Old 07-28-2008, 04:21 PM   #41
sillieidiot
My Ride: '06 AW 330ci
Originally Posted by sdbimmer View Post
E46addicted,
Are you sure the Courtesy light is 44mm? Osram states it as 6418 which is 39mm. I take it, it will still fit just fine?
2 x Sunvisor Courtesy Lights (9Led Festoon 44mm White)
yes it's a 44mm. i can confirm as well.***9824;
Old 07-28-2008, 04:25 PM   #42
sdbimmer
My Ride: 2004 325Ci
Thanks for the info and thanks again for the pictures.
sdbimmer is offline   Reply With Quote
Old 07-29-2008, 01:45 AM   #43
e46addicted
My Ride: E46 320CI 2000
E46addicted,
Yes, i had only 4 44mm festoons in my car, 2 for the courtesy lights, and 2 for OEM interior trunk lights. Anyway it's easy to check, they just pop out.
- '99 323CI Euro Spec - Tit. Silver - K&N CAI - VMR CSL 18s - MTech II Side/Rear - CSL rep fr bumper - CF Door Handles & Trunk Handle - Predator Chromiums 6K - Xenoflo 6K HID - EE LED Tail Lights - OEM Clear Sidemarkers & fronts - UUC RK6BL Shift Knob & E-Brake handle - Autolumination Interior LEDs - UUC Clutch Stop - Parrot CK3K Evo - IV2 - JBL 300W bridged amp - Sony 500W Sub in custom enclosure - OEM 16:9 NAv Retrofit - Rev Camera
e46addicted is offline   Reply With Quote
Old 07-29-2008, 01:48 AM   #44
e46addicted
You're welcome, that's why we are here. Note on the pics : driver side is LED, and passenger side is Xenon Blue tinted halogen.
Old 07-29-2008, 06:03 AM   #45
DOB2009
My Ride: 325i
LED looks better for sure, thanks for posting. I think the bulb sizes posted are the same for my 01 325i. I'm just going to order them and try it out.
DOB2009 is offline   Reply With Quote
Old 07-29-2008, 07:29 AM   #46
e46addicted
Another important NOTE :
DO NOT use these bulbs for rear license plate lights, they will throw out a bulb out warning on dash and flicker like crazy, unless you want to use resistors, wich i didn't want to do. The ones that worked for me are the JLeviSW V2 Licence Plate LEDs, bright as hell, no resistors needed, direct replacement.
It may e my car is tricky or teasing me
Also note that all my info, testing, and results are related to my EURO SPEC car, using an EURO LCM that may be different from US LCMs in voltage and resistance outputs.
Cheers
