Old 07-02-2008, 12:34 AM   #1
rholla1
My Ride: 2001 325i
Expansion Tank Installation Problem
Anyone have suggestions on how to get the new expansion tank seated on the bracket underneath it? I got the tank off with minimal trouble but I can't seem to get the replacement one pushed all the way down on the bracket underneath. I have been pushing on it as hard as I can but I'm afraid if I try much more I am going to break something underneath the tank. Whats the best thing to do to get this new tank to go on? Push from top or pull from bottom? Use any type of lubricant on the seal to make it go on? Any suggestions is much appreciated!
rholla1 is offline   Reply With Quote
Old 07-02-2008, 02:11 PM   #2
rholla1
My Ride: 2001 325i
No suggestions???
Old 07-02-2008, 02:56 PM   #3
djacs1
My Ride: 2001 325i
I had to push down from above pretty hard. I think I coated the bigger o-ring fitting underneath with coolant to help lube it.
good luck
djacs1 is offline   Reply With Quote
Old 07-02-2008, 06:40 PM   #4
Tom Busby
My Ride: 2001 325i, 1995 318i
Are you taking the "post" on the tank-bracket into account? The "post" points toward the front of the car. The post snaps into the radiator mount, and I'm guessing it is hanging you up if you are pushing straight down from the top.
Tom Busby is offline   Reply With Quote
