Old 07-06-2008, 09:53 PM   #1
BklynBimmer
My Ride: 323i
Exclamation Sputtering Problem
Recently I've been experiencing a sputter and loss of power, when i give the car some heavy acceleration from a stand still. If i power through the sputter the check engine light will go on and the car will shake when I come to a stop. Has anyone had this problem..........and any advice to fix it???
BklynBimmer is offline   Reply With Quote
Old 07-07-2008, 02:58 PM   #2
BklynBimmer
My Ride: 323i
Could this be a plug mis-firing??
Old 07-08-2008, 11:19 AM   #3
hummer
My Ride: 2001 330CI
You must check the codes!!
Old 04-28-2010, 10:55 PM   #4
E46 S54B32
My Ride: 323ci
this is exactly what my car is doing!!! any input..
yes i know thread revival but i rather continue a thread thats already posted than create a new one
this is exactly what class of 2010 has to learn to do
in a nutshell...let off clutch reallyyyy slow, she goes 5 mph and like 900 rpm-1000 rpm, floor it, car sputters thru out entire redline, sometimes CEL comes on and car runs really rough with rough idle and barley any acceleration, when CEL comes on i turn car off and turn back on and no more light, run the same process again a couple times and eventually CEL comes on again..need help
ohh and when CEL is off car idles REALLYY smooth you dont even feel it..only rough idle when CEL is on
-oem m3 front -oem m3 hood -oem m3 sideskirts-conforti intake -h&r race springs -TR Motorsport C2's -smoked corners/sidemarkers -smoked LED tails-CF CSL trunk-Black roof vinyl
E46 S54B32 is offline   Reply With Quote
Old 04-28-2010, 11:01 PM   #5
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
I'm actually experiencing a similar symptom on my car and have yet to get my hands dirty trying to diagnose it. It happened after I replaced my vanos seals and spark plugs back in January. It only happens for me occasionally though, maybe once a week when accelerating from a stop light. No SES light for me though. It almost feels like my problem is related to fuel. Maybe my injectors, or a clogged fuel filter.
-Gary
DiscoStu is offline   Reply With Quote
Old 04-28-2010, 11:07 PM   #6
E46 S54B32
My Ride: 323ci
i did my spark plugs a couple days ago and this started to happen when i changed them so im going to recheck my plugs tommrow...will spark plugs torqued to the wrong spec cause this?
you changed your plugs too, you should check them
my vanos is good tho
Old 04-28-2010, 11:09 PM   #7
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
Spark plugs are correct and were torqued to spec.
-Gary
Old 04-28-2010, 11:11 PM   #8
E46 S54B32
My Ride: 323ci
no im askking if spark plugs torqued wrong can cause this...bc my torque wrech seemed to be a little off for 18 ft-lbs
Old 04-28-2010, 11:13 PM   #9
Miko_10
My Ride: 330i 5 Spd
There's plenty of info if you search "rough idle". .
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 04-28-2010, 11:13 PM   #10
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
I was just stating that I don't believe this was the case for me as I torqued my plugs correctly. Post back results when you re-torque yours.
-Gary
Old 04-28-2010, 11:14 PM   #11
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
Do you have any idea how vague of a search term that is?
The problem here isn't really a rough idle either.
-Gary
Old 04-28-2010, 11:35 PM   #12
E46 S54B32
My Ride: 323ci
problem isnt rough idle its "sputter" and yes a searched hence the date of this thread
yea stu ill get back to the thread when i check this out tommrow
in the mean time if anyone has a clue what it might be..post it
fuel filter was changed 6k ago and ive used 93 octane (premium gas) ever since and new MAF 1k ago (will clean it out tommrow just incase)
Old 04-28-2010, 11:41 PM   #13
Miko_10
My Ride: 330i 5 Spd
okay okay, here's a summary of my experience, sputtering and rough idle issues, hopefully this can point you guys in the right direction. Post 24. I had some of the same issues and luckily I haven't had any problems since then, GL :
Old 04-28-2010, 11:56 PM   #14
E46 S54B32
My Ride: 323ci
holy crap dude you spent alot of money...
if my intake cam sensor was bad would a CEL come on?
Old 04-29-2010, 01:47 PM   #15
E46 S54B32
My Ride: 323ci
ok checked all my spark plugs today and torqued them right and still sputters/misfires when you floor it...i dont like it pleaseee input
Old 04-29-2010, 03:06 PM   #16
Miko_10
My Ride: 330i 5 Spd
it's possible, my ICS was replaced and I was getting an ICS code when all this stuff was happening to me. If you have a CEL or SES light on try and get the codes read.
