Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 07-17-2008, 11:27 AM   #1
tradingflare
My Ride: needs a mechanic
How to properly jump start an E46?
The 15 threads going on with regard to cluster boy and his 600,000 miles on the odometer had me thinking. An improper jump start could easily fry the ECU on an E46. While we all take precaution and use good judgment when replacing our batteries, the time will come when we have to jump start them.
So, how do you do it on these cars?
1. What is the process? I see the red terminal "box" under my hood...
2. Which terminals do we connect first, and which car gets connected first?
3. Where do we ground the black cable on the E46? (frame?)
4. Which terminals do we disconnect, and which car gets disconnected first?
5. Is it safer to jump start from car to car, or from a "jumper box"...ya know, those portable battery-charger-and-jump-start-thingies.
Sounds noobish, and it is, but I'm sure someone reading this finds it beneficial to know.
tradingflare is offline   Reply With Quote
Old 07-17-2008, 11:32 AM   #2
Nismode
My Ride: Accord EX
Send a message via AIM to Nismode Send a message via MSN to Nismode Send a message via Yahoo to Nismode
I had to do this from a 'battery box' when my dad's E46 wouldn't start.
First you connect the red cable to the remote terminal under the hood. Then there is another exposed nut to connect the ground (black cable) to.
After starting, you disconnect it in the reverse order.
Originally Posted by jpr
Good for you. Rule of thumb is mechanical engineers build missiles, civil engineers build targets. But both get more dates than the computer guys.
Originally Posted by neil1138 View Post
vitamin water = Kool-Aid for white people
Need a photoshoot? PM me for details.
Nismode is offline   Reply With Quote
Old 07-17-2008, 12:13 PM   #3
NOVAbimmer
My Ride: E60M
yeah...follow the same procedure You would with any other car...
red to red, black to ground (on the car being jumped)
disconnect is the reverse
NOVAbimmer is offline   Reply With Quote
Old 07-17-2008, 12:17 PM   #4
NorCal Einstein
My Ride: E92 335i
Send a message via AIM to NorCal Einstein Send a message via Yahoo to NorCal Einstein
Follow this guide:
http://www.edmunds.com/ownership/how...3/article.html
But when receiving or giving jump starts, hook cables up directly to the battery in the trunk.
Avoid using the terminals in the engine bay.
Current:
2009 E92 335i Alpine White/Coral Red
Past:
2007 E92 335i Sparkling Graphite/Black
2000 E46 323i Steel Blue/Grey
NorCal Einstein is offline   Reply With Quote
Old 07-17-2008, 12:44 PM   #5
Gadgetrick
My Ride: ES330, Disco
Originally Posted by NorCal Einstein View Post
Follow this guide:
Why? Electronically, it doesn't matter where the terminals are. They could be a town away and the battery wouldn't know.
Gadgetrick is offline   Reply With Quote
Old 07-17-2008, 12:49 PM   #6
che13
My Ride: 90 325is,04 330i ZHP
Same as any other car - but it is spelled out for you in the manual - step by step if you need it
che13 is offline   Reply With Quote
Old 07-17-2008, 02:30 PM   #7
neil1138
wat? Im cluster boy now?
neil1138 is offline   Reply With Quote
Old 07-17-2008, 02:32 PM   #8
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Follow this guide:
DON:T hook up to the battery on any car that has a IBS on the negative terminal that will cause alot of issues!! We don;t even charge car from the battery becasue of that reason.
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 07-17-2008, 02:41 PM   #9
Poon Stick
My Ride: ///M 330xi Sedan
Follow this guide:
The second guy is correct. Due to the battery fluid consisting of Sulfuric acid (H2SO4), it has a tendency to give off hydrogen as it dies. Since jump starting a car normally means its battery is dead, that means you'll be making and breaking electrical connections in the presence of (possible) leaked hydrogen. Does that sound like fun to you?
that's what the engine terminals are for. To stay as far away from the battery as possible. Plus you never hook up to the negative side of the battery, instead you use ground. (frame or designated grounding bolt under the hood)
"Johny was a chemist's son, but Johny is no more. What Johny thought was H20 was H2SO4."
Poon Stick is offline   Reply With Quote
Old 07-17-2008, 02:41 PM   #10
max123
My Ride: e90 / e46 / R6
i think it's time to change your user name...!
max123 is offline   Reply With Quote
Old 07-17-2008, 02:53 PM   #11
NOVAbimmer
My Ride: E60M
we could just call You cf
...not carbon fiber...
Old 07-17-2008, 03:02 PM   #12
NorCal Einstein
My Ride: E92 335i
Whoa, didn't know that.
I was almost certain I read somewhere to not jump it from the engine terminals....
Current:
Past:
Old 07-17-2008, 03:08 PM   #13
Poon Stick
... cluster fail?
Old 07-17-2008, 03:49 PM   #14
Sicily1918
There I was, Sicily, 1918..
Sicily1918's Avatar
My Ride: '03 325Ci + '05 ZHP
... cluster fail?
Cluster fcuk... come on, now!
Sicily1918 is online now   Reply With Quote
Old 07-17-2008, 03:49 PM   #15
neil1138
cluster fuked, jeez
Old 07-17-2008, 08:31 PM   #16
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
i jumped mine the same way ive jumped every car my whole life, whats the problem? battery to battery
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 07-17-2008, 08:33 PM   #17
dmon_101
My Ride: has sexy fogs/shoes
Send a message via AIM to dmon_101
Follow this guide:
So are the jumper posts in the engine bay just for looks?
Dealer Programmable Options | Projector Fogs FTW
There are a lot of Fs and too many Ks in the F/M/K scenario <- posted before I met my wife
To answer your question, it's something you can find by searching the forum or using Google
dmon_101 is offline   Reply With Quote
Old 07-17-2008, 08:34 PM   #18
tradingflare
Just breaking balls, no biggie...
Old 07-17-2008, 08:37 PM   #19
dmon_101
I love that one.
Old 11-01-2013, 01:59 PM   #20
h2obimmer
My Ride: 2005 M3, 2002 XiT
this post is confusing and not helpful at all...can we get back on topic please
h2obimmer is offline   Reply With Quote
