Old 05-13-2002, 07:04 PM   #1
Booraj323
Rieger/RD/HAMANN/ACS/HRE
My Ride: E500
Send a message via AIM to Booraj323
Uuc Big Brake Question?
I have a problem with my brakes... whenever i come to a stop there a slight jerk(making me go forward and back) like the rotors are worn unevenly & the wheel shakes when i brake.... the dealer says that it is the pads... but i don't think they know anything about the system... ANY ADVICE
Booraj323 is offline   Reply With Quote
Old 05-13-2002, 07:26 PM   #2
Delirium
yo mama
My Ride: -
Re: Uuc Big Brake Question?
Try contacting UUC Directly, they can probably help you.
Delirium is offline   Reply With Quote
Old 05-14-2002, 12:59 PM   #3
teamdfl
Slow in, slower out
My Ride: 325it
UUC brakes
The first couple days I had the UUC brakes on my car last fall, I had a mild shimmy under some braking conditions. After checking rotor runout, I found about .005" total runout in the rotors. After trading e-mail with Rob @ UUC, he guessed my rotors came from an early batch of rotors and hats from the prototyping stage that may not have been checked for trueness. I had a GOOD local parts shop take a very fine cut (~.003" per side) off the rotors and the shimmy went away. I checked the rotors after truing and found .001" or less total runout in both rotors.
The fact that my front control arm bushings were completely shot didn't help. I found out this spring the ball joints in the front control arms were bad so that probably also helped amplify brake shimmy.
Ed
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
