Old 06-04-2008, 07:28 PM   #1
tanzi
My Ride: 02' 325i
M54 Engine Sensors
What different types of sensors are on a M54? (i have a 2002 325i)
Idle control sensor, cam positioning sensor....... what else?
Can i replace these cheaply to help a rough start-up idle and as piece of mind?
tanzi is offline   Reply With Quote
Old 06-04-2008, 08:34 PM   #2
EvilGenius
Banned User
My Ride: '02 BMW 330Ci
There are a lot. If you just want to replace them all, you will a) spend a lot of money and b) waste most of it. It would be a better practice to get a diagnostic readout to find out what (if any) sensor is giving you static. Buuut, since you asked, all of the sensors that I can think of on an M54 engine:
2x Pre-cat O2 sensor (bank1, bank 2)
2x Post-cat O2 sensor (bank 1, bank 2)
exhaust cam position sensor
intake cam position sensor
camshaft position sensor
2x water temperature sensor (2 locations)
ICV (integrated idle position sensor)
throttle body with integrated throttle position sensor
knock sensor
oil level sensor
oil press sensor
oil temp sensor
mass air sensor
Hmm, know I'm missing some but that is the majority I think.
EvilGenius is offline   Reply With Quote
Old 06-04-2008, 09:01 PM   #3
tanzi
My Ride: 02' 325i
i just wasnt sure if there were 2-3 that should be replaced at around 70k miles if i am itching for something to do.
Old 06-04-2008, 09:05 PM   #4
EvilGenius
Banned User
Well if ya really want to The cam sensors are ~$100/ea, but that may not be the source of your problem. Better to get a diagnostic to find why your car is running rough at idle. Could just be a $20 rubber intake tube.
Old 06-05-2008, 10:25 AM   #5
951Tom
My Ride: 2001 BMW 330ci
There is also a crankshaft position sensor and a air intake temp sensor.
Tom
'01 330ci
951Tom is offline   Reply With Quote
Old 06-05-2008, 12:25 PM   #6
NiceRideENT
My Ride: 01 330Ci - Step
Is there a sensor to tell if the other sensors are bad?
If at first you don't succeed, don't try skydiving
NiceRideENT is offline   Reply With Quote
Old 06-05-2008, 01:38 PM   #7
02m3csl325
My Ride: is Stage 2 AWD!
^lol (insert whitty comment here)
02m3csl325 is offline   Reply With Quote
Old 06-06-2008, 03:23 AM   #8
abmi0000
My Ride: BMW 330i
Yup - It's called a Faulty Sensor
abmi0000 is offline   Reply With Quote
Old 06-06-2008, 04:05 AM   #9
paraklas
My Ride: ESS TS2 320ci
knock sensor
oil level sensor
oil press sensor
oil temp sensor
mass air sensor
ICV = Idle control valve, not a sensor
Camshaft position sensor? 1 exhaust and 1 intake.
