Old 07-16-2008, 08:06 PM   #1
destroyer427
My Ride: 2000 M5
Question Radioshack resistor for front turn LEDs not working
I installed some amber 1157 LEDs (88 mA draw at 12v) for front turn signals from superbrightleds and am having an issue with getting my radioshack resistor to work with the bulb so that it prevents the bulb out warning/flashes at normal rate. The resistor is a wirewound 50 ohm 10% 10 watt, it is connected to both turn signal wires via a wire tap and plugged into with a male crimp connector. I've also stripped the wire at the wire tap contact point to ensure that all points of connection are bare metal to metal. See attached pic
With all of this hooked up I still get a bulb out warning and the bulb blinks at the very fast rate. The resistor does get warm however. Am I doing something wrong here or simply have the wrong type of resistor? At this point I am almost ready to just purchase a resistor kit from a sponsor to skip this headache. If there is an easy/cheap workaround to this I would be glad to hear about it. Thanks
destroyer427 is offline   Reply With Quote
Old 07-17-2008, 09:24 PM   #2
deadlysyns
My Ride: 2004 M3
I think you need to get a load resistor.
http://m3forum.net/m3forum/showthrea...=load+resistor
deadlysyns is offline   Reply With Quote
Old 07-27-2008, 07:01 PM   #3
destroyer427
My Ride: 2000 M5
Bump
Old 07-28-2008, 01:15 AM   #4
Steve@ASPTuning
ASPTuning
My Ride: 01' 320i
Try post #2 first and let us know. Make sure you didn't reverse the polarity.
Steve
ASPTuning
Steve@ASPTuning is offline   Reply With Quote
Old 07-28-2008, 11:06 AM   #5
jason 77
My Ride: 2007 E92 335i AT
Maybe try a higher resistance? What formula did you use to come up with the 50 ohms?
jason 77 is offline   Reply With Quote
Old 07-28-2008, 03:00 PM   #6
ca1242
My Ride: 2003 330i
1. 50 ohms is too high - go lower. I would guess about 10 ohms would be fine. If you already have 50 ohm resistors, you can do two or 3 or 4 in series on each side to figure out how "high" you can go while fooling the computer. Whatever resistors you use, make sure you watch the wattage. Lower resistance = higher wattage: at 10ohms, you need more than 20 watts. Lower you go in ohms, resistor gets hotter, so you also have to watch where you mount it; it could melt plastic. You might need to go from wirewound to aluminum resistors.
2. Picture of how the resistor is installed scares me. T-taps are not very reliable. Exposed metal is not good. Once you get another resistor, solder some wires to it and properly insulate with tape.
3. resistors have no polarity, so it can't be backwards
Old 08-12-2008, 09:30 PM   #7
destroyer427
My Ride: 2000 M5
The 10 ohms work perfectly, thank you! I picked up some aluminum dale power resistor 10 ohm 30 watt 1% that look similar to the following
Connected everything with crimping wire connectors and fully insulated tightly with electrical tape and mounted so that its nowhere near plastic/flammables. No more warning out lights and blinking is normal.
Started tearing apart the license plate lights but looked much more involved. May decide to tackle it later or just install whiter incandescents.
Old 08-12-2008, 10:16 PM   #8
ca1242
My Ride: 2003 330i
Glad you worked it out. License plate lights come out easy. Just need to push one end to the side and slide out. Might even be in the car's manual.
Old 08-13-2008, 05:36 PM   #9
destroyer427
My Ride: 2000 M5
I've already got LEDs for the license plate lights, installing the resistors for those look to be trickier however
Old 08-14-2008, 07:12 AM   #10
ca1242
My Ride: 2003 330i
NO they are pretty easy. You have two options, you can remove the lid carpet liner and get easy access to the wires, or you can intercept the wire harness after the wires come into the car through the rubber boot.
Old 10-04-2008, 11:10 AM   #11
bourmb
My Ride: 2004 Toyota Tundra
Where is everyone installing their load resistors? Don't they need to be secured to the metal body to eliminate the potential of high heat effecting the wiring or plastic if they were zip-tied to something?
bourmb is offline   Reply With Quote
Old 10-04-2008, 10:45 PM   #12
ca1242
My Ride: 2003 330i
Preferably, screw them to metal. 2nd best option is to zip tie them to metal.
Old 12-13-2008, 09:02 PM   #13
dres79
My Ride: 04 M3
Send a message via AIM to dres79
ok here is a stupid question but ... what if i dont use a resistor? my lights go out about a minute after i tur nthe lights off. any damage if i do not use a resistor??
TIA
dres79 is offline   Reply With Quote
Old 12-14-2008, 10:32 AM   #14
ca1242
My Ride: 2003 330i
TIA
No resistor = light out error on the dash. It it doesn't bother you, you don't need the resistor.
Old 12-14-2008, 11:52 AM   #15
dres79
My Ride: 04 M3
[QUOTE=ca1242;9065278]No resistor = light out error on the dash.QUOTE]
thanks,
i dont even get that. so all good NICE! .. on to next mod
Old 12-15-2008, 09:40 AM   #16
SubZeroE46
My Ride: E46 320i
I'm not sure if you need resistors for the license plate lights. Mine blew and I didn't realize it until someone told me about it, no warning lights on the dash. Maybe can check by removing the bulb and see if the dash light comes on.
SubZeroE46 is offline   Reply With Quote
Old 12-15-2008, 09:55 AM   #17
SubZeroE46
My Ride: E46 320i
hmm... been reading some posts on the lighting thread and it seems like most people have warning lights for license plate lights being out. Maybe it's my car, will check.
