Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 4.83 average. Display Modes
Old 07-18-2008, 11:48 AM   #1
drealbmw
My Ride: 2005 325i e46
How do I replace my H7 halogen headlight bulb?
This is my question from yesterday. After working about 4 hours on the problem, you could guess that I got pretty fed up.
So I decided to leave it overnight. The morning light helped me solve the problem. So I decided to share the wealth. Here's what I did for my 2005 325i.
The trick is to look closely at the parts before you remove the headlight bulb. You don't want to turn the entire socket assembly -- just the black locking ring. It has a top and bottom tab that fits into the headlight assembly. Grab the square ring tab, which appears at the top right in the picture below, and twist it a short 1/8 turn counterclockwise (like you were sitting on top of the engine, facing forward). In the picture below, 0 is unlocked; 1 is locked. It will take a little effort to turn it to the unlocked position, but not that much.
Now, just pull the old H7 halogen bulb straight out and push the new one in, trying not to touch the new bulb directly with your oily fingers. I used toilet paper to handle the bulb. This step is a no-brainer, as you can see in the photo below.
Now, the fun part begins. There is a small, narrow slot in the clear, yellowish headlight assembly. You can see it at the bottom of the picture below, slightly to the right of center. (My macro camera setting is great, right? Even though it makes the part look huge.)
This yellow slot accepts the tab of the black locking ring. Barely. You really have to work at it to seat the socket assembly correctly.
You can see the block-looking black tab on the inside of the arm in the picture below.
Now, make sure the tab is in the unlocked, or "0" position. Then line up the 2 tabs, which are on opposite sides of the socket assembly ring, with the 2 slots. You won't be able to see them because your hand is in the way, so just give it your best guess. Then push the socket containing the bulb into the headlight assembly. Using trial and error, you will eventually be able to feel when the socket is seated correctly.
Then, I use my thumb on one tab and the middle finger on the other tab to line up the tabs and twist. If I guess wrong, I give a quick glance to the front of the car where the headlight is, and make sure that the bulb looks like it is seated correctly, and wiggle the part a little.
Then, just give it another go.
The only other bit of advice deals with the driver side headlights. It is a REALLY TIGHT SPACE. So, give yourself some more room and take off the cover of the square air filter housing. First, release the 2 clips for the hose containing the air flow sensor. Then release the 5 clips holding the air filter housing cover to its base. That should give you enough room to take a stab at the headlight assembly.
I know this is a long post on a small topic, but there are fewer and fewer things on my car that I can actually work on. I was determined that I was going to replace my headlights myself, no matter what! (Next time, I'll probably get the mechanic to do it.)
Good luck!
drealbmw is offline   Reply With Quote
Old 07-18-2008, 12:01 PM   #2
tony325ci_51
My Ride: BMW 335i 2007 Coupe
Yep, you got it right. Nice simple write-up that might be useful to those who haven't yet had to change a bulb.
Can be fiddly and take a little time, the key is to use patience, not force.
Daylight definitely helps (although most will end up doing it at night, cos you won't turn your headlights on to notice a blown bulb during the day).
DIY again next time, you've nothing to fear and it gets easier with practice.
tony325ci_51 is offline   Reply With Quote
Old 07-18-2008, 12:16 PM   #3
02m3csl325
My Ride: is Stage 2 AWD!
Lol wow, I was suprised not to find another diy on this subject although it is pretty much straight forward, nice write-up though.
02m3csl325 is offline   Reply With Quote
Old 07-18-2008, 12:51 PM   #4
Dan99
My Ride: 2001 330xi
Way to point out the obvious
Dan99 is offline   Reply With Quote
Old 07-18-2008, 01:00 PM   #5
Poon Stick
My Ride: ///M 330xi Sedan
Haha! Not so obvious, my friend
This post is basically an answer to my question. I couldn't seem to get the light out, I'm guessing because I wasn't using the square tab. I was just twisting it where the wires connect to the assembly. (The easiest part to reach without removing the air box.)
Thanks again drealbmw!
Poon Stick is offline   Reply With Quote
Old 07-18-2008, 01:24 PM   #6
drealbmw
If there is any way to mess things up, I WILL! (Or I will forget how to do it.)
So the next time I have this problem, I'll have this as a resource.
Now, if somebody could just help me upgrade my lame BMW stereo...
Old 07-18-2008, 08:46 PM   #7
wasp9166
My Ride: 04 330i jet black
Send a message via Yahoo to wasp9166
seemed like a piece of cake to me, whats the problem?
"if polarity comes from protons, does morality come from morons?"
Originally Posted by russ330 View Post
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 07-18-2008, 08:57 PM   #8
Poon Stick
So I came home and tried it... works like a charm if you only turn the square tabs!
Anyway the H7 lights I bought don't fit because they have an elbow (like they would fit directly to the wiring) but the bulb with prongs won't come out and thus won't fit into the assembly.
Would anyone like some unused, but opened H7 bulbs?
Old 07-18-2008, 09:57 PM   #9
wasp9166
sure you didnt buy h11?
Old 07-18-2008, 10:56 PM   #10
enelson325
My Ride: 2002 325i
haha
enelson325 is offline   Reply With Quote
Old 07-19-2008, 11:51 PM   #11
venzon
My Ride: 04 zhp 6MT
Nice write up OP! This will definitely come in handy for someone in the future. I wish you posted this two weeks ago. Took me an hour before I figured out how to remove the bulb.
venzon is offline   Reply With Quote
Old 07-20-2008, 12:56 AM   #12
colnago1331
My Ride: needs to be dropped
Same here.
colnago1331 is offline   Reply With Quote
Old 07-20-2008, 06:33 AM   #13
rishisen
My Ride: 316
good stuff, i found it real tricky at night, should help people
rishisen is offline   Reply With Quote
Old 08-05-2008, 12:13 PM   #14
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
im about to change out mine soon. if i run into any problems, i'll read this thread. lol
Devious1 is offline   Reply With Quote
Old 08-05-2008, 04:38 PM   #15
xNOxFear
My Ride: 99 323i
Just wanted to say thanks, changed the bulb last night and after reading this it was a breeze.
xNOxFear is offline   Reply With Quote
Old 08-06-2008, 01:28 AM   #16
HELLAS NC
My Ride: 03 320Diesel Tractor
Now that 4th pic was just a show-off for you camera... (and camera skills...)
Nice write-up!
I don't have a solution, but I admire the problem.
HELLAS NC is offline   Reply With Quote
Old 08-06-2008, 01:38 AM   #17
C4RLOS
My Ride: 2003 325Ci
FOR SALE: pre-facelift sideskirts and front and rear bumpers | 19" hyperblack VMR V715 wheels (in sig)
C4RLOS is offline   Reply With Quote
Old 10-28-2008, 07:16 PM   #18
omhl
My Ride: E46 M3 6MT
Send a message via AIM to omhl
+1+
+1 dude
omhl is offline   Reply With Quote
Old 10-28-2008, 07:21 PM   #19
tradingflare
My Ride: needs a mechanic
Thanks for the write up...things are NOT always so obvious, it's very much appreciated.
Little anecdote:
A buddy and I were trying to replace the headlight on his mom's 2000 VW bug. No manual or anything with us, we'd figure out it...we're guys, ya know? Well, after fiddling with the headlight assembly for 2 hours, an 8 year old neighborhood girl walked by and said, "Why don't you guys just pull the lights out toward you?"...that is, you actually pull the entire headlight assemblies directly off the car. She was right.
tradingflare is offline   Reply With Quote
Old 12-11-2009, 05:31 PM   #20
drealbmw
Glad to be a help to you guys, and the 1000s of other viewers!
