Old 06-11-2008, 11:22 AM   #1
stolidog
My Ride: 2004 M3 6spd
DISA Valve Removal
In every DIY guide and in every post I have read about taking out the DISA valve, the consensus is that there are two torx bolts/screws holding it in place (when I look at my car it looks like there are only two as well). However, when I went to the dealership to get new screws, the guy told me I needed 4. It looks like they are sold in 4-packs, so hopefully one of you can shed some light on this. The part number i found on realoem was 11611440384. I'm thinking they either just sell them in packs of 4 and the parts guy assumed that I "needed" 4, or.... I found the wrong part number. Any ideas?
stolidog is offline   Reply With Quote
Old 06-11-2008, 12:39 PM   #2
EvilGenius
Banned User
My Ride: '02 BMW 330Ci
There is definitely only two on the DISA valve. They may sell a pkg of four for use somewhere else on the intake. Any particular reason why you are buying new screws? You shouldn't need them unless the old ones are torn up. Your part # looks correct though.
EvilGenius is offline   Reply With Quote
Old 06-11-2008, 01:14 PM   #3
stolidog
Well... the top one was siezed in there pretty good and I sorta stripped it I tried to cut corners by not removing the cabin microfilter and the heatshield to the right. Doing that didnt give me the best angle on it and well... thats that. When I try it again, everything is coming out, ive got screw extractors, penetrating oil... you name it.... that screw is coming out!
Old 06-11-2008, 02:08 PM   #4
willsbma
My Ride: 99 323i
Anti-seize
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 06-11-2008, 06:44 PM   #5
Bailey228
My Ride: 99 323i Alpine White
Defintely 2 for the DISA valve, and 2 more for the Idle Control Valve that are the same size. As stated, you don't need all four for the valve.
The right to speak freely does not guarantee the right to be taken seriously.
Bailey228 is offline   Reply With Quote
Old 02-02-2010, 12:31 PM   #6
dino71
My Ride: 2003 BMW 330i
I tried to remove my DISA last night and the 5mm female hex bolts were not letting me put my 5mm allen in there and I ended up rounding the interior of the bolt. Is there a special tool that is used to remove these dam bolts? I have a motorcycle with like 50 5mm allens and never had a problem, why does BMW have to F-up something like this and make everyone life harder than it has to be?
dino71 is offline   Reply With Quote
Old 02-02-2010, 12:45 PM   #7
BakaN20
My Ride: 06 350z 03 325xi
If I remember correctly, the inside was torx-40, I just did mine recently and I think that was it. It was easy enough to remove the intake and stuff, you shouldn't cut corners. Good luck!
Asian guy who drives an import and a euro, but secretly dreams about driving a big V8.
Home - Fcuk Iraq - Done playing Soldier
06 350z - Nismo Exhaust/Dynotune Nitrous Wet Shot/NANO Kit/Motordyne 5/16th Spaver/mrev2/Other stuff
03 325xi - Monokuro Boo neck rest and seat belt pads, floor mats. ~Stock~
BakaN20 is offline   Reply With Quote
Old 02-02-2010, 01:58 PM   #8
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
so easy!
some times I pull this outta the card deck and show the milled disa cap that never was.
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 02-02-2010, 04:52 PM   #9
dino71
Are you talking about the DISA or the Idle control unit? The DISA bolts look like they are supposed to be allen...am I mistaken?
Old 02-02-2010, 04:55 PM   #10
BMW#1_323i
My Ride: Loves curves!
If your going to pull out the disa, you may want to replace the o-ring before you put it back in as this can lead to a vacuum leak. Happened to me.
BMW#1_323i is offline   Reply With Quote
Old 02-02-2010, 05:04 PM   #11
323I00
My Ride: E46 323I
How do you reconize DISA Issues ? What are the signs or encounters ?
323I00 is offline   Reply With Quote
Old 02-02-2010, 05:31 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
It's the black box on the side of the intake manifold.
You can determine if it's failing by the valve ticking inside
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 02-02-2010, 05:34 PM   #13
Rene325ci
My Ride: a car
Originally Posted by MachRc View Post
so easy!
Where did you find this cap? I want one of those
Originally Posted by Born Again View Post
relax kiddies ur 10 year old car is still god on this forum
Rene325ci is offline   Reply With Quote
Old 02-02-2010, 05:37 PM   #14
BakaN20
http://forum.e46fanatics.com/showthread.php?t=691291
I am pretty sure it is a t-40. Like I said, I just did it.
Hey Solidjake, I used your video when I did my disa. Thanks for the diy!
Old 02-02-2010, 05:40 PM   #15
Solidjake
Zero. Leaks.
Solidjake's Avatar
you're welcome
Old 02-02-2010, 05:42 PM   #16
beingdevious
Apple Jews
beingdevious's Avatar
Location: Drunk onthe Beach.. Official 4ngiefest.com Techie Go to: 4ngiefest.com/donate Needs: to leave the computer Status: ///Pantless
My Ride: 2001 325i Sedan
Send a message via AIM to beingdevious
i think he had it made
i am curious though, MachRC, did doing the cap affect any performance, or is it pretty much unnoticeable? I'm thinking about eliminating mine as well.
[IMG]http://************/ogaeq6[/IMG]
Question for you:
Are boobs and hands polarly charged, thus causing the inevitable joining of the two? If so are some breasts simply charged backwards?
On a scale from 0 to 24...wait, 3 to 24, where 6 is the lowest and 12 is the highest, how freaking high re you right now?
She's got you high, and you don't even know yet.
beingdevious is offline   Reply With Quote
Old 02-02-2010, 05:43 PM   #17
Rene325ci
My Ride: a car
He may have had it made, but if he made a diagram with all of the values it would make it easier to make one
Old 02-02-2010, 05:48 PM   #18
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Jake,
Belated thank you from me on your disa diy...I think I watched one of you heading to throttle body...and I'll get to that in spring. I also gave up like an idiot before cleaning icv.
And Yes, T-40, not an allen head...though I'm sure the 5 mm fit in fine...that's what stripped the bolt.
Doug
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-02-2010, 06:20 PM   #19
323I00
My Ride: E46 323I
Old 02-02-2010, 06:21 PM   #20
323I00
My Ride: E46 323I
