Old 07-18-2008, 12:20 AM   #1
OEMguy
My Ride: 323i 99 4D E46
o2 sensors...how many?
How many o2 sensors are there in an E46? Ive read 4 and Ive also read only 1. I am losing crazy gas (20 miles for every 1/4 miles). And the engine service light is on. I now have 100,300 miles.
- 1999 323i E46 sedan
- Black on Black
- Clear corners/sidemarkers
- Scrolling LED license plate frame
- Chrome pipes
- Valentine One
- (2) 10" Subs + amp hooked up to stock radio
OEMguy is offline   Reply With Quote
Old 07-18-2008, 12:21 AM   #2
towelie
My Ride: 1999 323i
4 I believe, 2 on the headers and two behind the catalytic converters.
towelie is offline   Reply With Quote
Old 07-18-2008, 12:26 AM   #3
aaroncougar
My Ride: 02' M3 smg
4 is correct.
MODS:
Performance: AFE Intake Stage 1, ebay Headers, SS section 1 pipe, Shark Injector for SCCA T2 Class, Denso Iridium Spark plugs, Odyssey PC680 battery, Satisfied GS6 pads, wider tires (235/265)
Exterior: LED Tailights, Smoked turn signals, 20% Tint, DVD player/Nav, black coated wheels with polished lip
Interior: Kicker sound system
Coming soon:
Bilstein PSS9 coilovers
Pulleys
ti muffler
aaroncougar is offline   Reply With Quote
Old 07-18-2008, 01:24 AM   #4
sdbimmer
My Ride: 2004 325Ci
sdbimmer is offline   Reply With Quote
Old 07-18-2008, 01:27 AM   #5
Five_seveN
My Ride: rover james
Send a message via AIM to Five_seveN
^ yup. good diagram
Originally Posted by VaderDave View Post
I'm having a hard time imagining any set of responses that ends with anyone expressing admiration for Marshmallow.
Perhaps you should stop responding. It's a no-win for you here. :dunno:
Five_seveN is offline   Reply With Quote
Old 07-18-2008, 06:09 AM   #6
Bodo61
My Ride: 323i
Just did mine a few weeks ago and the 02 sensor tool that I had wasn't tall enough. I did get the pre-cats our with the use of a crows foot (that was easy) and the post-cats out with a wrench. I had 110K and haven't noticed a difference in anything. I sugest you remove one at a time (post cats) and then install (as opposed to removing both then installing). Reason is you don't want to mix what holes they need to go to.
Bodo61 is offline   Reply With Quote
Old 07-18-2008, 11:07 AM   #7
hummer
My Ride: 2001 330CI
And why haven't you check for codes?
Old 07-18-2008, 11:21 AM   #8
bigfatvr6prik
My Ride: Z8
You might be wasting time and money just changing things randomly. Read out the error codes from your OBDII ... use PEAKE or Carsoft or PA Soft etc. It will give you an idea on what the problem could be. Also, if O2 sensor is faulting it will give a code such as P0XXX--which will tell which sensor in which bank needs to be replaced.
Good luck.
bigfatvr6prik is offline   Reply With Quote
Old 02-25-2017, 02:26 PM   #9
dkokin
My Ride: 2005 330ci vert ZHP
My OBDII port shows O2 sensor data for only one sensor. The second sensor shows no data. I have no fault codes but my car requires leaving the key in the ignition for a few seconds before starting; otherwise it will continue to turn over for about 5 seconds before starting. It's starts immediately after priming.
I have replaced the fuel pump and regulator but the problem persists. Any thoughts?
dkokin is offline   Reply With Quote
Old 02-26-2017, 12:11 AM   #10
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Which OBD scanner or app are you using? Many don't correctly display the wideband O2 sensors on your car.
OBD Fusion app supports them correctly.
///Mmmmmm...
Old 02-26-2017, 01:14 AM   #11
dkokin
I'm using this cheap wifi OBD device:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 (power button let's me keep it plugged in)
and OBD Fusion on the iPhone. I haven't been able to find a decent bluetooth version what works with the iPhone. My phone doesn't connect to the internet when I connect via wifi.
