DIY for UGDO? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-30-2008, 08:46 PM   #1
Biz
My Ride: is clean.
DIY for UGDO?
Does anyone have a current DIY for the UGDO (Homelink transmitter)? The usual Circle BMW and BMW Nation links appear to be broken. It would figure since mine just came in from eBay.
Biz is offline   Reply With Quote
Old 06-30-2008, 09:21 PM   #2
deafboy
My Ride: 2000 323Ci
um...
1) take a flat head screw driver, pop the cover off
2) uplug connectors to completely remove the cover
3) cut (on the back side) an opening using an exacto knife
4) pop the UGDO in until you hear it clip
5) plug connectors in
6) pop cover back on.
I didnt think a DIY was needed.
-Cole aka bigtall*****
Originally Posted by Owtlaw333 View Post
You'll always be pretty in my eyes, Cole :luv:
Originally Posted by Chrissspyy View Post
i was like passed out while she's shoving the entire bar in my mouth. :rofl: :rofl:
deafboy is offline   Reply With Quote
Old 07-01-2008, 03:18 AM   #3
Biz
My Ride: is clean.
Originally Posted by deafboy View Post
um...
Ha, that's assuming that my installs always go according to plan, which they never do. There was something about peeling away the headliner material away from the frame and cutting out the mounting hole that I wanted to check up on.
Old 07-02-2008, 11:34 AM   #4
jms_w
My Ride: '08 E93 M3
You must be referring to finding the ugdo connector. Once you pull the panel/cover off, there are 3 or so connectors tucked above the passenger side visor area. You need the white one with 3 wires and it's the only one that will fit the ugdo box. You may find black felt-like tape wrapping it almost completely. As for the cut-out/mounting , it'll be readily apparent where you need to cut as there's an outline on the inside of the cover. Good luck.
I've attached some pics.
jms_w is offline   Reply With Quote
Old 07-02-2008, 02:45 PM   #5
Biz
My Ride: is clean.
Thanks, man.
Old 07-02-2008, 02:55 PM   #6
Paul180
My Ride: 2003 330ci
http://www.bmw330ci.net/projects/homelink.php
This is how I did mine.
Paul180 is offline   Reply With Quote
Old 07-02-2008, 03:07 PM   #7
Biz
My Ride: is clean.
Nice work, Paul. You get two:
