Old 02-01-2015, 07:30 PM   #1
SuperSleeper
My Ride: 2003 330CIC
Looking to mount a second battery
I want to make use of the front battery compartment and use it for always-on accessories with an isolator or solenoid. I'm sure I'm not the first to want this. Looking for ideas, perhaps some parts, like front battery mount, etc.
SuperSleeper
SuperSleeper is offline   Reply With Quote
Old 02-03-2015, 03:23 PM   #2
liket
My Ride: E36 M3
I don't know if it's viable, but the easiest thing should be to have two regular single throw double pull relays that switches between two wires, both at the battery and by the thing that needs power. Run a separate wire that connects to the "off-state pole" on the relays and just have the relays trigger via the ignition switch.
You would need to have an extra relay and wire for each thing you needed to power though.
liket is offline   Reply With Quote
