Old 06-29-2014, 11:29 AM   #1
zetatre
My Ride: 2004 X3, 2003 Z4
Mann+Hummel Provent 100 as oil separator on M54
Hello guys!!!! I thought I'd share here a mod I've done to our Z4 that you may find of use for the E46...
It's no news that the crankcase breather system on the M54 is a great idea with poor implementation. The thing either cracks causing vacuum leaks, or does a poor job separating the oil suspended in the crankcase fumes. On the Z4 it cracked and after I replaced I discovered the car went from using basically no oil to using 1 quart every 3K miles. After disassembling the plumbing of the CCV I discovered quite a bit of oil in the line going from the CCV to distribution rail on the intake.
What I went ahead and did was installing a Mann+Hummel ProVent 100 oil separator. You can find the catalog of Mann+Hummel ProVent here: https://www.mann-hummel.com/fileadmi...nt_en_2013.pdf
These separators are designed for diesel engines and because of that we need to keep in mind two things:
1) The HP rating is not a good metric for our NA cars: diesel have a much higher boost (my X5 35d runs a bit over 40 psi), much higher compression (16:1 Vs 11:1), which (along with diesel burning characteristics) result in much higher peak cylinder pressure. Bottom line HP per HP they generate more blow-by. The issue with flow and flow rating of the ProVent unit is not so much because they would cause a restriction, but primarily because the efficiency of the filter to separate oil particles decreases with flow.
2) They never run under any significant vacuum so the CCV uses the small depression between the air filter and the turbo to draw blow-by into the intake. As a result of it, the valve on the Mann+Hummel filter can't be used to regulate crankcase pressure in our engine
Because of #2 we need to do 2 things:
a) savage the valve from the stock CCV system
b) disable the valve ProVent
For (a) I simply cut the valve off of the stock CCV
For (b), it may be not needed at this point since the stock CCV is already reducing the vacuum from several inches of mercury (what you find in the intake of a NA car) to few inches of water (what you find between the filter and the turbo of a diesel engine). You can't completely remove the membrane since it acts as seal as well, but you can simply superglue it to the cap: this way it will not interfere...
Other than that you have some plumbing to do. Form the valve cover to the ProVent 100: you can disconnect the connector from the stock plumbing and using a 3/4 inch rubber hose you can have a very stock look.
From the ProVent to the stock modified CCV
And also from the ProVent back to the oil sump. On that line I added a check valve to ensure that under no condition the oil dipstick acts as a crankcase ventilation chimney; to ensure proper filtration I want fumes to always come only from the valve cover
I secured the ProVent 100 under the air filter so it's not visible
After putting all back together I quickly checked the crankcase pressure using a plastic bag over the oil cap: as expected there is a mild vacuum under all condition. The pressure drop across the ProVent filter element is extremely small.
After about a week of driving here's how the filter was:
Mind you that these are coalescer filters: their job is to combine oil droplets and vapor into larger drops that stay behind. Once the filter reaches a certain saturation it start shedding oil: gravity will cause oil to collect towards the bottom of the filter and eventually pool and drain back in the sump. In diesel engine these filters need to be replaced every so often primarily because the soot suspended in the oil particles tends to clog the filter. In our cases the replacement interval should be longer
I guess it's now drive and see...
Hopefully you find this useful!!!_a_
zetatre is offline   Reply With Quote
Old 07-02-2014, 03:18 AM   #2
Tappers
My Ride: Ducati749
awesome writeup!
any updates?
what was your oil consumption before and after?
Tappers is offline   Reply With Quote
Old 07-02-2014, 11:53 AM   #3
zetatre
Originally Posted by Tappers View Post
awesome writeup!
any updates?
I don't have much of an update yet since I basically just installed it other than everything appear to be working fine... I'll keep you posted on oil consumption.
My situation was pretty obvious since I went from no oil used to 1qt every 3k miles just by changing the stock CCV. Also the tubing going from the CCV to the distribution flute on top of the intake was coated with oil.
Old 07-02-2014, 05:19 PM   #4
BringsMeWomen
My Ride: 2001 330ci
I just started to lose a lot of oil in my car as well. I will definately look into this good DIY!
BringsMeWomen is offline   Reply With Quote
Old 10-28-2014, 06:50 PM   #5
zetatre
Just a quick update: after 5K miles oil consumption is entirely gone. No other issues to report.
Old 10-28-2014, 07:58 PM   #6
markusmarkus
My Ride: 2001 330Ci
Just out if curiosity, how much is the valve? Where did you buy?
Old 10-28-2014, 09:59 PM   #7
zetatre
I bought mine from diesel-filters.com and it cost $75-$85 depending on the design. The PDF I posted has the part number of the different designs that are available.
Old 10-29-2014, 09:31 AM   #8
markusmarkus
My Ride: 2001 330Ci
Thanks for the info. Question: do you think that oil vapors are being properly burned?
Old 10-29-2014, 12:47 PM   #9
zetatre
I've no idea or thoughts on it. I guess if they make it in the combustion chamber they burn just fine, it's not a lot anyway. Not all of the oil makes it, and in the long run it gets the intake dirty. Valves stay fairly clean since we have manifold injection and gasoline wash them off, but in GDI oil cakes up and carbonizes quite a bit. In diesels the crankase vents ahead of the turbo so the vapors end up covering the intercooler and once they get to the intake they mix with the soot from the EGR and really cakes up.
At the end of the day on the Z4 I did it because I didn't like to have to top off oil more than anything.
Old 10-29-2014, 05:29 PM   #10
markusmarkus
My Ride: 2001 330Ci
Thanks for the response. I was curious if your car passes emission testing.
Old 10-29-2014, 05:35 PM   #11
zetatre
As far as the sniff test I never had any issue: 1qt of oil every 3K miles will go unnoticed.
As far as the visual inspection, we'll see. The setup is not some shiny aluminum catch can from eBay; it's a clack plastic box that I guess would go unnoticed to the untrained eye. And it's hidden away... But we'll see: my smog comes up next year.
Old 08-25-2016, 04:14 AM   #12
Hil_lo
My Ride: 325ti Msport
Massive thread bump
But what do you have to modify on the old ccv? Looking to do this myself.
Hil_lo is offline   Reply With Quote
Old 02-07-2017, 02:49 AM   #13
ralf
My Ride: 330i
This vale is rated for 100 kW the M54 engine makes 170 kW have you had any problems or failures with the valve?
ralf is offline   Reply With Quote
