Old 07-13-2008, 03:45 PM   #1
Alb89n
My Ride: Goes places
Location of the condensation drain?
So basically I am trying to find the condensation drain because my car's ac has been dripping on my feet when I turn sharply. After looking at the diagrams I can't really determine where it is, though I did jack my car up to try to find it and saw a water drip coming from the above the trany. So my question is where the heck is the condensation drain so that I can try to clear whatever clog may be in there?
Thanks,
Alex
Alb89n is offline   Reply With Quote
Old 07-13-2008, 07:27 PM   #2
Alb89n
bump
Old 07-14-2008, 08:46 AM   #3
wolfe
My Ride: 330i
I'd like to know this too. It's in the evaporator housing but I don't know quite where it exits to in the transmission tunnel.
wolfe is offline   Reply With Quote
Old 07-14-2008, 02:09 PM   #4
KriTiKaL AspecT
My Ride: 2001 AW 330Ci
I believe the evap is behing the dash (center above the tunnel). Atleast thats how it is on an e30. Thats all I know.
Headers - KW V2 - Hotchkis Sways - 55w 6000k HID - 35w 6000k HID fogs
EVO 3 SSK mit ein DSSR - EE Tails - Meyle LCA, FCAB, & RTAB w/ Rogue Limiters - M3 Mounts ....
-Paul
KriTiKaL AspecT is offline   Reply With Quote
Old 08-12-2008, 06:16 PM   #5
Alb89n
bump. still need to know.
Old 09-08-2008, 06:07 AM   #6
scintilla
My Ride: E46 330i
My car is having the same problem. And I found this thread, which might help you.
http://forum.e46fanatics.com/showpos...2&postcount=14
I believe the hole in the middle of the transmission tunnel is the drain, right under the A/C housing behind the center console.
Does anyone know where the tube exits under the car? I got under the car last night but couldn't find any hose from that area.
scintilla is offline   Reply With Quote
Old 09-08-2008, 06:58 AM   #7
GoingNuts
Just Nuts
My Ride: 2004 330Ci
Can the drain be rerouted ? I think the water is rusting all my metal under the middle of the car.
GoingNuts is offline   Reply With Quote
Old 04-27-2009, 11:03 PM   #8
wacuna
My Ride: BMW 323i
Did anybody find the answer. Is that hole the AC drain? I need to know. Thanks,
wacuna is offline   Reply With Quote
Old 06-12-2011, 10:51 AM   #9
JeepBMW
My Ride: 01-330xi
We're having the same problem now. It started as a small drip here and there. Now it's gotten the carpet soaking wet on both sides.
Thanks,
Mike
JeepBMW is offline   Reply With Quote
Old 07-02-2011, 10:57 AM   #10
JeepBMW
My Ride: 01-330xi
After taking out the glove box and other pieces, this is my findings after the car has been sitting all night.
Old 07-02-2011, 12:17 PM   #11
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Guys, I know I've seen it, but didn't do anything with it at the time.
I'm thinking it was probably above the clutch bleed valve, as that was the only thing I've done that would be remotely in the area. Not a promise, per se, but a hope.
I'm recalling seeing just a little 1-2" rubber tube maybe 1/4 diameter. It's got to be visible from the bottom of the car...take a wire or something and clear it out...you'll know you've struck paydirt when a load of stinky water covers you!
Facebook.com/DMAXstandup
Mangofy your E46!
