Old 07-08-2008, 09:20 PM   #1
Asmodeus
My Ride: 328i
Central Lock / Hazard Lights no longer working
The module that controls the central locking and the hazard lights isn't working, albeit the buttons do light up when I turn on the headlights.
I wanted to know if there are any areas I should check (fuse, known loose wires, etc) before buying a new module.
328i - TiAg / Black with PP - HK - 35% Tint - TiAG Headlight Trim - RSM - Gauge Rings - Clears - GruppeM - Silvervision - Koni Adjustables - UUC T.M.E., Clutch Stop, DSSR, Pulleys, Swaybars, LTW - EPS Pump - SS Brake & Clutch Line - MTech II Front - Angel Eyes - M3 Lip Spoiler - Z211, K104 - M6 Wheels -
TLC/BMW Instructor
Asmodeus is offline   Reply With Quote
Old 07-08-2008, 10:11 PM   #2
Steve@ASPTuning
ASPTuning
My Ride: 01' 320i
Check the connectors connecting to the switch. To get through there you need to remove your trim around your shift knob. And then another two screens that holds the plastic holder with switches I believe...
What happens over time due to usage the bottom peice that connects the buttons together is that it breaks. Therefore, the unti/switch needs to be replaced. I had to do this on a few cars... atleast 3 so it's a common wear and tear problem.
Steve
ASPTuning
Steve@ASPTuning is offline   Reply With Quote
Old 07-11-2008, 11:35 PM   #3
mastamind518
My Ride: 2000 323i
happened wit my car. all that happened was the bottom piece of the switch breaks so there is no resistance in the spring for the button to press. If you dont feel a "click" when u press the button like before then this is the issue. You can fix the current switch wit a little bit of super glue, but be careful not to put too much in....i kno from experience....some ended up leaking into the button n it wouldnt press Had to open it up and do it all over again w/o breaking it, but it works fine now. theres a diy for it somewhere if you search.
2000 323i
Carputer installed
mastamind518 is offline   Reply With Quote
Old 07-11-2008, 11:40 PM   #4
mastamind518
My Ride: 2000 323i
http://forum.e46fanatics.com/showthread.php?t=512654
6th post is a mini diy
2000 323i
Carputer installed
Old 07-12-2008, 12:12 AM   #5
madchef
My Ride: '04 ZHP Sedan MB/NB
Yup, careful application of super glue worked great for me
2004 ZHP Sedan - Mystic Blue/Natural Brown, Sunroof Delete
OEM M3 Stress Bar, AFE Intake, OEM Clears, CDV Delete
madchef is offline   Reply With Quote
Old 02-16-2014, 10:36 PM   #6
vjderose
My Ride: 2004 325Ci
Thank you all so much for this great thread! I almost started disassembling the console and would have bought a new switch once I got to it. I decided to read the forum first; popped out the switch, glued it together, and done!
vjderose is offline   Reply With Quote
