Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Old 06-26-2008, 03:40 PM   #1
oceanfront26
My Ride: 2000 BMW 328I (E46)
E46 Fuel Pump
I'm new to this forum, I just got this E46 and this is the first time trying to fix it myself, I would like to know if any of you guys have had trouble with the fuel Pump, If so I would like to know how to know if is broken? Thank you.
The car cranks but won't start and the i let it seat for about 4hr and it will start again, I need help trying to Diagnos it.
oceanfront26 is offline   Reply With Quote
Old 06-26-2008, 05:05 PM   #2
K:^P
My Ride: 00 323//65 Fastback
well if it starts up after 4 hours then the pump is somewhat working. Most likely it's something else. It could be anything; relay, crank sensors, etc...
Check if it throwing any CEL code, go from there.
K:^P is offline   Reply With Quote
Old 06-26-2008, 08:07 PM   #3
scarface007
My Ride: 04 E46 M3
pump problems most like fail under load not at start up ,if pump was bad it woul not start ever . run a scan you might have a problem somewere else .
" Some people spend an entire lifetime wondering if they made a difference , The Marines don't have that problem. "
- President Ronald Regan
http://www.ftperformancebmw.com/
scarface007 is offline   Reply With Quote
Old 06-26-2008, 08:23 PM   #4
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
never seen a pump problem on an e46 and i been workin on 'em a year
330ciandr6 is offline   Reply With Quote
Old 06-26-2008, 08:27 PM   #5
BodyMan
My Ride: 2002 325i
My pump just went out a few weeks ago. Car ran like a champ one day, next day it wouldnt start. Changed it in about 15 minutes, and did the filter also. Fired right up.
BodyMan is offline   Reply With Quote
Old 06-26-2008, 10:56 PM   #6
Exacc
My Ride: 2005 ZCP M3
It could be your fuel filter only being clogged. Happened to me also...Was in traffic and the car just shut off. Tried to start it but the car would not stay on, or would not let me rev it...and cut out after a few seconds. When they towed the car to the dealership a few hours later, it started just fine.
Basically, from what was explained to me...because the fuel filter is clogged, it could not pass fuel to the side of the tank where the pump is...
Fuel filter replacement is done on each inspection I, I think, or II. haha
2005 E46 M3 ZCP
2008 E92 335i
Exacc is offline   Reply With Quote
Old 06-26-2008, 11:31 PM   #7
oceanfront26
I had My car scan today and they are No codes on it. but I still have the problem I will start by changing the fuel filter and i will take it from there i will keep you guys post it thank you for all the good replies keep them comming.
Old 06-27-2008, 12:01 AM   #8
E46_SoKOR_328I
E46_SoKOR_328I's Avatar
My Ride: --
I had my fuel pump die on me while on the highway. Had merge over 3 lanes of traffic to get to the shoulder with no power.
Sure way to test is to look at your fuel rail. There's a small valve towards the front, if you press it with a small tipped screwdriver, fuel should come out. In my case, I heard AIR.
I'll have to agree with checking your fuel filter (under the belly, driver's side). Go ahead and check your fuel lines (especially going towards the front of the vehicle). Any kinks is sure to restrict fuel flow.
E46_SoKOR_328i
Mobile Gear
Camera: Nikon D700 w/ RRS L-plate
Lenses: Nikon 14-24mm, 24-70mm f/2.8, 70-200mm f/2.8 VR1 w/ RRS foot, 105mm f/2.8 VR
Mobile Lighting: SB-900, SC-29, Lumiquest Softbox III, Manfrotto 12' lightstand, Westcott 60" conv. umbrella.
Bag: TTP Urban Disguise 50 v2
Support: Gitzo 2330 w/ RRS BH-40.
E46_SoKOR_328I is offline   Reply With Quote
Old 06-27-2008, 12:43 AM   #9
venzon
My Ride: 04 zhp 6MT
Just replaced the fuel pump on my daughter's car 2 months ago. Problem was intermittent, it stalls and not start. After a few hours, it will start again. One way to check if the fuel pump is the culprit is to listen for the sound. When you turn the key on (without starting engine), you should hear the pump run for a few seconds. If you can't hear any sound, more than likely the pump is broke. Another test is to lift the rear seat to gain access to the pump (passenger side). Tap the fuel pump with a rubber mallet then try starting the car. If it starts, then 100% you need a new fuel pump. Good luck!
venzon is offline   Reply With Quote
Old 06-27-2008, 07:33 AM   #10
scarface007
My Ride: 04 E46 M3
fuel related problems will not set any faults in the DME on the e46 . i would check fuel pressure at iddle , and then while driving ( under load ) . If you do have a pump problem you should replace the filter as well .
Old 06-27-2008, 07:38 AM   #11
scarface007
My Ride: 04 E46 M3
i dont know were you learned your diag techniques but these aint our fathers 69 Camaro . The fuel system is more complex than that . for example If you have a siphen pump problem ( wich is the left side sending unit that feeds fuel to the right ) you can have these problems listed above , fuel pump could be good but starving it self becasue of a faulty siphen pump . dont just throw parts at the car unless its an ovious problem , dignose the problem right and fix it first the first time .
Old 06-27-2008, 08:26 PM   #12
venzon
My Ride: 04 zhp 6MT
I'm just providing information that I have experienced and fixed my problem. If you have a full tank of gas and still have the problem, I think you can rule out the siphon pump being the culprit.
Old 06-28-2008, 04:18 PM   #13
oceanfront26
Just a keep update, Today I change the fuel filter and the fuel relay before changing the fuel pump, i will run it see if that takes care of the problem.
Old 07-02-2008, 05:42 PM   #14
oceanfront26
Is been about a week since a change the fuel filter and the car runs very smooth just like a bimmer should, I think that was the problem thank you guys.
Old 08-20-2008, 11:01 PM   #15
oceanfront26
Well my problem came back and now i'm thinking of replacing the fuel pump.
Old 08-21-2008, 02:16 AM   #16
Alex323Ci
My Ride: M3 & 323Ci (sold)
well there was another thread recently showing how to test the fuel pump. i'd do that first.
http://forum.e46fanatics.com/showthr...+baffle&page=2
Last edited by Alex323Ci; 08-21-2008 at 02:54 AM. Reason: link to thread w/answers
Old 08-21-2008, 02:21 AM   #17
monkeyjuice5150
My Ride: bmw
I believe you can put in a M3 e46 fuel pump for alittle upgrade...
Read it somewhere.. forgot.
monkeyjuice5150 is offline   Reply With Quote
Old 08-21-2008, 08:30 AM   #18
Nait Sirhc
My Ride: 92 GSX, 01 330i
I had my fuel pump go out. Took 15 minutes to replace it. It's really, really easy. Just bring a bunch of shop rags because you're probably going to get gas on yourself.
Nait Sirhc is offline   Reply With Quote
Old 08-21-2008, 09:55 AM   #19
330ciandr6
My Ride: .
take off the plastic cover beside the valve cover that covers the injectors, and on the fuel line you will see a valve, inside it is a schrader valve like on tires. u can remove that schrader valve, put a hose on it going into a bottle or something and turn the key on and see if you have any fuel pressure
Old 09-08-2008, 12:51 PM   #20
oceanfront26
I finally Change the fuel pump I spent about $150.00 and 30min of labor DIY and i got it pump from http://www.bmaparts.com/ grade deal Thank you.
