Old 07-10-2008, 07:19 AM   #1
skilletdog
My Ride: 2002 bmw 325i
Abs Control Module On A 2002 Bmw 325i
my abs light,dsc light ,and brake light all are on...will it hurt the car to drive it on a long trip before i get it fixed,,someone told me the abs control module needed repair and that the abs control module has something to do with the transmission,,,is this correct or is it safe to drive the car,,,everything seems fine other than the lights being on,,,help me with this question please friends....
skilletdog is offline   Reply With Quote
Old 07-10-2008, 10:17 AM   #2
skilletdog
i really need some help on this issue friends,,
Old 07-10-2008, 10:22 AM   #3
silverslider
My Ride: 2001 325ci
These units are fairly easy to replace, you just need to get it coded to the car once you do, driving it would hurt but i wouldnt rec. doing it. The trans needs speed sensor inputs to work right, if it does not see that you may go into failsafe mode in an extreme case.
silverslider is offline   Reply With Quote
Old 07-10-2008, 10:30 AM   #4
Fooljam
My Ride: 5
Having the same, ABS/DSC unit + 2 speed sensors + lights as you are gone.
Been 2 months now, been diagnosed by BMW, got the part number but have not done it yet. So been driving 2 months like this, no pb.
I am using my GPS to let me know the speed cause it is easy to lose your foot oj the pedal...
ABS/DSC unit is about 700 USD.
Well the only problem is that the mileage counter has stopped working, so I hope it is still saved somewhere and it will show off again when the car will be fixed.
Fooljam is offline   Reply With Quote
Old 07-10-2008, 11:31 AM   #5
skilletdog
thanks
where is it located,,i can't seem to locate it on my 2002 bmw 325i,,,?
Old 07-10-2008, 11:39 AM   #6
silverslider
My Ride: 2001 325ci
On the front of the ABS/DSC hydraulic unit, six t15 or t10 (cant remember) bolts. The black plastic portion with the connector, no bleeding required.
Old 07-14-2008, 08:21 AM   #7
skilletdog
thanks man but it looks very hard to get to this part..it seems to be underneath the master cylinder..is there a site i can go to to see how to do this job myself?
Old 10-13-2012, 10:41 AM   #8
esantos
My Ride: 325 i
I have the same problem with my 02 e46, ,all my lights are on, abs,dcs,airbag and brake lights!!! my mechanic cant seen to find the problem!!!! HELP?????
esantos is offline   Reply With Quote
Old 10-13-2012, 02:49 PM   #9
robin325ci
My Ride: Helrot 325Ci
Bring it to a mechanic/shop with the proper diagnostic software.
robin325ci is offline   Reply With Quote
Old 10-13-2012, 03:21 PM   #10
russian_e46
My Ride: 1999 BMW 328i 5spd
There is a company online that will rebuild the unit for like 120 dollars. Go on an e39 forum and there are tons of threads on it
Sent from my SPH-L710 using Bimmer App
russian_e46 is offline   Reply With Quote
