spout helps control how much you pour out
  • Helps conserve product and save you money
  • Keep a few around the garage in case you break a cap
Old 04-30-2013, 07:20 AM   #1486
Today's Daily special (April 30, 2013) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.46!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old 05-01-2013, 07:10 AM   #1487
Today's Daily special (May 1, 2013) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6 inch is $11.99. Today's price is $8.75!
Regular Price for 5 inch is $9.99. Today's price is $7.09!
Regular Price for 4 inch is $5.99. Today's price is $4.79!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a medium or heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old 05-02-2013, 07:06 AM   #1488
Today's Daily special (May 2, 2013) is Dodo Juice Born to be Mild Shampoo.
Regular Price for 250 ml is $16.99. Today's price is $12.66!
  • One of the best shampoos we've tested in terms of lubricity and maximizing your coats of protection
  • Highly concentrated formula means only a little bit of product is needed to achieve great results
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Old 05-03-2013, 07:08 AM   #1489
Today's Daily special (May 3, 2013) is DI Accessories Razor Blade and Mini Plastic Holder.
Regular Price is $1.99. Today's price is $1.41!
  • Pocket size plastic scraper with one single edge razor blade
  • Quickly remove inspection stickers and registration stickers
  • Use for virtually any scraping, trimming, or cutting
  • Open or close with easy push button lock system
Old 05-06-2013, 06:08 AM   #1490
Today's Daily special (May 6, 2013) is Surbuf R Series MicroFingers Buffing Pads.
Regular Price for 2x 6.5" is $16.99. Today's price is $12.57!
Regular Price for 2x 5.5" is $13.99. Today's price is $10.21!
Regular Price for 2x 4" is $9.99. Today's price is $7.29!
  • Excellent polishing power with minimal haze left behind!
  • Read a professionals recommendations on how-to use Surbuf pads properly
  • Each box comes with 2 pads
  • The pads can be washed and re-used many times
  • Perfect match for Porter Cable users with Meguiar's M105
Old 05-07-2013, 07:05 AM   #1491
Today's Daily special (May 7, 2013) is DI Accessories Razor Blade.
Regular Price for 100 pack is $6.99. Today's price is $5.03!
  • 100 pack is an awesome value!
  • Fits all standard razor blade holders
  • Made in USA high carbon steel
  • Quickly remove contamination, stickers, etc.
  • Single edged design
Old 05-08-2013, 07:13 AM   #1492
Today's Daily special (May 8, 2013) is Chemical Guys Luber.
Regular Price for 16 oz is $9.99. Today's price is $7.29!
Regular Price for 128 oz is $29.99. Today's price is $24.92!
  • An outstanding clay bar lubricant formulated to work specifically with your clay bar
  • Can also be used as a quick detailer to remove a light dusting along
  • Works great with the Chemical Guys Fine Grade Clay Bar
Old 05-09-2013, 07:10 AM   #1493
Today's Daily special (May 9, 2013) is Little Trees Royal Pine Air Freshener.
Regular Price is $0.99. Today's price is $0.71!
  • The original Little Trees scent that is still a favorite
  • Proudly made in the USA
  • Great scent that lasts several weeks
Old 05-10-2013, 07:11 AM   #1494
Today's Daily special (May 10, 2013) is DI Accessories Plastic Razor Blade.
Regular Price is $0.99. Today's price is $0.72!
  • Perfect to use on windows!
  • Quickly remove inspection stickers and registration stickers!
Old 05-13-2013, 06:07 AM   #1495
Today's Daily special (May 13, 2013) is Little Trees Wild Cherry Air Freshener.
Regular Price is $0.99. Today's price is $0.74!
  • A great cherry scented air freshener that everyone will love!
  • A fun and pleasant scent that easily lasts several weeks
Old 05-14-2013, 07:06 AM   #1496
Today's Daily special (May 14, 2013) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.25!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
Old 05-15-2013, 06:57 AM   #1497
Today's Daily special (May 15, 2013) is Stoner Trim Shine Vinyl & Plastic Coating.
Regular Price for 12oz is $5.99. Today's price is $4.37!
  • Restores and UV protects vinyl, plastic and rubber using a clear, colorless, non-greasy formula
  • Works great on faded trim, bumpers, in the engine bay, running boards, rubber moldings, AC vents and more
Old 05-16-2013, 07:00 AM   #1498
Today's Daily special (May 16, 2013) is Lake Country Black Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $7.99. Today's price is $5.75!
Regular Price for 4 inch is $4.99. Today's price is $3.69!
Regular Price for 3 inch is $3.99. Today's price is $2.83!
  • A finishing pad is designed to bring the paint to its maximum depth and gloss when combined with a finishing polish
  • Used to apply a light polish, finishing polish, glaze, sealant or liquid wax
  • Menzerna SF 4500 (PO85RD) is one of the most popular polishes to use with a black finishing pad
  • We recommend cleaning your pads with Lake Country Snappy Clean Pad Cleaner
Old 05-17-2013, 07:05 AM   #1499
Today's Daily special (May 17, 2013) is Sonax Profiline Nano Polish 3/6.
Regular Price for 1000 ml is $47.99. Today's price is $35.03!
  • Excellent polishing power but still finishes down extremely well
  • Works great as a one step polish or pair it with the SONAX Profiline Fine Abrasive Paste 5/4 for serious polishing power
  • Safely removes swirls, oxidation, water marks, ultra fine scratches, etc.
  • Has the polishing power of a medium cutting polish but finishes down like a premium fine polish should
  • Low dusting, easy to use, easy to remove
Old 05-20-2013, 06:11 AM   #1500
Today's Daily special (May 20, 2013) is DI Accessories Medium Grade Clay Bar.
Regular Price for 200 g is $18.99. Today's price is $14.05!
Regular Price for 100 g is $10.99. Today's price is $8.13!
  • Use to remove stubborn contamination such as tree sap, tar, rail dust and paint overspray
  • Large enough to break into several pieces for multiple uses
  • We recommend Dodo Juice Born Slippy as a clay lube
  • If you drop a piece of clay, throw it away!
Rate This Thread
